I renamed all relevant userdata-folders (skinshortcuts, shinhelper, etc.) and now all the widgets are shown.
Maybe the script got some hiccups due to testing many github-versions
No speed issues so far: I de-installed script.colorbox because I thought it causes a one second delay. Someone mentioned it before afaik.
There are still some Bugs:
1. BG -> Multi-Image -> I can't select the Kodi-folder, only my HDD (/media/INTENSO) and a SMB-share. Previously I was able to select the Kodi-userdata-folder, where all my BG-Images are
2. I have this in the logfile:
15:25:41 1336.088501 T:3038674944 WARNING: ReleaseTexture: Unable to release texture listselect_fo.png
15:25:41 1336.088623 T:3038674944 WARNING: ReleaseTexture: Unable to release texture separator2.png
15:25:41 1336.089966 T:3038674944 WARNING: Previous line repeats 4 times.
15:25:41 1336.090210 T:3038674944 WARNING: ReleaseTexture: Unable to release texture listselect_fo.png
15:25:41 1336.090576 T:3038674944 WARNING: ReleaseTexture: Unable to release texture separator2.png
15:25:41 1336.090820 T:3038674944 WARNING: Previous line repeats 1 times.
15:25:41 1336.090820 T:3038674944 WARNING: ReleaseTexture: Unable to release texture listselect_fo.png
15:25:41 1336.091064 T:3038674944 WARNING: ReleaseTexture: Unable to release texture separator2.png
15:25:41 1336.091187 T:3038674944 WARNING: Previous line repeats 1 times.
15:25:41 1336.091187 T:3038674944 WARNING: ReleaseTexture: Unable to release texture listselect_fo.png
15:25:41 1336.091309 T:3038674944 WARNING: ReleaseTexture: Unable to release texture separator2.png
15:25:41 1336.092896 T:3038674944 WARNING: Previous line repeats 6 times.
15:25:41 1336.093018 T:3038674944 WARNING: ReleaseTexture: Unable to release texture listselect_fo.png
15:25:41 1336.093384 T:3038674944 WARNING: ReleaseTexture: Unable to release texture separator2.png
15:25:41 1336.093628 T:3038674944 WARNING: Previous line repeats 1 times.
15:25:41 1336.093628 T:3038674944 WARNING: ReleaseTexture: Unable to release texture listselect_fo.png
15:25:41 1336.093872 T:3038674944 WARNING: ReleaseTexture: Unable to release texture separator2.png
15:25:41 1336.094849 T:3038674944 WARNING: Previous line repeats 5 times.
15:25:41 1336.094971 T:3038674944 WARNING: ReleaseTexture: Unable to release texture separator5.png
15:25:41 1336.095337 T:3038674944 WARNING: Previous line repeats 9 times.
15:25:41 1336.095459 T:3038674944 WARNING: ReleaseTexture: Unable to release texture android/btn_radio_on_holo_dark.png
15:25:41 1336.095459 T:3038674944 WARNING: Previous line repeats 1 times.
15:25:41 1336.095459 T:3038674944 WARNING: ReleaseTexture: Unable to release texture android/btn_radio_off_holo_dark.png
15:25:41 1336.095581 T:3038674944 WARNING: Previous line repeats 1 times.
15:25:41 1336.095581 T:3038674944 WARNING: ReleaseTexture: Unable to release texture android/btn_radio_on_holo_dark.png
15:25:41 1336.095703 T:3038674944 WARNING: ReleaseTexture: Unable to release texture android/btn_radio_off_holo_dark.png
15:25:41 1336.095703 T:3038674944 WARNING: ReleaseTexture: Unable to release texture separator5.png
15:25:41 1336.096802 T:3038674944 WARNING: Previous line repeats 4 times.
15:25:41 1336.096802 T:3038674944 WARNING: ReleaseTexture: Unable to release texture separator2.png
15:25:41 1336.097168 T:3038674944 WARNING: Previous line repeats 1 times.
and so on ...
All the mentioned files are in the media-folder
3. The highlight bar is a "real" bar (no transparency) on my screen. It was more "gradient" before.
before:
http://forum.kodi.tv/showthread.php?tid=...pid2186714
maybe this is related to the log-entries from 2.?
4. I can't get the "watched / unwatched" overlay to show up
there is only this in settings.xml
<setting id="Disable.UnwatchedIcon" type="bool">true</setting>
I can't find anything related to a "watched Icon"
5. Widget-Transparency:
This should be renamed to "Opacity", because when "Transparency" it is set to 100% (default), then it is NOT transparent. If it where "Opacity 100%", then it would be correct.
6. Why is the language.po file loaded about 20 times?
18:39:18 T:3038568448 WARNING: Skin has invalid include: WindowTitleCommons
18:39:18 T:3038568448 DEBUG: POParser: loaded 188 strings from file /usr/share/kodi/addons/service.openelec.settings/resources/language/German/strings.po
18:39:18 T:3038568448 DEBUG: POParser: loaded 0 strings from file /usr/share/kodi/addons/service.openelec.settings/resources/language/English/strings.po
18:39:18 T:3038568448 INFO: Loading resource://resource.uisounds.confluence/sounds.xml
could it be, that it is loaded 2x for every xml file in .kodi/userdata/addon_data/script.skinshortcuts/? I have 9 XMLs and every entry is there 18 times
8. Is there an option, that skin.shortcuts or skin.helper saves its data, so that it shows immediately after it has extracted from the DB? For me it lasts about 5-10 sec until "Similar Movies" occur. Even if the scripts (don't which is responsible) has got its data the first time.
