another issue:
1. The volume bar has a small brighter line at the bottom
Kodi Jarvis - latest github (jarvis) from today, 1 hour ago
2. Color-Selection:
Why is a asterisk (*) behind
Theme and
Unwatched Episode?
FR:
The scrollbar-indicator (the thing that gets brighter, when you select it) is hard to see sometimes. How about adding a ~2px border in theme-color around it?
I found one last unwatched episode label that requires the new variable. This is the unwatched count on the new information pop-up.
Which folder do I need to put my Fx (Us) flag in order to have it shown like others do?
(2016-01-15, 16:06)ath7 Wrote: [ -> ]Hello!
I have a few issues to report/ask.
1) In LowList (in minimal mode) view there are no genres in TV Shows list: http://i.imgur.com/CYTHPnp.png
They were here in original Aeon Nox.
2) Strange shadow in episodes list: http://i.imgur.com/n2OXFCd.png
3) If I don't want to install ExtendedInfo Script addon, when opening episode or TV Show information, this popup always appears: http://i.imgur.com/3Oe3muY.jpg
Can this popup be disabled? I have to always click the right button (No). Also the buttons Yes/No don't have labels here.
The next issue is happening only on Krypton build: take a look at the right corner: 11 %.1f (%i votes)
4) In Set My Rating dialog, the Cancel button still has an old background style, from original Aeon Nox: http://i.imgur.com/OSUMgHd.jpg
Change it to new, flat style maybe? There's also a missing text on this button
5) In Russian language, the "Working..." message is truncated: http://i.imgur.com/gJAy3FS.png
In strings.po file, the message is correct "Подождите", but the skin for whatever reason just truncates it to "Подождит"
6) When scanning library, the top line is hard to see with the current color: http://i.imgur.com/ISkY8EC.png
I hope these can be fixed.
Everything I could replicate should be fixed. Extended Info script is a requirement in the skin so you should install it.
(2016-01-15, 16:39)Solo0815 Wrote: [ -> ]another issue:
2. Color-Selection:
Why is a asterisk (*) behind Theme and Unwatched Episode?
FR:
1 is not an issue its a feature
I was playing around with it and liked it so...
2 is there to let you know that it can be overridden in certain places.
For the FR I need to think on it a bit but I won't add color there.
(2016-01-16, 02:12)Warner306 Wrote: [ -> ]I found one last unwatched episode label that requires the new variable. This is the unwatched count on the new information pop-up.
Should be fixed.
(2016-01-16, 02:34)hahaikke Wrote: [ -> ]
For any missing studios... You (or anyone else) can wrap them up in a zipfile, post the link here, and I can PR them to be added to their respective resource addon pack. I am not gonna PR only a couple of studios though so it will have to be more than that.
I checked your change to Fullscreen Wall. The overlay is the correct size but at the expense of posters with the wrong aspect ratio.
I don't understand why the item layout is set to "stretch" and the focused layout is set to "scale." I would have left both at "scale," as I thought the wall looked great as is. The fat posters are not my thing, so I changed this my own set-up.
If you think the width being stretched an unnoticeable 12 pixels is worse than missing some of the poster image... I do not know what to tell you.
If you are referring to accidentally adding stretch to the default layout then I will fix that.
(2016-01-16, 07:17)mikesilvo164 Wrote: [ -> ]If you think the width being stretched an unnoticeable 12 pixels is worse than missing some of the poster image... I do not know what to tell you.
I think the width is the same either way, just the logic used to scale the image changes. I watched a movie tonight and thought it looked off.
I'll try to explain in more detail...
With the default layout (not smaller posters) the space given to each poster is 1.5 times the width equals the height or the standard 1000x1500 movie poster size. TV Shows use a different standard so they may be slightly more off than that...
Smaller poster layout is not even with that aspect ratio so the scale tag was scaling the image to fill that 12 pixel gap cutting off some of the poster image in the process. I personally do not like the image cutoff like that especially when the posters and the text on them are so small.
Personal preference so if you like it the other way then do what works best for you
(2016-01-16, 03:41)mikesilvo164 Wrote: [ -> ] (2016-01-15, 16:39)Solo0815 Wrote: [ -> ]another issue:
2. Color-Selection:
FR:
1 is not an issue its a feature I was playing around with it and liked it so...
No ProgressBar in your skin has that brighter line at the bottom, so I thought it is a bug. The line is inconsistent btw.
for the asterisk:
Maybe explain it in the bottom-text? Or delete it, because it doesn't look good
(2016-01-16, 11:14)Solo0815 Wrote: [ -> ]No ProgressBar in your skin has that brighter line at the bottom, so I thought it is a bug. The line is inconsistent btw.
for the asterisk:
Hmmm... I guess that there is no progress bar that does the same thing but volume isn't really a normal progress bar, is it? It is not displaying the progress of volume it is a current value of how many decibels it is lowered... Unique bar, unique attribute
Maybe I will explain it in the bottom text... If I remember to get to it
Mike the text on the music widgets doesn't change to the same as the colour picker. I've got mine set to orange but it displays blue. This is on latest isengard branch.
Also what does the "Information on Focus" do for full screen movie wall?
(2016-01-16, 12:02)GTunney Wrote: [ -> ]Mike the text on the music widgets doesn't change to the same as the colour picker. I've got mine set to orange but it displays blue. This is on latest isengard branch.
Should be fixed now. Can you check please?
It is an idea from Warner306 and it takes 3 seconds of no activity to appear.
Currently looks like this:
Yup all fixed thanks.
Ah I was just being too impatient and moving before the 3 seconds.
I like the centralised info bar at the top of full screen music visualisation instead of offset to the right.
(2016-01-16, 13:00)GTunney Wrote: [ -> ]Yup all fixed thanks.
Thanks for letting me know it is fixed.
About centering the bar... I find it takes a few iterations to get things "right"... It is nice to know at least 1 other person, besides myself, likes some of the choices I make
(2016-01-16, 12:29)mikesilvo164 Wrote: [ -> ] (2016-01-16, 12:02)GTunney Wrote: [ -> ]Mike the text on the music widgets doesn't change to the same as the colour picker. I've got mine set to orange but it displays blue. This is on latest isengard branch.
Looks familiar, nice work buddy
