Hi mike,
Happy to know that your skin has been added to the translation system!
I need help to know how to change a value inside the skin, all my files are in different hard disk, and
i would like to have on the infopanel the information about the source. I have assigned different icon to
all my source and I would be very grateful if anyone would tell me which file to edit to show the icon in this
position:
image share
thank you in advance!
Hi Mike,
thank you for the skin! I have 3 questions:
1. is it possible to add the option to "show widget only when it's focused" for each widget and not only global?
2. I would like to have a special background for the youtube-addon. For the other video addons I like the fanart. But if I set this background for youtube it is in all video addons. Is it possible to set backgrounds for each addon?
3. I don't know if this a problem with the skin but maybe it is: The extended info script works great with movies. But if i click the info button for example in a video addon of a tv channel, I don't see any info. In the topbar appears "Videos/Info: ..." but nothing happens. Here is a screenshot:
thanks again!
(2016-03-12, 07:10)mikesilvo164 Wrote: [ -> ] (2016-03-07, 22:35)Solo0815 Wrote: [ -> ]@mikesilvo164:
I think I found a bug in DialogSeekbar.xml. It is the slider in the seekbar.
in line 107 and 108 there is
<textureslidernib colordiffuse="$VAR[ThemeLabelColor]">listselect_fo.png</textureslidernib>
<textureslidernibfocus colordiffuse="$VAR[ThemeLabelColor]">listselect_fo.png</textureslidernibfocus>
shouldn't that be osd_slider_nib.png or osd_slider_nibNF.png instead of listselect_fo.png?
It is osd_slider_nib.png in AeonNox, btw
Not a bug since images like that need to be changed using themes and I am getting rid of that by using images that can be colordiffused. If you have a suggestion...
Can't you change it to a transparent slider rectangle? ATM there is only a square above the progress bar. It would be better if it where a rectangle like in AeonNox. How about putting the rectangle into the progress bar like
this and not above?
Hi Mike
First of all congratulations on the fantastic modification of the skin
Can tyou help me please
I would like to request a correction of the skin in relation to the live tv
In maniac skin to change to channel does not appear the symbol of break
In your skin you have the manic functions and i use your skin because is better, I ask you if it is possible to remove the symbol from the break when channel seedlings with the up or down
Thank you very much
A Question...probably a dumb one.
If I upgrade to Jarvis from Isengaard, will I have to re-do all my poster/fanart/menus?
Hi Mike, for TV Shows I like to use the View of Episode, but using this view I don't have the option of enabling a Logo.
I also did a fresh install of everything yesterday onto my Android tablet. I noticed that on Android using Episode view, I have a logo for the TV Series in bottom right/left depending on Episode settings.
Should Episode view have a logo on screen ?
Actually, just found the cause. Artwork Downloader Season art is not selected in the Add-on configuration by default. Turned those settings on, and selected Run, then the logos came down and appeared on the Episode screens.
(2016-03-12, 04:46)mikesilvo164 Wrote: [ -> ] (2016-03-09, 16:07)flhthemi Wrote: [ -> ]What am I doing wrong?
I use Tri-Panel view for TV Shows and Movies. I do not use the option to have backdrops display (Turned off in side panel). I use Recently added movies as a widget with Poster view. When you hover over a movie cover in the widget a backdrop is supposed to display. The only one that will display for ME are the ones that have either been displayed at some point in time or I must turn on backdrops in my Movie Tri-Panel view and briefly touch on each movie one-at-a-time to make it pull in the backdrop. Once it has the backdrop, I guess cached in the thumbnail folder, then the widget will show the backdrop....so I just know I need to change something that it couldn't be a problem this wonderful skin has.
Most likely a cache thing. Kodi "caches" artwork once it has been accessed so I recommend using Texture Cache Maintenance Utility (wiki) to pre-cache it without needing to activate the fanart in the side menu.
Guess I'll just have to keep going to each install here and manually updating the backdrops when I add new media. Looked at this Utility and it looks like I would still have to make a trip to each installation here to use it...I just thought that maybe Mr.V's was supposed to do this and there might be a problem. But since it's by design I'll just man up and get it done.
Could this be the result of using MySql for the movie db?
First of all congratulations for this great skin.
I have to report something: in the LowList view the movie running times are always displayed in minutes, even if in the settings I have selected the option to display them in hour and minutes. All other views seem to work as intended, and in the movie info dialog the correct hour and minutes format is working as well, the only place where this seems to fail is the LowList view.
(2016-03-12, 17:51)effe.rnr Wrote: [ -> ]Hi Mike,
thanks again!
1) That is up to Mr. V
2) The fallback only sets up a background to use if there is nothing to display per section it is not meant to provide one for the large amount of possible addons one could have.
3)
Debug log (wiki)
(2016-03-12, 19:47)Solo0815 Wrote: [ -> ]Can't you change it to a transparent slider rectangle? ATM there is only a square above the progress bar. It would be better if it where a rectangle like in AeonNox. How about putting the rectangle into the progress bar like this and not above?
Made some changes on Git.
(2016-03-13, 03:31)Xemaniac Wrote: [ -> ]A Question...probably a dumb one.
As long as the isengard version is currently using SkinShortcuts to handle the main menu everything should work besides widgets since they are completely different and must be set up again.
(2016-03-13, 22:55)LordTywin Wrote: [ -> ]First of all congratulations for this great skin.
Will fix, thanks.
Working on an update to the info screen...
watch gallery
Thoughts?
Sorry if this has been answered but this thread is 303 pages long and it may take a long time to find an answer. Is it possible to have fanart completely disabled throughout this skin? For example, recently added episodes over my tv shows tab. Tosh.0 is my most recent one but when I hover over the particular episode the Tosh.0 fanart becomes the background. Sometimes this isn't a problem but if it's a really bright image then the text is near impossible to read.
Also on the note of recent episode, is it possible to have the show name displayed as well? It seems to only show SXXxEXX followed by the episode name. If it's a show I'm unfamiliar with then I won't be able to tell what show it is just by looking at the fanart. American Crime Story is a good example of this.
Just my requests. Having said that the skin looks great! Been using it a few weeks and I love it!
(2016-03-14, 02:48)mikesilvo164 Wrote: [ -> ]Working on an update to the info screen...
watch gallery
Thoughts?
That looks fantastic.
As an aside, and this is not a request per se, but I always liked the language/country flags that Shednox had. Does anyone know of a way where I could integrate a country flag into the info screen?
watch gallery
Thoughts?
Personally I think 7 items in that little section looks to cramped. I'd remove awards and RT rating and just have the 5.
(2016-03-14, 10:16)GTunney Wrote: [ -> ]Personally I think 7 items in that little section looks to cramped. I'd remove awards and RT rating and just have the 5.
Better or worse? I want to at least keep 6 items but not sure if I should show a little of the next page or just the first six...
Hi mike
Am not one to bitch and argue most certainly not online it's sad and pathetic.
I am not a lazy user far from it I spend hours reading and hardly post anything. I ask questions if am stuck. I was stuck my question was legit an in no way to annoy people. Yes s answer was given. A alternative it wasn't the answer I seeked. Bob did however give me the answer. I understand he may have answered it a number of time maybe I was the unlucky one but a simple check source file would have been easier.
Regardless to that I don't wanna fall out I don't know Bob first hand so it understandable I could read it in a negative manor it is text after all an I have seen s lot off negative comments from devs to users before.
I would like to apologise to Bob your self and draw a line in the sand.
Am here to learn an to enjoy kodi like everybody else.
I also appcieate everything u guys do an know it's for free. I would be the first to thank u guys
Anyway keep up the great work Both of you.
Peace
