hello, I'm on jarvis 16.1 and Extended Info Jarvis 4.6.2. I'm getting an "extended info: could not find valid content type" error when selecting a movie or show detail view in the latest Aeon Nox Silvo Mod skin from Git. I have selected the "Replace with ExtendedInfo for Movies and Shows" option in Skin Settings - Video Info. Here's the debug log:
http://xbmclogs.com/pmzpehflj
Thanks for your help.
(2016-04-27, 15:36)phil65 Wrote: [ -> ] (2016-04-27, 15:34)taylormia Wrote: [ -> ] (2016-04-27, 13:03)Jeroen Wrote: [ -> ]The error originates from the youtube add-on. Search the forums for that error message and you'll find some more info about it.
I have searched the forums for this error message and can find no posts discussing the youtube add-on. I have also updated to the latest youtube addon 5.1.20.6 with the same error. Can you expand on why you believe the error is related to the youtube addon? Thanks.
No, nothing to do with youtube. The skin is calling "openinfodialog" instead of "extendedinfo".
The above is from the extended info script developer re: the "Could not find valid content type" error mentioned in the previous post. Can someone validate or respond to this? Thanks.
Here is the post from the Extended Info script forum and below is the relevant info from the debug log:
http://forum.kodi.tv/showthread.php?tid=...pid2322025
_____________________________________________________________
15:31:18 T:3316 NOTICE: version 4.6.2 started
15:31:18 T:3316 DEBUG: script.extendedinfo: openinfodialog
15:31:18 T:3316 DEBUG: script.extendedinfo: {
"handle": null
15:31:18 T:3316 DEBUG: script.extendedinfo: openinfodialog.Count = None
15:31:18 T:3316 NOTICE: finished
15:31:18 T:3316 INFO: CPythonInvoker(13, C:\Users\user1\AppData\Roaming\Kodi\addons\script.extendedinfo-jarvis\default.py): script successfully run
_________________________________________________________________
Hi Mike..
i have anohter question for this great skin..
why we can't have Concerts as a multiple set
like we have in Movies aka Movie sets?
right now i have added thos concert for same artist in 1 folder
but they will not show up as a set
is this possible to make?
thank you! rock on...
(2016-04-27, 20:30)mikesilvo164 Wrote: [ -> ] (2016-04-27, 20:18)taylormia Wrote: [ -> ]Thanks Mike. Please let us know when the changes are uploaded to Git on Jarvis and Krypton. Will test and let you know the results.
(2016-04-27, 20:19)Magoo32 Wrote: [ -> ]Thanks for the quick fix up Mike, Fast Service
Not sure it needs testing. I am only passing ListItem.DBID to extendedinfo so it should hopefully work like it did. Should be available on Git.
Any issues please post in the skins thread.
I downloaded and copied the new version of DialogVideoInfo.xml from Git into the 1080i folder replacing the older version and restarted Kodi. Now I do not get the "Could not find valid content type" error, but the movie info detail does not show when clicking on the movie poster.
http://xbmclogs.com/pi5pdjanu
(2016-04-26, 02:25)reksp13 Wrote: [ -> ]Sorry to take so long to reply. Thank you so much! Works Great! The only thing I noticed was the missing text on the side menu:
Other than that perfect.
Should be fixed now. I was using a Krypton only language id.
(2016-04-26, 07:50)jeinnor Wrote: [ -> ]I cant seem to install this. I am running OpenELEC Beta Releases (7.0 beta 2) and tried installing both from repository and skin.aeon.nox.silvo-5.8.4-3.0.2 (Jarvis), both of them give me an error saying that it failed to install a dependency. Something before that message is the file that fails, but I cant see what it is. Please advise as I really LOVE this skin ;-)
**Edit
Okay, so I took a video so that I could see why it fails to install, not sure if this is the right place to put this, but it is a dependency that fails, namely "Recordlabel Icons - White" I tried to install it from the kodi repository as well, to no avail. Please help!
Sounds like a possible OpenELEC bug. You can install the Recordlabel Icons
manually.
(2016-04-26, 15:24)ziggy231 Wrote: [ -> ]Hi Mike, do you know when we can expect another update for Silvo, and also do you think there will ever be an option on movie sets for all discs to roll in and out of the screen like the single discs do, I use mine on Rightlist and that is perfect for disc art on single film, but when you have a movie collection/set it would be good if all discs showed at the top of the case or rolled in/out like on Shednox I think it was or Madnox
Do you think there will ever be an option for Disc Art on TV shows, I think I remember Shednox or Madnox again having this option, maybe....
Sorry to be a top pain in the Arse buddy !!!
Sorry, no fake discart. I am not a fan of it. I could add the rest of the set discs just not sure if I should roll them in succession hiding the previous ones
(2016-04-27, 16:26)Tork Wrote: [ -> ]Hi Mike..
I don't have any concerts so I am not sure what would be scraped and available for them. I don't add things that check the path for stuff like discart so it would have to be added to the Kodi library and be an available art type for that container.
(2016-04-27, 21:04)taylormia Wrote: [ -> ]I downloaded and copied the new version of DialogVideoInfo.xml from Git into the 1080i folder replacing the older version and restarted Kodi. Now I do not get the "Could not find valid content type" error, but the movie info detail does not show when clicking on the movie poster. Here's the debug log:
Not sure unless you downloaded the wrong version... Looks like you're on Jarvis so did you change from master to jarvis before downloading DialogVideoInfo?
If that is not the case try re-installing the skin instead of a single xml. I just tried it on my Jarvis test install and all seems to be working correctly.
(2016-04-27, 21:26)mikesilvo164 Wrote: [ -> ] (2016-04-27, 21:04)taylormia Wrote: [ -> ]I downloaded and copied the new version of DialogVideoInfo.xml from Git into the 1080i folder replacing the older version and restarted Kodi. Now I do not get the "Could not find valid content type" error, but the movie info detail does not show when clicking on the movie poster. Here's the debug log:
Re-installed the new Git Jarvis version and it works perfectly now. Thanks so much Mike!!
Re-installed the new Git Krypton version.
Still errors out for me on Krypton, every time I press info on a movie.
Also throws an error as soon as I put the cursor on favorites in the APPS section.
No Errors on TV Shows, but I'm not sure if it's actually adding an extra info either.
New Debug Log
I just wanted to pass by and thank you Mike for such a nice skin! Zero crashes, very fast, and clean/minimalist.
I love my TV Shows gallery setup only showing logos and a big fanart background
I have a suggestion/request:
1) Is it possible to add to Weather a "background based on weather condition" option (by installing a weather background artwork pack)?
I have a question:
2) In episodes, I use Right List (default view, no alternate). Is there a setting to not show the selected episode's rating? (it shows as a second line).
(not my image, but here is an example: first episode is selected, the "7.7..." rating is showing, I'd like to disable that so only the episode name is showing)
Amazing skin work. Great on my SPMC 16.2.1 setup. Many thanks, Mike
(2016-04-28, 10:20)Botafuco Wrote: [ -> ]I just wanted to pass by and thank you Mike for such a nice skin! Zero crashes, very fast, and clean/minimalist.
I have a question:
Where you found these mediaflag ? Thx !
Hi guys
just a quick question, is it possible, like madnox, to have trailers play where fanart is displayed, via tvtunes
I know on madnox if you install tvtunes and add the trailer file to your movie set folder then it will play the trailer in the fanart position in showcase setting....
does aeon nox silvo have this function ?
thanks
ziggy
have you scraped your concerts into your movie library? If so then you can create sets but you have to do it manually, on a concert press 'C' and then look for the option 'Manage movie set' select that and then use 'add option' to create a new Concert set, then just repeat for the other concerts you want to add to the same set.
The reason it is not there to begin with is I presume that the scraper doesn't have set info for concerts. Movie sets are either created by the scraper, if you have the setting active, or manually like above.
