(2016-05-29, 12:15)mikesilvo164 Wrote: [ -> ] (2016-05-28, 16:52)CandyLuv Wrote: [ -> ]Hi,
I'm having a problem with the widgets. There are 3 widget options, classic, panel and extended panel. The panel and extended panel are exactly the same with no additional/extended information. I'm not sure if it's something I'm doing wrong but it worked in the previous version.
I have all the scripts install.
I'm using the isengard version 5.7.4-2.1.3.
Also is there a way to make the widget panel smaller?
Thanks in advance.
Can you post a screenshot? Also, just for future reference, please read the FAQ on first page (question 8).
Yes, I did read it. I'm unable to update at this time. My main system is a raspberry pi using openelec and it's still in beta for jarvis also when trying to port my setup to it, I get a black screen and sometimes it goes into reboot loop. This didn't happen when I was using the helix skin which I have resently updated it to isengard.
As for the requested photos:
As you will also see, when one of the movies is selected the screen behind the widget is black sometimes so to show that it is selected since I have wallpapers and the widget picks up most of the screen and no show information. That is the extended option but the normal panel option shows the same things. No error messages etc comes up.
(2016-05-29, 12:24)mikesilvo164 Wrote: [ -> ] (2016-05-29, 11:39)maverick1960 Wrote: [ -> ]I maybe be sounding dumb but even after adding repo's and addons the problem stays unresolved. The problem occurred after the last update of Skin Shortcuts to 1.0.8. Before this everything was working perfectly. Suddenly the menu items disappeared even though it was appearing in skin settings. Therefore I did a clean install of Jarvis 16.1. Now as you can see without even touching skin settings the default menu items (movies, tv shows) have all disappeared. I would really appreciate some help. My debug log is http://xbmclogs.com/pkq0h85dv
This is now the 3rd time you have not posted a debug log (wiki). I suggest you read the link I have now posted to you twice. You should have also enabled skinshortcuts debugging in the scripts settings.
You really should not expect things to work properly if you only install all sorts of crappy repos and banned add-ons (wiki).
Mike, I apologize if I have offended you in any manner. I have been using this amazing skin for the past 6 months and posted many a debug log in this manner but it has never been objected to earlier. In any case your point is well taken. The problems do not surface in the main aeon nox skin as the Skin Shortcuts recreates the menu and submenu items perfectly. So I guess the problem is not with Skin Shortcuts.
I'm still going to plump for you not having any movies or tv shows in your library. Version 1.0.8 of the script fixed a bug where menu items to library nodes weren't correctly picking up the visibility condition specified by those library nodes on some platforms. This means that menu items that should have been invisible (and to places that you can't get to by going to Music or Videos first) weren't but now are. It can't really be compared to Nox 5 as that uses the script in a very different way to Nox 5: SiLVO.
Sorry guys don't know if I got an answer but can you play trailers on the aeon nox silvo
Can anyone help, quite often lately the silvo mod seems to crash and all formatting disappears, all menus go white with some menu lines missing completely
Hi There, I am new to this forum, I have been trying many many times, but still failed. Is there anybody can help solve this problem please? I am using Jarvis 16.1. with Beast build and Aeon Nox skin. I have installed some of chinese video addons, the image icons displayed correctly, the only problem that arise is, it can't display chinese character correctly. The chinese character will be display only as rectangular box with diagonal line crossing from (left bottom to right up and from left up to right bottom corner). I trying to change the Font / appearance setting but only show default. and nothing change. Please help, thank you in advance....
(2016-05-29, 15:03)flhthemi Wrote: [ -> ] (2016-05-29, 12:09)mikesilvo164 Wrote: [ -> ]That almost sounds as annoying as not getting a log of this behavior. Maybe someone will post a debug log (wiki) with skinshortcuts debugging turned on so it can be looked into but... If you do not want to lose settings STOP deleting your damn settings files! If you have an issue loading a skin first post a F'n DEBUG LOG (wiki) and second remove or delete the skin folder from the addons folder and restart Kodi.
(2016-05-27, 16:05)flhthemi Wrote: [ -> ]I think when you see the Downloading 5% the addon is deleting and then writing the data. If you just let it sit there long enough it will clear and on exit from the update the skin will restart/redraw. As I have said before low powered android devices just require patience
If you guys can easily replicate this why not post a debug log (wiki)?
It's not an issue for me, so no need for a debug. All it takes is a little waiting and all works fine. You have to expect that slower processors will take longer to do things.
I'll bare that in mind thanks
This was my first time updating via the repo as I've not had the AFTV long and my main install updates via GitHub. Not to mention it's a complete tw*t getting anything on or off the AFTV but I'll install the log add on to get them uploaded if I can make it happen on next repo update but deffo sounds like I was just being impatient.
Filthemi I'll leave it running next time it updates from repo and give it plenty of time. I'd have thought it wouldn't refresh the skin until the download had finished but guess it goes all funny when it's clearing files etc.
I'm running the Jarvis version from GutHub and I seem to have a problem with displaying custom artwork for video genres.
I defined the path in the skin settings using NFS.
Unfortunately, the genre backgrounds do not change in the movie genre view. Is this a known issue? I know this worked in the past for me.
Another problem I have is that when I play music in fullscreen mode and have enabled "Artist Slideshow" I always have my original local artist fanart blended in the foreground.
The artwork from Artist Slideshow is only showing behind. But I only want to see the artwork from Artist Slideshow here. How do I manage this?
(2016-05-29, 16:23)zenyatta80 Wrote: [ -> ]Hi,
When I click on Movie Information from inside the context menu on a Movie I get directed straight to the Extended Info dialog and not the default. This also happens after a significant lag.This is on my Android TV. On my Mac however everything works as expected (barring the disc art and the RT rating etc. - no sure if this feature is released yet). My settings for Extended Info on my Mac and Android TV are identical.
Also I notice on the main page that Extended Info script is mentioned as "required only for Isengard" but if if uninstall it and then click on Movie Info I get asked to re-install the add-on.
Much appreciate the guidance to help fix this.
Cheers!!
Sounds like you activated the "Replace with ExtendedInfo option in Skin settings > Video info... Probably not because why would you do that if you didn't want to use ExtendedInfo? Please post a
debug log (wiki).
(2016-05-29, 17:03)CandyLuv Wrote: [ -> ]Hi,
Something is wrong with your photos. The skin you are using is modified. It looks like the Jarvis Mr. V widgets are on Isengard when they should not be.
I do not support modded version of the skin.
(2016-05-29, 17:36)maverick1960 Wrote: [ -> ]Mike, I apologize if I have offended you in any manner. I have been using this amazing skin for the past 6 months and posted many a debug log in this manner but it has never been objected to earlier. In any case your point is well taken. The problems do not surface in the main aeon nox skin as the Skin Shortcuts recreates the menu and submenu items perfectly. So I guess the problem is not with Skin Shortcuts.
You didn't offend me, it is just annoying when you keep saying your posting a
debug log (wiki) when you are not. A regular Kodi log is not a
DEBUG LOG (wiki)
(2016-05-29, 22:35)irn|bru Wrote: [ -> ] (2016-05-26, 21:08)irn|bru Wrote: [ -> ]Mike and/or Mr. V:
Is there any way to change the info text in the widgets? I'm using the Next Aired add-on as my Upcoming Schedule widget for TV programs but it currently only displays the TV show name: Image 1. I know we can just highlight the show in the widget to display more details: Image 2, but I would like it to be able to display more information without having to do that: Image 3 (mock-up). Is there a setting I'm not seeing or where and what do I need to change in an xml file to make it work? If there is a solution?
Anyone
I am not going to mess with the Widgets for a bit... Mr. V appears to be taking a much deserved break so when I have more time I can look into changing things just remind me in a couple of weeks if I have not mentioned anything about it before then.
(2016-05-29, 23:05)SevenOfNine Wrote: [ -> ]Can anyone help, quite often lately the silvo mod seems to crash and all formatting disappears, all menus go white with some menu lines missing completely
Need a
debug log (wiki) since my mutant psychic powers have not been activated yet.
(2016-05-30, 11:44)Maaarv Wrote: [ -> ]Hi,
Are you manually adding it or selecting the path in Skin settings? What does it say in your
debug log (wiki)? I am not familiar with NFS or any of the file system/sharing protocols. I think wilmans2m had a similar issue with NFS stuff but I am not sure if he was able to solve them
(2016-05-31, 04:19)mikesilvo164 Wrote: [ -> ]I am not going to mess with the Widgets for a bit... Mr. V appears to be taking a much deserved break so when I have more time I can look into changing things just remind me in a couple of weeks if I have not mentioned anything about it before then.
Thanks for the reply, appreciated and understood. That said, are you able to tell me what file it is I need to edit to do it manually? I have my usual 'test' version of Kodi on the laptop so don't mind messing about with things. Thanks.
(2016-05-29, 17:36)irn|bru Wrote: [ -> ]Something is wrong with your photos. The skin you are using is modified. It looks like the Jarvis Mr. V widgets are on Isengard when they should not be.
It was download/installed/updated using the repo from this page. I have not installed jarvis on this system neither the jarvis skin. Unless you are talking about the bar and font which is the only change I made. So maybe there is a problem with the version on the repo or it got corrupted. I'm confused.
How can this be rectified?
(2015-06-26, 19:48)mikesilvo164 Wrote: [ -> ] (2015-06-26, 07:23)tinnyskillz Wrote: [ -> ]Hey mikesilvo164, i made the buffer (cached/progress) seekbar in the osd menu a bit brighter, so it's easier to see how much a video has buffered (imo it was too dark before). If you decide to try it, just drop the file from the link below into the skins media/osd folder.
http://www.filedropper.com/midtexturecache
I like it. Added and replaced old image.
How can I make it even brighter, e.g. lime color. In the 5.8.6 latest update, I find it still difficult to discern the buffer bar. The old link is empty.
(2016-05-31, 16:16)irn|bru Wrote: [ -> ]Thanks for the reply, appreciated and understood. That said, are you able to tell me what file it is I need to edit to do it manually? I have my usual 'test' version of Kodi on the laptop so don't mind messing about with things. Thanks.
The files are
here and
here but they total around 12,000 lines of code...
(2016-06-01, 01:05)CandyLuv Wrote: [ -> ]It was download/installed/updated using the repo from this page. I have not installed jarvis on this system neither the jarvis skin. Unless you are talking about the bar and font which is the only change I made. So maybe there is a problem with the version on the repo or it got corrupted. I'm confused.
You have an issue with your install. Could be a crappy repo (not mine
) you have installed or multiple skin folders but it is impossible that you installed it from my repo and it looks like that without something changed or added.
Only suggestion is to delete all the skin folders you can see then re-install. Settings are not saved in the skin folder in the addons directory. DO NOT delete anything from your
userdata (wiki) folder if you wish to keep your settings.
(2016-06-01, 01:22)Walt White Wrote: [ -> ]How can I make it even brighter, e.g. lime color. In the 5.8.6 latest update, I find it still difficult to discern the buffer bar. The old link is empty.
The image is
here and you can make a new one or add a colordiffuse to the progress control in defaults.xml. Just search for texturebg_cache.png.
[/quote]
The image is
[/quote]
I've changed the default.xml to below but still no visible buffer bar. Do I need to change the dialogseekbar as well?
<default type="progress">
<left>0</left>
<top>0</top>
<texturebg border="1">osd/texturebg_cache.png</texturebg>
<lefttexture>-</lefttexture>
<midtexture border="2">osd/midtexture.png</midtexture>
<righttexture>-</righttexture>
<overlaytexture>-</overlaytexture>
<colordiffuse>Blue</colordiffuse>
<visible>true</visible>
</default>
