hi guys am having a pain problem i finally finish my build am using kodi jarvis 16.1 with tha latest aeon nox 5 silvo the latest well all my build is working great on my pc so went i install my build on my android tv box all my background are black i notice it still detec that they are on my pc but i did change the path on the setting here userdata\addon_data\skin.aeon.nox.silvo\setting.xml and change all the background path to special://userdata\Frostbackground\tv\
still not working am using muti imagen any help please thanks
mike:
Jarvis from repo has a small bug, not displaying top250 properly
Is there a way to get the dual/double widget option in isengard skin?? I know Mr. V use to have the widget separate so to be able to merge with skin but I can no longer locate those options since it have been removed from the GitHub Page. If posible I would like to get the v2 widget files.
I believe the old widgets were better than what have been implemented in the standard isengard skin since now there is no compact option etc therefor limited.
As I said before I had upgraded from the old skin that I use with Helix which still worked in isengard but may have been better of sticking with that one.
The pic below shows exactly what I am trying to accomplish:
If any one can assist me in this I will be extremely grateful
Thank you
(2016-06-11, 19:44)CronicPain Wrote: [ -> ]hi guys am having a pain problem i finally finish my build am using kodi jarvis 16.1 with tha latest aeon nox 5 silvo the latest well all my build is working great on my pc so went i install my build on my android tv box all my background are black i notice it still detec that they are on my pc but i did change the path on the setting here userdata\addon_data\skin.aeon.nox.silvo\setting.xml and change all the background path to special://userdata\Frostbackground\tv\
I'm having the same problem. I thought it was something I did wrong on my side. Only difference is that the images sometimes shows up but it's like there is a black image as well and that is what is mostly shown and starts to act a little glitchie.
Hey mikeSILVO,
First I just wanted to saw how much I love your skin. Incredibly beautiful and lightweight to boot.
Second, I just had a question about the Myflix view option in Movies. This view serves everything I want, except that the movie covers get dimmed for some reason, taking away from the vibrancy of the view. Is there anything I can do to change that?
Cheers,
Camo
(2016-06-12, 00:46)CandyLuv Wrote: [ -> ] (2016-06-11, 19:44)CronicPain Wrote: [ -> ]hi guys am having a pain problem i finally finish my build am using kodi jarvis 16.1 with tha latest aeon nox 5 silvo the latest well all my build is working great on my pc so went i install my build on my android tv box all my background are black i notice it still detec that they are on my pc but i did change the path on the setting here userdata\addon_data\skin.aeon.nox.silvo\setting.xml and change all the background path to special://userdata\Frostbackground\tv\
yeah i know mine does not show any picture i keep looking but still no luck
(2016-06-11, 16:32)bsoriano Wrote: [ -> ]Hello Mike!
In the last week or so that I have been testing music changes in Krypton I have been using this skin exclusively. A few issues I have noticed:
1. if you select "Random Movies Fanart" or "Random video fanart" or "Random fanart" as a background for a menu item, no fanart for movies is ever shown, it is always black for a movie. By the way, thank you for adding the name in the bottom left corner, sweet detail!
2. If you select "Mixed" as a widget type, and select "Recommended Episodes" as Widget 3, you cannot navigate between episodes (pressing up or down) in that widget. The other two widgets are fine. I know perhaps this is a question for Mr. V rather than you.
And a feature request, could you add "Widget 1 fanart" and "Widget 2 fanart" as choices for the background for menu items? It is really convenient and one of the features I miss from MadNox.
As always Mike, stellar work on the skin and support, and thank you for looking into my issues/request.
Regards,
Bart
1) Do you have script.grab.fanart? All the Random arts work fine for me... Cache issue perhaps?
The fanart title is from BigNoid. I cannot take credit for it
2) I cannot replicate I can navigate the recommended in the 3rd spot. Mind posting a pic of the Widget settings so I can duplicate them exactly.
What exactly does that feature do? Does it use the widget content as the background? If you are using a smartplaylist you can select the playlist as the background option.
(2016-06-11, 19:37)Pienoet Wrote: [ -> ]Hi Mike is it possible to add PVR artwork?
I don't plan on adding that. Sorry.
(2016-06-11, 23:26)Edworld Wrote: [ -> ]mike:
Works fine here:
Something wrong with the scraped INFO
What does it show in the top right of the infodialog?
(2016-06-12, 07:09)Camo252 Wrote: [ -> ]Hey mikeSILVO,
Cheers,
Camo
Added a dimming control option. You can choose from solid black to none at all
watch gallery
(2016-06-12, 19:56)flhthemi Wrote: [ -> ]Whoopsie!
Should be fixed now.
Technically it is the fault of the addon that should not be named... It looks like a movie is marked as a TV show. That's also why the Title is in place of the TagLine
Wow thanks Mike, you work damned fast!
Hey I was wondering if there is anyway to change all the views to myflix. On my laptop I tried doing it on one add on othen when I backed out and went back in and it resets to the default view. Is this normal or do I need to do a fresh instal?
Hi MikeSilvo
If I want to keep up to date with your changes you make daily and monthy do I just download the newest version from GITHub and overwrite my version of Silvo, or will this lose all my menus and setup I currently have made ?
Please advise
Many thanks
Ziggy
Hello Guys
Just a quick question
Is it possible to automatically import Poster.Gifs when using artwork downloader rather than poster.jpg ?
I have some of the GIFs already but I have to amend these manually and place in the respective folders
Is there another way of doing these that is not so long winded ?
Any ideas
Many thanks
Ziggy
(2016-06-12, 10:43)CronicPain Wrote: [ -> ] (2016-06-12, 00:46)CandyLuv Wrote: [ -> ] (2016-06-11, 19:44)CronicPain Wrote: [ -> ]hi guys am having a pain problem i finally finish my build am using kodi jarvis 16.1 with tha latest aeon nox 5 silvo the latest well all my build is working great on my pc so went i install my build on my android tv box all my background are black i notice it still detec that they are on my pc but i did change the path on the setting here userdata\addon_data\skin.aeon.nox.silvo\setting.xml and change all the background path to special://userdata\Frostbackground\tv\
If you are using the "Backup" program to save your build, I may have a suggestion for you guys. When I used "Backup" to save my build, I used the custom directory option in the program to save my backgrounds. It works well but seems to move the backgrounds to the thumbnail folder and if you ever clear your thumbnail cache, you lose you backgrounds. To get around this I just saved my background folder on same USB as the backup and just reinstall after I do a Restore. Just save all your backgrounds and screensavers in one folder in userdata inside Kodi. Works, and not to hard to do. Hope this helps.
(2016-06-06, 17:33)Maaarv Wrote: [ -> ] (2016-05-31, 04:19)mikesilvo164 Wrote: [ -> ] (2016-05-30, 11:44)Maaarv Wrote: [ -> ]Hi,
I'm running the Jarvis version from GutHub and I seem to have a problem with displaying custom artwork for video genres.
I defined the path in the skin settings using NFS.
Unfortunately, the genre backgrounds do not change in the movie genre view. Is this a known issue? I know this worked in the past for me.
Another problem I have is that when I play music in fullscreen mode and have enabled "Artist Slideshow" I always have my original local artist fanart blended in the foreground.
The artwork from Artist Slideshow is only showing behind. But I only want to see the artwork from Artist Slideshow here. How do I manage this?
Are you manually adding it or selecting the path in Skin settings? What does it say in your debug log (wiki)? I am not familiar with NFS or any of the file system/sharing protocols. I think wilmans2m had a similar issue with NFS stuff but I am not sure if he was able to solve them
Sorry that it took so long.
Here is my latest log. http://sprunge.us/eiYU
I'm using the latest LibreELEC stable build 7.0.1 and the latest Jarvis version from GitHub.
I also tried using the LibreELEC home folder as a location for the genre backgrounds but this did not work aswell.
Can someone take a look at this please?
I already made sure that all of my images used are in jpg format.
