Hi Mike,
I was cleaning out some old files and though the code below might be of some use in your mod. I used to have an upload that replaced movie titles with logos. After looking at your skin, I noticed you don't have any of the logos I used.
I thought the positioning and sizing is already a spot, allowing you to paste the code directly into your skin and add a toggle. I clearly marked the clearlogo in each file with markers.
Shift - MyVideoNav.xml (Line 188):
Icons - MyVideoNav.xml (Line 188):
Small Icons - MyVideoNav.xml (Line 341):
InfoWall - View_51_InfoWall.xml (Line 126):
I've had a couple people ask me about adding logos since I took it down and thought of sending them to you.
The files with code are attached: https://drive.google.com/file/d/0B2LAr9I...sp=sharing.
(2015-02-01, 09:03)Mario S. Wrote: [ -> ]mike what you think of it to assign default backrounds not only the black one !!!
The idea behind it is that it is not so easy for new user to assign someone specially the default_bg !
(if you want I can send you some backgrounds)
I'm sorry Mario but I will not add any default backgrounds. I think that the personalization of things like that make Kodi such a great choice and any personal decisions for a default is way too subjective for me to pick any to include. I actually would rather deal with a large influx of users asking what is going on with my black backgrounds than have a default pack of choices.
(2015-02-01, 09:08)Warner306 Wrote: [ -> ]Hi Mike,
Thanks! I will take a look
FYI, tomorrow is a very busy day for me so while I will be able to check in on any comments or issues posted I most likely will not be able to respond till the day after... of course if I find the time I will address any issues or comments.
If anybody would like to help out in my absence, please do.
Thank you for this, if settle some things I'll try these.
Hi Mike.
Past the discomfort of last Friday and not happy, I tested the skin on the Windows machine, with clean install Kodi14.01 + (Nox 5 with Some Added Views (Helix) - (Updated January 27th) and Script, script.skin.info.service / script.extendedinfo, I installed everything from menu (Install from zip file)
Unfortunately, even on Windows OS machine. Seven, do not change anything, remains the error animation CDArt in Showcase section, I just can not understand, in Show Discart in movie information, there is animation, is in Showcase with the same movie, there is no animation Discart, honestly I have not most other ideas on how to resolve this situation.
Enclose new screenshots from Windows machine
NO Animation CDArt Showcase.
Same movie with animation cdart, in Showcase with the same movie.
Animation cdart - No CoverFlow is activated - mystery
Excuse me if I insist, but I'd love to understand why it does not work.
(2015-02-01, 17:26)gotham_x Wrote: [ -> ]Hi Mike.
Probably a silly question but you are not just toggling the no CoverFlow button right? The animation is activated when moving to the next item so just toggling the button will animate in no CoverFlow but you would have to scroll to the next item in regular showcase view.
I do not know if I understand what you mean, though, animation showcase cdart activates only when NO CoverFlow is enabled, and all movies with NO active CoverFlow have its animation showcase,
If you return a view window that is what I prefer to view of my movies, there is no animation cdart,
If you can 'serve, I noticed that if I disable and active Enable Covers, there is animation cdart,just for that movie, then there is more animation
(2015-02-01, 20:34)gotham_x Wrote: [ -> ]I do not know if I understand what you mean, though, animation showcase cdart activates only when NO CoverFlow is enabled, and all movies with NO active CoverFlow have its animation showcase,
If you can 'serve, I noticed that if I disable Enable Covers, there is animation cdart, if you return with Enable Covers active, no there is animation cdart
Try turning off no coverflow and press left or right to activate animation.
Disabilita non coverflow quindi selezionare la voce prossimo film si dovrebbe quindi vedere le animazioni
Mike, if I disable No CoverFlow and I move right left next movie, there is no animation
(2015-02-01, 20:51)gotham_x Wrote: [ -> ]Mike, if I disable No CoverFlow and I move right left next movie, there is no animation
I have no idea whats going on. It is the exact same code for the animations in both. You will have to send me a debug log since i cannot replicate this at all and since you have the animations appearing with No CoverFlow active it is something I can not diagnose. The mod settings are correct? You don't have it set to 5 seconds and are maybe not waiting the 5 seconds for the disc to appear? If you have the showcase mod active but still have the delay to off it will not work.
Enable Showcase Mod = Enable
Showcase Mod delay = OFF
For Android and Windows, I always used these settings.
(2015-02-01, 21:13)gotham_x Wrote: [ -> ]Enable Showcase Mod = Enable
I know it is confusing but you CANNOT have the delay set to off you must pick a delay option either 2, 3, 4 or 5
