(2016-10-21, 23:18)zorensen Wrote: [ -> ]EDIT 2: Tried to remove all addons, including Aeon Nox SiLVO. Installed everything again and grabbed the latest version of Skin Shortcuts from GitHub, but I'm still getting Skin Shortcuts error... I can't even activate Aeon Nox SiLVO now
Debug log (wiki)?
(2016-10-22, 00:49)horstepipe Wrote: [ -> ]Thank you very much I'll try to figure it out.
Any other hints on how to build a context menu addon?
Follow the link in my signature for the Skin Shortcuts context menu add-on - the source code is a further link away. Also
Context Item Add-ons (wiki).
(2016-10-21, 19:47)BobCratchett Wrote: [ -> ] (2016-10-21, 19:28)horstepipe Wrote: [ -> ]hey mike
is this true or did he misunderstand me?
http://forum.kodi.tv/showthread.php?tid=...pid2441090
Best regards
I suspect he misunderstood you. It's quite possible I'm about to as well, but I think you're wanting to be able to toggle an add-ons setting, but without going to the add-ons settings page. If I'm understanding right, I don't believe that's possible directly as I don't believe there's a built-in function to toggle an addons settings (unless the addon itself provides a method). Indirectly, you could write a very simple addon (even a context menu addon) to do it, as addons can toggle another addons settings with:
import xbmcaddon
xbmcaddon.Addon( "[addon.id]" ).setSetting( "[settingName]", "[value]" )
And then map a button to your new addon.
Thank you very much, I figuerd it out.
http://forum.kodi.tv/showthread.php?tid=...pid2441548
(2016-10-22, 00:49)HomerJau Wrote: [ -> ] (2016-10-21, 23:18)zorensen Wrote: [ -> ]I just updated to the latest LibreELEC version with Krypton. I have the same problem. My box is stuck on the intro... However, editing the settings.xml didn't help me I'm still stuck on the intro...
EDIT: I removed the intro.mp4 file to see what happened. I got into the main menu, but with a error message that said "Skin shortcuts error. See log for details". I'm trying to find that log, but no luck so far. Also the main menu on Aeon Nox is blank. I have no options what so ever - just the date and clock in the middle of the screen....
I have same issue with Krypton and SiLVO skin but never tried to solve it (no spare time). Just went back to Jarvis. I was hoping I'd see a fix here...
I figured it out, and finally have this awesome skin running on Krypton. I had to backup my old guisettings.xml (or delete it if you'd like). Then I installed the Aeon Nox 5: SiLVO version from the standard Kodi skin and resetted the home menu settings from the settings menu. Then everything finally worked as it should.
Be aware, this makes you set up the skin to your likings again. All settings that you previously had are deleted. After some Googleing, I learned that this error usually are some because of corrupted home menu elements settings, and that a reset should do the trick. It did the trick for me at least! Hope that this will help you guys with the similar problem. Good luck!
(2016-10-21, 19:40)BobCratchett Wrote: [ -> ] (2016-10-21, 19:19)TopperBG Wrote: [ -> ] (2016-10-21, 18:26)BobCratchett Wrote: [ -> ]I'm sorry, but as your log shows you are using banned add-ons (wiki), I can't provide any support. You need to find a forum where the add-ons you are using are supported to ask your questions, or remove all such add-ons and provide a clean debug log.
Sorry for that Didn't know....
Here is the cleaned up log
https://www.dropbox.com/s/zpvymldsvr1qpbc/kodi.log?dl=0
Thanks for taking the time to provide a clean debug log
OK, there's a few things that could be happening, looking at your log. The most likely are:-
The XMBCSwift module - which, from the log, looks to be be being used by one or more addons to import their content into the library isn't doing it's job correctly.
Emby, which you look to be using as a backend, isn't importing its media correctly into the local library.
Skin Shortcuts, which manages the main menu, isn't correctly adding visibility conditions to the menu item.
Unfortunately I'm only qualified to deal with the last one. If I could ask you to go to 'Videos' from your main menu, and tell me if you see a 'Movies' entry there, that will confirm if Kodi has library entries and if the Skin Shortcuts visibility condition is correct (it, like the Skin Shortcuts menu item shouldn't, won't show if there are no movies in your library). Just be aware that 'Videos' won't always take you to the root of the video library, so if you have a ".." entry at the start of the list, please follow it until you get to the root
If it's there, then you've most likely found a bug in Skin Shortcuts, in which case it would be appreciated if you could get me a debug log with that scripts own debug logging option enabled. System/Settings > System > Add-ons > Dependencies > Skin Shortcuts, then enable the debug logging from it's settings page and click 'OK' (otherwise the setting doesn't save).
Log isn't that clean
before Bob spends any time on this I would like to ask TopperBG to please backup your
userdata (wiki) folder and delete it from Kodi then start new with just the skin and add your sources from emby or wherever but DO NOT add any other repos other than my own if you need it. Then report if you have any issues with a
debug log (wiki).
(2016-10-21, 19:59)Nathcloud9 Wrote: [ -> ]Hi, I have updated to krypton beta 3 and latest version of silvo and live tv widget is not working on both of them as it was before beta 3 update. Also is it just me? but the scan for channel icon is greyed out and I'm having to add each one of the 100's of channel icons 1 at a time via channel manager.
You're gonna have to post a
debug log (wiki) or be more specific with what isn't working since I and another user have confirmed the widget to be working the same as it has been.
(2016-10-21, 20:13)Nathcloud9 Wrote: [ -> ]Is the repo down at the moment?
Not that I am aware of. The repo is from GitHub so if you can access that it should be working barring any bugs from Kodi itself.
(2016-10-22, 00:45)HomerJau Wrote: [ -> ]Yes I meant adding to the Kodi repo.
Would be much easier for the non-technical users to get the skin. (And this is the best/easiest skin IMO, especially for music)
It can not be added to the Kodi repo. First reason is that there are no other repos in the Kodi repository and the second is the one entry per skin rule, there is already an Aeon Nox in the repo so there cannot be another.
I agree with this rule as it avoids confusion and while I would appreciate a review of my code from those more experienced than myself it does allow me leeway to add things that might otherwise be rejected from the Kodi repo
(2016-10-22, 08:12)zorensen Wrote: [ -> ] (2016-10-22, 00:49)HomerJau Wrote: [ -> ] (2016-10-21, 23:18)zorensen Wrote: [ -> ]I just updated to the latest LibreELEC version with Krypton. I have the same problem. My box is stuck on the intro... However, editing the settings.xml didn't help me I'm still stuck on the intro...
You really should not be forced to re-setup your menu again. That is why Bob asked for a
debug log (wiki)
My thanks to you once again Sir Bob
You always seem to be around to help when my time is the most limited.
(2016-10-20, 11:58)mikeSiLVO Wrote: [ -> ]We have had a discussion about Plot/Outline previously and I said that I prefer to get a wider sample of how that is handled by other backends and locations that differ from yours before I changed it. Where does the info in PlotOutline come from? Who provides it? What does it say using WMC in the states? Why does PlotOutline show Episode Name and Year? It doesn't seem to make sense to me to do that when PlotOutline is handled differently in Kodi library. Lots of unanswered questions...
Please ask the Kodi-devs why is PlotOutline gives other info in PVR than in the library.
Edit: maybe someone answers here:
http://forum.kodi.tv/showthread.php?tid=...pid2441603
PlotOutline is in Estuary (new default skin) too and it is IMO there for a reason: It provides info that is useful in PVR. Please think about this again, even if you are not using PVR-section
(2016-10-20, 11:58)mikeSiLVO Wrote: [ -> ]I have an opinion too, which is why I said "I may do something different"
Of course, but why don't you want to make your skin's PVR section better and show info that is there (and useful). In library view there is info (first aired, added, studio, etc.) that is there and shown.
If PlotOutline is empty then is doesn't show. I can make a PR that equals the changes from AeonNox and your skin. So that you don't have to go through every single line the next time. I've rewritten the PVRInfo-dialog btw.
(2016-10-22, 08:35)mikeSiLVO Wrote: [ -> ]Log isn't that clean
There are times - when the user has made a genuine effort to provide a clean log, when they've apologised for their mistake, and (notably) when I'm keen to work out whether I've made a change to the script which has broken users systems after a few informationally lacking reports - when somehow my eye doesn't spot some of the log crud
I promise to check more carefully in the future!
(2016-10-22, 08:35)mikeSiLVO Wrote: [ -> ]My thanks to you once again Sir Bob You always seem to be around to help when my time is the most limited.
And issues with Skin Shortcuts always seem to pop up when your time is the most limited. Are you secretly keeping it working behind the scenes in your spare time?
(2016-10-22, 09:22)Solo0815 Wrote: [ -> ]Please ask the Kodi-devs why is PlotOutline gives other info in PVR than in the library.
I am not going to ask the Kodi devs anything...
Since this seems very important to you, if you PR the changes without added comments (<!-- -->) I will merge it as-is but if anybody mentions seeing the wrong info or that it is doubled with regular plot then I will revert it faster than you can say "If it ain't broke don't Solo it"
This last bit is very irritating to me cause I've spent a lot of time improving the PVR section when I don't even use the damn thing so when you come and say shit like
"why don't you want to make your skin's PVR section better" it is extremely aggravating
(2016-10-22, 09:33)BobCratchett Wrote: [ -> ]And issues with Skin Shortcuts always seem to pop up when your time is the most limited. Are you secretly keeping it working behind the scenes in your spare time?
Ummmm... I am going to follow Winston Zedmore's advice...
If someone asks if you're a God you say YES!
Sorry mike
I know you spend hours/days improving the skin, not just the PVR section and and I didn't want to annoy you
I love your and BigNoid's work and want to make the skins experience even better in PVR, which you and BigNoid aren't using.
I'm on further training the next week and not at home. I'll do a PR, when I'm back home.
Another question:
What editor are you using to edit the skin's XMLs? I'm using Kate (from KDE) and I can hide groups so that only the <control="group"> line is there. For that reason I'm adding the comments. So that I can easily see, what group it is.
If you don't want it, then I'll remove it.
(2016-10-22, 09:53)Solo0815 Wrote: [ -> ]Sorry mike I know you spend hours/days improving the skin, not just the PVR section and and I didn't want to annoy you
Another question:
Solo0815, I consider you a friend. An online friend but regardless of that my foul language used at times is never a sign that I will hold a grudge or anything
I use SublimeText 3 and phil65s wonderful, amazing, fantastic, did I say wonderful, KodiDevKit. I recommend the combo to all who can deal with a slight learning curve.
I am a control freak, I admit it. The reason for the comment removals is because I do not like seeing them and have even removed or changed existing ones from others and myself. I only mentioned it because I was perturbed and drunk Mike + annoyed = Grumpy Mike
Guess i will try again and hope for some help. Some icons seem to be gone on my install.
Top right is supposed to be the mute icon but it is just a black block:
http://imgur.com/HkfaLhZ
Debug:
http://pastebin.com/4apvGQDV
Edit: seems to work now magically.
I also got a problem with tv widget. Mainly showing tv-shows in progress. Most of the other seems to work. No matter what panel/list/compact I select for In Progress TV-Shows, it wont show anything.
Debug:
http://pastebin.com/sW3iKwEX
Hi again, can someone please answer my questions? I have now looked inside the skin zip file and there is no live tv widget (only system info). What happened to it please as it looked great. Also why is scan for missing icons greyed out on live tv?
thanks Nath
@mikesilvo: In regards to my showcase weird behaviour, it was fixed by the addon update! Many thanks for that tip! But the disc issue persisted. Funny thing is, I've been able to figure a pattern to what's going on. It was all due to my moviesets, but since I had issues with them in madnox as well, I realised there was something amiss on my end, probably with the database. So a complete reinstall did the trick. I'm reintegrating my films into the library, starting off with the sets, and so far, all is good.
Sorry if it's asked already but can't find it - How can I move settings like menu structure, submenus, widgets, addons shortcuts to another Kodi installation?
Tried already but can't copy all of the things in menu:
1. copy /userdata/addon_data/skin.aeon.nox.silvo/settings.xml
2. copy /userdata/guisettings.xml
3. copy all /addon/skin.aeon.nox.silvo ?
