(2016-11-08, 19:43)avika Wrote: [ -> ]hello. i have searched high and low for a solution to an issue i'm having with Silvo skin for Jarvis 16.1.
I am unable to utilize the Manage Submenu function because the Skin Shortcuts control seems to be missing.
It's the one that has options for TYPE/ADD/DELETE/MOVE UP/MOVE DOWN, etc.
Instead, I get a screen that says CHOOSE ITEM FOR MENU with options that include COMMON/VIDEO LIBRARY/MUSIC LIBRARY, etc.
I downloaded from three different sources and all are the same, even after completely deleting kodi and starting anew.
I went so far as to replace the script in userdata/addon_data/script.skinshourtcuts - to no avail.
Please let me know if you can help. Thank you so much.
If you are looking for additional options then they have been moved to the context menu:
If you have keyboard press "C", if you have remote use a mapped button, and if you have a very small remote with limited buttons or do not want to map one then hold down (long press) the select button.
Oh my goodness -so it was there all along? I was pulling my hair out thinking I had downloaded corrupt file(s). Thank you so much for your response. You really made my day!
[/quote]
Hello Mike. I am unable to bring up the context menu when pressing C on the keyboard as you suggested. As a side note, I'm familiar with Kodi and have created a few of my own personal builds using other skins. Anyway, for some reason the methods suggested are not working in that particular section of the skin. For example, when I navigate elsewhere I am able to bring up the context menu when pressing C. I am doing this from my MacBook Pro using Jarvis 16.1 I'm having the same experience while testing on Wetek Core. if you will be so kind to look into this for me it will be greatly appreciated. Otherwise, I can use the default method no problem. Minor issue here. Thanks again.
(2016-11-09, 00:58)fogotten Wrote: [ -> ]Hey. Recently switched to this skin and I love it. Best one I've come across. There is just one think I would like to tweak. I use Trakt Progess in Specto as a widget. When I select a file lets say, "The Walking Dead S02e3." It takes me to a folder with The Walking Dead eps 3-whatever. I have autoplay setup so I would prefer when I click on the widget it plays the file rather than goes to the file Walking Dead S02 directory. Can anyone here help me with this? Or is that more of a Specto issue?
I do have a sent issues but with me you would send me to my playlist
Sent from my iPhone
(2016-10-10, 01:18)horstepipe Wrote: [ -> ] (2016-10-09, 22:22)mikeSiLVO Wrote: [ -> ] (2016-10-09, 21:48)horstepipe Wrote: [ -> ]I'm not sure wheter this mistranslation to German is by the skin or by Kodi itself, but in movie information view the word "Auszeinchnungen" should be "Auszeichnungen" and "Revenue" is still English and should be "Einnahmen"
edit: and "Audio" should be "Ton"
Regards
Some translations come from Kodi while others come from the skin and both use Transifex... Now that you mention it there has not been an update from Transifex in awhile. I have to try and remember to ask about that in the skinning section.
If there are issues with translations then you can request to be added to the German team and update or add any missing ones.
nice, request sent.
still no answer, guess I won't get an invite anymore.
You know what this little "flash" is ? It appears for a moment then disappears.
HI
I am rookie in using this screen and unable to understand how to activate HD/SD/3D/ Bluray indicators with the fanart as mentioned in the above post in the bottom of screen. In the view list on the left hand side on the screen i had selected almost all options including the big list setting with HD/SD/3D indicators as ON but still while browsing the list of movies the HD/SD/3D/Blueray indicators for the movie title cant be visible. is there is any other way or add that can activate the same.
one more query in the above skin although the video player is good as it cant hide the whole screen the only drawback i found is the pause sign that appears in the middle of the screen when pause which is really annoying, any solution to hide this or may be change of the default video player .
Thanks in advance for guidance.
Hi
Love this skin...
Though i have a problem..
I have separated series in adult and kids playlists..
Problem is that when i use Live background with series playlist it gets no case on it..
What to do??
Hey guys, running the skin on krypton beta 5 and "just" have one issue, which i dont know if it is skin related.
I have two user profiles and default is to show the login page.
Very often after ill select a user to logon, the screen is just black!
I have made a log, and compared it to an "good" start of kodi.
The difference is:
18:38:46 T:5772 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('result',)
File "C:\Users\popy\AppData\Roaming\Kodi\addons\service.library.data.provider\service.py", line 188, in <module>
Main()
File "C:\Users\popy\AppData\Roaming\Kodi\addons\service.library.data.provider\service.py", line 59, in __init__
self._fetch_favourite()
File "C:\Users\popy\AppData\Roaming\Kodi\addons\service.library.data.provider\service.py", line 91, in _fetch_favourite
LIBRARY._fetch_favourite_episodes()
File "C:\Users\popy\AppData\Roaming\Kodi\addons\service.library.data.provider\library.py", line 341, in _fetch_favourite_episodes
return self._fetch_items(useCache, prefix="favouriteepisodes", queryFunc=query_favourite)
File "C:\Users\popy\AppData\Roaming\Kodi\addons\service.library.data.provider\library.py", line 72, in _fetch_items
rv = queryFunc() # Must return a unicode string (json-encoded data)
File "C:\Users\popy\AppData\Roaming\Kodi\addons\service.library.data.provider\library.py", line 309, in query_favourite
if favs['result']['favourites'] is None:
KeyError: ('result',)
This exception is not visible in the good log.
The logs could be downloaded here:
bad log:
http://pastebin.com/XbfVvFNu
good log:
http://pastebin.com/mwLixzy0
Any hints, what could be the culprit?
Maybe it has todo with any widget or main menu entry -> i can read "favouriteepisodes" in the exception?
Any hints if this got used by the skin?
thx
pOpY
(2016-11-14, 20:09)popy Wrote: [ -> ]Hey guys, running the skin on krypton beta 5 and "just" have one issue, which i dont know if it is skin related.
The difference is:
Main()
bad log: http://pastebin.com/XbfVvFNu
good log: http://pastebin.com/mwLixzy0
thx
pOpY
Have made some tests and it seems it has nothing todo with this exception!
Have tested 10 times and 8 times it freezes on login.
After changing skin to Esturay the issue went away.
Please can anybody guide me in the right direction what could be the issue that login with aeon nox silvio freezes?
Here is a debug log of another freeze on logon:
http://pastebin.com/CMCJBDy5
thx
pOpY
I have a problem with all posters not showing. I have asked in the KODI forum but no one answer.
I have all my media at an FTP and i have every movie in separate folder with nfo, fanart an poster.
Example:
Folder: 101 Dalamtiner
Files in folder:
101 Dalamtiner.avi
101 Dalamtiner.nfo
Text in the nfo:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<movie>
<title>101 Dalmatiner</title>
<runtime>99</runtime>
</movie>
I am using the skin Aeon Nox Silvo.
I dont get all posters to show, i guess they have the wrong aspect example 350 x 491.
I have changed all
to
stretch</aspectratio>
as i read in another thread. First i just changed it in View_57_Shift.xml file (i use Shift Small) but nothing happens so i changed all the xml files in the skin.aeon.nox.silvo folder but nothing happens,
Am i doing something wrong? I have tried to remove the textures13.db, clean the library och delete and add the source again.
(2016-11-11, 19:15)Alyy Wrote: [ -> ]Hi,
its power low.. on a raspberry pi
(2016-11-15, 00:45)Warez Wrote: [ -> ] (2016-11-11, 19:15)Alyy Wrote: [ -> ]Hi,
I'm plugged into the mains. How it can be weak ?
Regards.
(2016-11-15, 19:41)Alyy Wrote: [ -> ] (2016-11-15, 00:45)Warez Wrote: [ -> ] (2016-11-11, 19:15)Alyy Wrote: [ -> ]Hi,
Regards.
This has nothing to do with the skin. Depending on which Pi your using the power brick needs to be between 1.8 to 2.5 amps. That symbol is showing that its not receiving enough power. So get a new adapter that's 2.5 amps and you'll be fine. Alternatively you can edit the config.txt file as follows and it will remove the symbol but to be honest you should just get a new brick.:
avoid_warnings=1 removes the warning overlay.
avoid_warnings=2 additionally allows turbo when low-voltage is present.
(2016-11-10, 05:04)avika Wrote: [ -> ]Hello Mike. I am unable to bring up the context menu when pressing C on the keyboard as you suggested. As a side note, I'm familiar with Kodi and have created a few of my own personal builds using other skins. Anyway, for some reason the methods suggested are not working in that particular section of the skin. For example, when I navigate elsewhere I am able to bring up the context menu when pressing C. I am doing this from my MacBook Pro using Jarvis 16.1 I'm having the same experience while testing on Wetek Core. if you will be so kind to look into this for me it will be greatly appreciated. Otherwise, I can use the default method no problem. Minor issue here. Thanks again.
I think there was an issue with Super Favorites blocking the context menu and there was a workaround added to Skin Shortcuts but had to be removed due to repo rules. I recommend posting a
debug log (wiki) and perhaps check with the Super Favorite author.
(2016-11-11, 15:49)horstepipe Wrote: [ -> ]still no answer, guess I won't get an invite anymore.
They might not need anymore German translators ATM. It is a moot point currently as there has not been an update from the translation system since July 25th. Likely a fix is needed and the one person who volunteers to handle that is probably busy with real life.
(2016-11-12, 14:09)masifh Wrote: [ -> ]HI
Not sure what you mean so please post a pic. All items need to be added o your library and be in a format where the details can be read by FFMPEG and displayed in Kodi.
Adding video sources (wiki)
(2016-11-13, 12:13)XenoBIT78 Wrote: [ -> ]Hi Love this skin...
What to do??
Do you mean TV Shows do not show a BluRay case? TV Show shouldn't show a case. Need more info like what the playlist rules are..
(2016-11-14, 22:53)popy Wrote: [ -> ] (2016-11-14, 20:09)popy Wrote: [ -> ]Hey guys, running the skin on krypton beta 5 and "just" have one issue, which i dont know if it is skin related.
The difference is:
Main()
thx
pOpY
Here is a debug log of another freeze on logon: http://pastebin.com/CMCJBDy5
thx
pOpY
I don't see any freezes but the skin never loads so perhaps it is an issue with your install maybe try to re-install the skin. There is also some weirdness with profiles so you might want to check with Kodi support for your platform.
(2016-11-15, 00:40)sabelstrom Wrote: [ -> ]I have a problem with all posters not showing. I have asked in the KODI forum but no one answer.
Example:
Files in folder:
101 Dalamtiner.avi
101 Dalamtiner.nfo
Text in the nfo:
<movie>
</movie>
I have changed all
to
Do the posters show in other skins? If not then have you added them correctly to your library? Don't the images need to be in your
NFO files (wiki)?
I do not see a link to them in your NFO example.
(2016-11-16, 17:41)mikeSiLVO Wrote: [ -> ] (2016-11-10, 05:04)avika Wrote: [ -> ]Hello Mike. I am unable to bring up the context menu when pressing C on the keyboard as you suggested. As a side note, I'm familiar with Kodi and have created a few of my own personal builds using other skins. Anyway, for some reason the methods suggested are not working in that particular section of the skin. For example, when I navigate elsewhere I am able to bring up the context menu when pressing C. I am doing this from my MacBook Pro using Jarvis 16.1 I'm having the same experience while testing on Wetek Core. if you will be so kind to look into this for me it will be greatly appreciated. Otherwise, I can use the default method no problem. Minor issue here. Thanks again.
I think there was an issue with Super Favorites blocking the context menu and there was a workaround added to Skin Shortcuts but had to be removed due to repo rules. I recommend posting a debug log (wiki) and perhaps check with the Super Favorite author.
I genuinely might be mis-remembering, and I'm not in a position to go back and check the code right at this moment, but didn't I only add the context menu to Skin Shortcuts when using Krypton, and not Jarvis or earlier...?
Super Favourites didn't/doesn't exactly block the context menu - when it's global context menu is active, pressing the context menu key will close Skin Shortcuts and display it's context menu instead.
(2016-11-16, 17:51)BobCratchett Wrote: [ -> ]I genuinely might be mis-remembering, and I'm not in a position to go back and check the code right at this moment, but didn't I only add the context menu to Skin Shortcuts when using Krypton, and not Jarvis or earlier...?
Ummm... Duh. Yep I missed that they were using Jarvis. The quoted was about missing the options and I only removed them for the Krypton version
