(2016-11-16, 17:41)mikeSiLVO Wrote: [ -> ] (2016-11-15, 00:40)sabelstrom Wrote: [ -> ]I have a problem with all posters not showing. I have asked in the KODI forum but no one answer.
I have all my media at an FTP and i have every movie in separate folder with nfo, fanart an poster.
Example:
Folder: 101 Dalamtiner
Files in folder:
101 Dalamtiner.avi
101 Dalamtiner.nfo
Text in the nfo:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<movie>
<title>101 Dalmatiner</title>
<runtime>99</runtime>
</movie>
I am using the skin Aeon Nox Silvo.
I dont get all posters to show, i guess they have the wrong aspect example 350 x 491.
I have changed all
to
stretch</aspectratio>
as i read in another thread. First i just changed it in View_57_Shift.xml file (i use Shift Small) but nothing happens so i changed all the xml files in the skin.aeon.nox.silvo folder but nothing happens,
Am i doing something wrong? I have tried to remove the textures13.db, clean the library och delete and add the source again.
Do the posters show in other skins? If not then have you added them correctly to your library? Don't the images need to be in your NFO files (wiki)?
I do not see a link to them in your NFO example.
No the images dose not need to be in the nfo. It works on 90% of all my movies, most of them have download the poster via Media Center Master, and most of them are 1000x1500 in size, but those that didnt have any posters i scanned some of my own or used google or took a frame from the movie and used as poster. But they are not 1000x1500 or near the aspect ratio 2:3.
And i dont know how to tell the nfo to look for poster in the same folder as the movie. I have only found out how to tell the nfo what folder to search in and what the posters name is, good to use when you have all posters in the same folder.
Some exampel: 1146x1610, 350x491, 374x528, 347x495, 362x515.
Found out what was wrong. All posters i have made had a capital "P" so it couldn't auto scrap.
i'm not really sure if i'm not searching right or if no one had this question before:
there is an option in titan skin to always show labels on thumbnail/icon view.
on silver i couldn't find it. it's not in the slide-out menu nor the skin settings. i'm seeing the labels sometimes, with some plugins, but not with others. for example if i set icon view on youtube, i'll see the labels overlay on every item. if i set the icon view in spotify addon, then i don't get the overlays. it's the same for most of the addons. and i'd like to be able to always show labels on icon view.
is that possible somehow? i am able to edit code if necessary, but i can't understand it in depth.
(2016-11-16, 01:10)jwrv Wrote: [ -> ] (2016-11-15, 19:41)Alyy Wrote: [ -> ] (2016-11-15, 00:45)Warez Wrote: [ -> ]its power low.. on a raspberry pi
I'm plugged into the mains. How it can be weak ?
Regards.
This has nothing to do with the skin. Depending on which Pi your using the power brick needs to be between 1.8 to 2.5 amps. That symbol is showing that its not receiving enough power. So get a new adapter that's 2.5 amps and you'll be fine. Alternatively you can edit the config.txt file as follows and it will remove the symbol but to be honest you should just get a new brick.:
avoid_warnings=1 removes the warning overlay.
avoid_warnings=2 additionally allows turbo when low-voltage is present.
My power supply is good, 2A/5V. This symbol is displayed only 2, 3 seconds
I just wanted to know what it was, even though I do not understand why it appeared.
Do you know it is actually producing 2 amps? It might be getting maxed out and can't keep up for the brief time the icon appears. So maybe a 2.5 amp supply would be the solve
It sure wouldn't hurt to try one and see.
Hi!
Thank you very much for all the hard work on this skin. It is the best.
I have only one question if you could answer me. What is the function of the "Show Live TV widget" option, in movies for example?
I searched the tread and i couldn't find any explanation.
(2016-11-16, 17:54)mikeSiLVO Wrote: [ -> ] (2016-11-16, 17:51)BobCratchett Wrote: [ -> ]I genuinely might be mis-remembering, and I'm not in a position to go back and check the code right at this moment, but didn't I only add the context menu to Skin Shortcuts when using Krypton, and not Jarvis or earlier...?
Super Favourites didn't/doesn't exactly block the context menu - when it's global context menu is active, pressing the context menu key will close Skin Shortcuts and display it's context menu instead.
Ummm... Duh. Yep I missed that they were using Jarvis. The quoted was about missing the options and I only removed them for the Krypton version
Not a problem guys. I've grown accustomed to the existing workflow and it works like a charm. Really appreciate reading all your responses on this! Thank you so much.
This is a great skin.
Been searching the forums for an answer about the video OSD.
I really like the video OSD that is used in the aeon nox skin for plex home theatre. Is there a way to use it in Kodi?
(2016-11-18, 02:32)flhthemi Wrote: [ -> ]Do you know it is actually producing 2 amps? It might be getting maxed out and can't keep up for the brief time the icon appears. So maybe a 2.5 amp supply would be the solve It sure wouldn't hurt to try one and see.
It's been almost 2 years since I have this diet and it is only recently that it happens.
Maybe I should change it ?! Thx !
Sorry to re-post... but does anyone have an idea how to resolve?
(2016-11-08, 16:57)mikeSiLVO Wrote: [ -> ] (2016-11-07, 14:21)hernandito Wrote: [ -> ]Hi,
In Wall View and Shift View, I want to disable fanart display on the background. I want a single image to be used as the backdrop. I can set this withe the Background option. But when I go to Shift view, and I enable Info w/ fanart, I get plain background displayed in the fanart portion.
I simply want to hard-code the image in lieu of the fanart for the background only.
Which xml file renders the fanart background for these views. I already tried MyVideoNav.xml, and View_503_Wall without any succes.
Any guidance is greatly appreciated.
Many thanks,
H.
Not sure what you are asking about, pics would help. The backgrounds are in the CommonBackground include in Includes_Backgrounds.xml
Thanks Mike... Please let me clarify with image samples.
When browsing all my movies in
Wall View, I prefer to have a plain background without the fanart background like this:
When I browse my Recent Movies, I want to use the Shift View or MyFlix View. With the fanart disabled, This is what I get in that view.
The way I was hoping to "resolve" this was to disable the use of fanart in the Wall View by editing the correct xml file and having that point directly to my plain background image (eliminating code that says to display the fanart). For TV Shows, I use the BannerWall View, and there I also want to display a plain background as well.
I have tried looking and editing code in various files, including IncludesBackgroundBuilding.xml and have not been able to isolate the section that renders the fanart background in these views.
Any pointers would be awesome. Thank you so very much.
PS. Is there a way I can set the widgets to update every time I enter the Home Screen? I believe the old Shednox had that option. It seems like quite often, my recent widgets do not update when new media has been added to the library.
Thanks,
H.
I just installed the Jarvis Skin. Not sure if I'm just not seeing it. But is there still an option to add an intro video?
Skin helper update ruins the sub menu creation. Anyone else has this issue?
(2016-11-20, 03:19)x007sunny Wrote: [ -> ]Skin helper update ruins the sub menu creation. Anyone else has this issue?
I've had one other report that the recent update to Skin Shortcuts ruins the same, but as I can't reproduce it and no-one has provided a
debug log (wiki) yet...
Edit: Someone once offered to write me a 'debug log' song (a funny and cheeky song to be used in an almost 'rick-rolling' way), due to the amount of them that I seem to request. I never got back to that person, and - with the amount that I seem to have requested recently - I sincerely regret that. So if you are that individual or have any musical/YouTube talent, please do hit me up
Only happens when you try to edit the sub menu you already have.
(2016-11-20, 04:09)x007sunny Wrote: [ -> ]Only happens when you try to edit the sub menu you already have.
I'm quite sure it does, but I'm still not able to reproduce this and it still won't get fixed until someone provides a
debug log (wiki).
It really does not take too much effort to contribute... x007sunny instead of trying to downgrade why not just post a
debug log (wiki) so the problem can be fixed? Unless the problem is you use those banned add-ons and repos this community warns against using cause it messes yo shit up!
Please just post a
debug log (wiki).
