Hi All
Hope you can help me , I am using a build that is using Aeon Nox 5: SiLVO (the build is KodiNoLimits) everything is fine I was able to customize pretty much everything but the views , I can set them up for example using MyFlix and everytime I get out or changed page it goes back to default view, Any suggestions how I can make the changes permanent ??
tks for your help in advance
I use Aeon nox skin on kodi 17. I take a category in an addon and bring it out the main screen. When I run it and when I press return to get out. It always come back to the main addon then I have to press another return to go to the main kodi screen.
This is not the case in kodi 16.1
Anyone knows what is the problem and how to fix it?
(2017-02-26, 04:45)shaktoo Wrote: [ -> ]@ rosario try the latest Krypton nightly & re enable skin, it will download another dependency addon which should enable you to them & colors.
Mike the latest Git update seems to have broken the videolyrics again ?
Also manfeed has added new animation for his videolyrics.
Thanks Shaktoo...doing it right now.
(2017-02-26, 13:37)craigey1 Wrote: [ -> ] (2017-02-26, 13:02)natcatmj420 Wrote: [ -> ]hI, just made an account because I'm new to creating builds for kodi, I downloaded aeon nox 5 silvo and worked customized a build, just finished it today and created a backup. However when I tried to restore the backup to firestick, it just shows the old version of the aeon nox build I had previously, I don't know what I am doing wrong, please help
Can you say what folders you backed up? You've probably missed something.
well I customized aeon nox silvo with my pc using kodi 17 and I backed it up the same method I usually use with regular aeon nox, I'm not sure if I was supposed to save it a different way but this is what I did: using adblink I did a back up and saved it on a folder to my desktop, then with this folder I did a restore to my firestick, but it showed the build I had before I downloaded aeon nox mod . when I turn kodi on my pc, aeon nox silvo build works great, but I don't know how to save it properly because when I go to c:/user/appdata/roaming/kodi/addons I only see the folder for aeon nox, but not aeon nox silvo. could this is because I didn't start from scratch? I downloaded the aeon nox silvo while. still using my aeon nox build, so everything including my apps and repositories deleted, but my sources in file manager remained intact. thank you for your fast reply!! this whole thing is stressing me out so I really appreciate it!
(2017-02-26, 23:47)natcatmj420 Wrote: [ -> ]well I customized aeon nox silvo with my pc using kodi 17 and I backed it up the same method I usually use with regular aeon nox, I'm not sure if I was supposed to save it a different way but this is what I did: using adblink I did a back up and saved it on a folder to my desktop, then with this folder I did a restore to my firestick, but it showed the build I had before I downloaded aeon nox mod . when I turn kodi on my pc, aeon nox silvo build works great, but I don't know how to save it properly because when I go to c:/user/appdata/roaming/kodi/addons I only see the folder for aeon nox, but not aeon nox silvo. could this is because I didn't start from scratch? I downloaded the aeon nox silvo while. still using my aeon nox build, so everything including my apps and repositories deleted, but my sources in file manager remained intact. thank you for your fast reply!! this whole thing is stressing me out so I really appreciate it!
I've not used Adblink before, but you'll definitely need to have copied the "skin.aeon.nox.silvo" folder to the new build as well as some of the other script / service folders etc. You'll also need to copy the relevant folders under userdata/addon_data/ - You could try manually copying them over.
(2017-02-26, 21:18)rosario04 Wrote: [ -> ] (2017-02-26, 04:45)shaktoo Wrote: [ -> ]@ rosario try the latest Krypton nightly & re enable skin, it will download another dependency addon which should enable you to them & colors.
Updated kodi to todays nightly 20170226-07ae746 and no change. Not allowing me to customize skin colors. Any help greatly appreciated. Thanks
Having issues with recording of iive TV -- when I hit the 'record' button from anywhere (for example the guide), a partial and transparent window pops up (looks like 4 rows of the timer popup maybe). No buttons or anything else. The recoding does however seem to start.
I am using Krypton and 6.0.3 Silvo. Also using MediaPortal PVR if that has an impact.
tried to find in posts but could not and didn't see in GitHub as an issue or recently fixed issue. Tried latest from GitHub also and it is still there.
Cheers, Tony.
I think I know whats happened. Since Master has become Leia , hence I am pulling that which is why Kodi 17 is disabling the skin.
I have tried git pull from the tree/krypton but it dosen't work! There must be a way . Could someone help ?
rosario I am unfortunately having issues of my own. As soon as I am able to run ANS again i shall try & reproduce your issue to see whats happening.
(2017-02-25, 10:43)kowalmisiek Wrote: [ -> ]Hello mikeSiLVO
The icons for all applications are stretched. Should be square.
How to edit the file to change the size of icons youtube?
How do your skin a view as:
6.0.3 (Krypton) view disc image?
Your images show square and if you do not want square then chose something else under art when enabling the widget.
(2017-02-25, 22:36)9800pro Wrote: [ -> ]Question regarding Fanart when listening to the music.
I just want to have only one predefined image instead of Fanart when song is playing in full screen.
Tried searching but nothing i find works.
I installed Artist Slideshow, tried every option in it but background is always black.
Only thing that shows anything is CD Wall and Blurred album thumb.
How can i set only one image as default music full screen image?
Thx
This is a unique request and I do not understand wanting to display a specific fanart for all music. If the image is black then make sure your library has been tagged properly including a musicbrainz ID. If you have a properly tagged library and you still have a black screen then seek support in the artist slideshow thread.
(2017-02-24, 09:58)Alyy Wrote: [ -> ]To illustrate in image with addon Catch-up. You can not do anything ?
I do not use that add-on but if they display a landscape image then they should not be setting the content to Movie or TV Show which if using the latest from Git must be the case otherwise the image aspect ratio would be correctly kept
(2017-02-26, 16:54)OptimusGREEN Wrote: [ -> ]Hi Mike,
I have a feature request.
I think it would be quite useful to have some kind of indicator that there is a widget available for the section if the 'hide widgets if not focussed' feature is on.
I don't know if this could be a small tab extending from the main bar or something.
My mrs would definitely find it useful lol
Not a bad idea, will look into implementing something...
(2017-02-26, 20:35)curtqn Wrote: [ -> ]I use Aeon nox skin on kodi 17. I take a category in an addon and bring it out the main screen. When I run it and when I press return to get out. It always come back to the main addon then I have to press another return to go to the main kodi screen.
Whats the story, are you using this skin or default Aeon Nox 5? Posting multiple threads isn't gonna help with a proper response...
(2017-02-27, 01:51)rosario04 Wrote: [ -> ]Updated kodi to todays nightly 20170226-07ae746 and no change. Not allowing me to customize skin colors. Any help greatly appreciated. Thanks
Do not need nightly. Check that skin.helper is not disabled on your system... Not an easy way to do that so I suggest deleting all skin.helper folders in the addon folder, restarting Kodi, then re-installing using the supported add-ons section in Skin settings > Help. You likely installed manually and the item is disabled.
(2017-02-27, 04:40)twiseva Wrote: [ -> ]Having issues with recording of iive TV -- when I hit the 'record' button from anywhere (for example the guide), a partial and transparent window pops up (looks like 4 rows of the timer popup maybe). No buttons or anything else. The recoding does however seem to start.
Cheers, Tony.
I do not have PVR to test so I will need a
debug log (wiki) and pics to show me the issue.
(2017-02-27, 05:52)shaktoo Wrote: [ -> ]I think I know whats happened. Since Master has become Leia , hence I am pulling that which is why Kodi 17 is disabling the skin.
No idea what the problem is on your system so I say just delete all and install from zip the correct branch using the info in the skin FAQ when installing the GitHub version.
Way too many posts in this thread about "Builds"... Stop it!!!
If you want to make a "Build" go somewhere else, you are not wanted here!
I DO NOT WANT ANYONE MAKING A "BUILD" WITH THIS SKIN!
Seriously...
Why the hell do any of you
banned addon (wiki), build making, what-u-ma-call-it users want to run this skin? All I see is shitty YouTube videos where everyone is using the List view. There is a list view in EVERY other skin in existence!
Why use this one? I don't get it...
None of those stupid videos you are watching will teach you how to skin properly or how to use skin shortcuts. When you say "I edited script-skinshortcuts-includes.xml" and it was overwritten, you seriously have no idea what you are doing or talking about so... Why bother?
I can honestly say that all those "build" posters who have a donation page that make money from this piss me off to no end.
Slapping a coat of paint on a house and claiming you built it makes you a liar...
The secret to skinning is very simple. Stop being lazy and take the time to learn. I have been doing this for a couple of years and I still have many things to learn, also try giving a shit about what your providing even when you aren't paid! That is called work ethic.
Had to think about this... If you are doing a pull but have not changed the branch then you will still be stuck on master. Can't help any more without pics of what Git software you are using.
On win 10 you can use Windows Key + Prt Scrn and it will appear in your USERNAME\Pictures\Screenshots folder.
Is there a way to use season-fanart in the episode view from a TV show?
(2017-02-27, 08:44)mikeSiLVO Wrote: [ -> ]Seriously...
Why the hell do any of you banned addon (wiki), build making, what-u-ma-call-it users want to run this skin? All I see is shitty YouTube videos where everyone is using the List view. There is a list view in EVERY other skin in existence!
Oh, I agree soooooooooooooooooo much with this Mike, sick of seeing a youtube video with some muppet thanking someone who has built a shitty build and using Madnox and hearing the muppet saying that so and so has done an amazing job with the skin, really? what did he do exactly other than take all my hard work and put it in a shitty build.
I'm seeing more and more posts from people with either shitty builds or banned add-ons and am getting real tired of it, to the point where I could quite easily just say "F**k it" and walk away.
I did love what I spent MY FREE TIME doing when skinning, but not much right now!
