Hey is anyone else having issues with in the settings and customizer being able to open up the color picker tool so the menue bar and system bar colors can be changed?
Sent from my LG-H918
(2017-03-10, 02:14)djb719 Wrote: [ -> ]Hey is anyone else having issues with in the settings and customizer being able to open up the color picker tool so the menue bar and system bar colors can be changed?
Sent from my LG-H918 (typie typie)
Read back a page or two to get the secret answer.
(2017-03-09, 20:01)Solo0815 Wrote: [ -> ]@mikeSiLVO:
to fix the MyPVRRecordings.xml bug (no recordings shown) in Leia (your master-branch), please add
after line 7 (menucontrol) in MyPVRRecordings.xml
There are a few PRs left
Are you interrested in changes to variables.xml for internetstreams (webradio) together with skinhelper? Skinhelper is nicely parsing Artist and Title from the internetstream-tag. This will lead to a correct Artist-Clearart and Cover.
Fixed, thanks
I know about the PR's just trying to play catchup here but with 2 kids and getting my new PC up and running I just haven't had much time to do everything that needs doing
I'm interested if you want to show me what is working but I am hesitant to use skin helper for too many things cause I do not want to make it a dependency, also I don't stream anything so hard to test...
(2017-03-10, 01:52)1jester Wrote: [ -> ]I'll need to have a look mike, I can add the ",return" myself (I'm quite clever when I get told what to do...) It's strange that it isn't adding that part of the command/shortcut if it used to in Jarvis (if it is indeed behaving that way) I set the skin up using the same method I did in the previous version, never even thought to look in the custom shortcut field and comparing both versions, have you set the Krypton version to act this way?
Nothing I changed but could be a bug in Skin Shortcuts script but I would need a
debug log (wiki) with the debug option enabled in skin shortcuts script as well and then try to set the path to the shortcut.
Missed an onclick, will push an update in the coming days. If you want to fix it yourself change the onclick condition on line #599 in SkinSettings.xml from
<onclick condition="!System.HasAddon(script.skin.helper.service)">
to
<onclick condition="!System.HasAddon(script.skin.helper.colorpicker)">
(2017-03-10, 02:34)donlasagne Wrote: [ -> ]Hey Mike i made the FSK logos smaller. Idk if you want to use them, thought i share it.
http://imgur.com/a/y3oma
I will add them, thanks!
(2017-03-10, 03:14)flhthemi Wrote: [ -> ]Read back a page or two to get the secret answer.
Shhh! Don't tell my secrets! :p
Sounds like a plan
(2017-03-08, 09:06)heula Wrote: [ -> ]Here are the Dutch Icons
G = NL-AL
PG = NL-6
PG-13 = NL-12
R = NL-16
NC-17 = NL-18
TV-Y - NL-AL
TV-Y7 -NL-6
TV-G - NL-AL
TV-PG - NL-6
TV-14 = NL-12
TV-MA - NL-16
What about the recordings icons? Is that skin rel;ated or not?
Sorry but the icons will not work. Wrong dimensions.
I haven't looked into it yet... I do not use live tv.
(2017-03-10, 04:12)mikeSiLVO Wrote: [ -> ] (2017-03-08, 09:06)heula Wrote: [ -> ]Here are the Dutch Icons
G = NL-AL
PG = NL-6
PG-13 = NL-12
R = NL-16
NC-17 = NL-18
TV-Y - NL-AL
TV-Y7 -NL-6
TV-G - NL-AL
TV-PG - NL-6
TV-14 = NL-12
TV-MA - NL-16
What Dimension do you need?
Are
these usable?
hope someone can help.
i want to remove the year from the date.
could someone point me to the right xml file.
thanks
Any chance to have logo and clearart as an option in "BigFan" view?
(2017-03-03, 20:39)logictester Wrote: [ -> ]i think there is a missing screen in the skin. when you have multiple unwatched episodes of the same show and you finish one episode - there is a screen that tries to auto play the next episode with a time counter, this screen appears to be from the kodi skin and aeon:
Hi Mike, any notes about this screen?
G = NL-AL
PG = NL-6
PG-13 = NL-12
R = NL-16
NC-17 = NL-18
TV-Y - NL-AL
TV-Y7 -NL-6
TV-G - NL-AL
TV-PG - NL-6
TV-14 = NL-12
TV-MA - NL-16
In Titan de Dutch MPAA ratings are working.
The icons used in Titan are perfect. Something like this would be nice.
Since I have installed Krypton 17.1 RC I have noticed a huge delay on the start of the PVR Manager in Nox Silvo. I thought it was Krypton but it seems to be skin related.
I changed back to Titan with the same setup as used in Nox Silvo for testing and with Titan the PVR Manager in Titan is started instantly. I can use my guide and TV tuner right away. With Nox Silvo this takes at least 30 to 40 seconds before it is usable.
Also the start of the Emby addon is much faster in Titan.
Can you please have a look into this?
Kodi with Titan log
Kodi with Aeon NOx Silvo log
Thanks Mike for a great theme.
Is it possible to reduce the font size of the plot summary and also justify it as it is currently left aligned?
(2017-03-10, 21:46)heula Wrote: [ -> ]The icons used in Titan are perfect. Something like this would be nice.
mike and heula:
I'll have a look at the icons and see what I can do. You'll get some screenshots the next week and you can post your opinion ...
Edit:
@heula:
Can you please post a screenshot with a "single" and a "series" recording? I can't find different icons and different code for it in the Titan xmls :~
Thx
