Can you and everyone else try to replace the textures.xbt file with
THIS ONE...
Kodi must be off to replace.
Please let me know if it is fixed.
(2017-03-16, 01:43)mikeSiLVO Wrote: [ -> ] (2017-03-16, 01:31)Stildawn Wrote: [ -> ]Um, I think its whenever I have two operational widgets, for example if I put widget 1 as none and widget 2 as recent episodes then it works and the widget is along the top of the screen, currently I have them set as widget 1 is recent episodes and the widget shows just above the main menu bar (which I have in the low position).
I have tired in both TV Shows and Movies menu items, no luck getting two to work on either. I have also tried lots of widget types, like in progress etc.
Didnt know about the trakt thing, I'll look to see if I have to install a add on for it.
I do not have any issues at all with 2 widgets...
What happens if you set the same working widget to both Widget 1 & Widget 2? Just to make sure it is not the widget provider that is not working.
API issues are usually service related like trakt is "down". No need for another addon related to that.
Ok so I can have two of the same, and even two of Recent and Random movies.
But the combos I'm after are:
Recent Movies & In Progress Movies - The In Progress doesn't show
Recent Episodes & Next Aired - Can't find Next Aired Widget and the other TV Show on (Airing etc) don't show.
(2017-03-16, 02:25)mikeSiLVO Wrote: [ -> ]Can you and everyone else try to replace the textures.xbt file with THIS ONE...
10 min and i test with to diferent systems
Enviado do meu iPhone usando o Tapatalk
(2017-03-16, 02:26)Stildawn Wrote: [ -> ]Ok so I can have two of the same, and even two of Recent and Random movies.
I think the Widgets need to be updated for skin.helper. Can you test latest from Git to see if that is the case cause I just updated that with some more Widget choices as well.
I have the problem either from repo or from the link in the first post...
The texture.xbt you provided fix the problem!
EDIT: There is a problem with the logo.Check this screenshot.
watch gallery
And something else can you add a skin settings option in the bottom right corner?Or is it impossible?
Mike!
I tested in LibreELEC system and Windows System and color is ok, but logo is not ok
Logo is known. Just a quick test to make sure the issue. Next update or Git will look normal.
Ok Mike
Thanks for your help
Another thing it's possible in your skin add icon libreelec with libreelec functions equal estuary
Example
Estuary
[/align]
Aeon Nox Silvo
I making a build using aeon Knox silvo 6.0.4 with kodi 17.1 and for some reason the choose color theme option is not available when I click on it the addon is not there. I try using xbmc color picker beta but I don't know how to use. I had that option available to me before but some addons were not updating and I resulted in deleting addons.db but when I restarted build I went back to estuary skin. So I had to install aeon Knox silvo 6.0.4 all over again and when I switched to the aeon skin the build I was working on came back when the skin was applied. But most of the addons were disabled. I enabled all of them but when I tried to go to customization the the choose color skin was not available no function. Please help I'm almost finishing my build and I been stuck trying to resolve this issue for hours.
Edit: I disregard this message I read back a few pages and found out how to resolve issue...
meowmoo
Thanks for your help, but
I have created the file but I can't get it on the AppleTV
I am sure I do it the right way with Kodi file manager but the file is not copied. How do I get the Keyboard file in the Keyboard directory on my AppleTV?
(2017-03-16, 02:31)mikeSiLVO Wrote: [ -> ] (2017-03-16, 02:26)Stildawn Wrote: [ -> ]Ok so I can have two of the same, and even two of Recent and Random movies.
How do I do that haha, sorry bit useless.
Would I lose all my settings etc?
(2017-03-16, 03:54)mikeSiLVO Wrote: [ -> ] (2017-03-16, 03:16)tnds Wrote: [ -> ]Ok Mike
Done
Thank's a lot
Leave in the next update ?
Best Regards
Done
Mike, you have the brown bottom bar too? It used to be blue
Also, can you add a shadow/transparency to the icons, like they show in Estuary, makes easier to read/see against backgrounds.
