(2015-02-07, 16:14)choekstr Wrote: [ -> ]Looks like you are going to have to bite the bullet and have an option to turn on and off labels for all or just selected.
Easier said than done...
(2015-02-07, 16:52)Edworld Wrote: [ -> ]Mike:
I took this image from Warner's post. In my "second" opinion this setup is identical to the rest of the skin, if you decide to add more movies (Warner has 5) it would be your choice, but the movie info and rating at the bottom with the shaded black (so you can read the info) within the poster works.
You should include what you really like, adding both options is too much work for a widget
On a different subject, last week I made the comment of adding MPAA ratings. If you decide to incorporate this change into the skin I recommend the following script:
http://forum.kodi.tv/showthread.php?tid=107331
It downloads the ratings, updates IMDB and also provides a list of the movies you are missing
I won't make it like Warners mod cause then there is no need for me to add it since his already exists. Anything I add will always have to be at least a little diffrent, otherwise I would have no interest in adding it. I always liked BigNoids addition of poster_back.png and I plan to replace the black.png seen behind the labels in the photo you posted everywhere (still have some to replace). I use IMDb rating update myself and it is a good recommendation.
(2015-02-07, 17:00)canadave Wrote: [ -> ]See, to me, that's too hard to read. Look at the Maze Runner poster and rating. That's very difficult to discern. Same for the Fury poster. I think it'd be better to have the white rating text on a clean dark background off the posters, and keep things clear.
I am leaning more toward this way... But like I said I don't use widgets so I am trying to be democratic about it but it is 50/50 so I will eventually just pick one or slightly tweak one of those choices.
(2015-02-07, 18:54)Warez Wrote: [ -> ]Mike installed your last build... in pannelstyle mode and program addons... you get 4 pannels....
Like this: https://scontent-b-ams.xx.fbcdn.net/hpho...4173_o.jpg
just let you know.... that all
I will fix that (hopefully by tonight)
thanks
Just had a thought... surprised it didn't occur to me before. I already have the two separate widgets coded perhaps the best course of action would be to have compact only show the info on the poster when focused. Expanded can have the labels always on and I could either change position of the label and put the title above the poster and the rating below the poster or I could keep it the same… Just brainstorming
(2015-02-07, 21:00)mikesilvo164 Wrote: [ -> ]Just had a thought... surprised it didn't occur to me before. I already have the two separate widgets coded perhaps the best course of action would be to have compact only show the info on the poster when focused. Expanded can have the labels always on and I could either change position of the label and put the title above the poster and the rating below the poster or I could keep it the same… Just brainstorming
I'm just glad I'm not a modder as I could not handle 50 messages on whether a widget should or should not show more Info...
(2015-02-07, 21:10)uncertainty Wrote: [ -> ]I'm just glad I'm not a modder as I could not handle 50 messages on whether a widget should or should not show more Info...
LOL...no kidding, eh? Talk about "first world problems"....
You guys are funny... but seriously... I welcome and want any and all suggestions. I will decide on things in the end since it is my thread but do not take that as you shouldn't discuss things or offer an opinion.. I want that to happen. I know that anyone can have a great idea. If you post an opinion, idea, or suggestion I will most likely want to discuss it with you while involving the others who read the thread, so if you just tell me "I think this will look good" Expect a follow up discussion in the hopes to possibly include it if after the convo is over and it makes sense to add after that. I just want to reiterate that I welcome all questions, feedback, ideas, comments, opinions, even statements on aspects of the skin that you do not like. In my opinion it will end being a better option in the process. I realize that this might mean 50 posts or more on a particular issue... and while I found that statement humorous your opinions do matter to me and I take all of it seriously. I guess in the end all I am trying to say is... I do not want anyone to not offer an opinion on something just because you think I might get upset, annoyed, or dismissive. So please tell me your ideas, opinions, dislikes, likes, suggestions, alternatives, and honestly anything else you feel like sharing. If I can help I will
Wow Mike, what a generous perspective to take on all this. You rock.
My little hypnosis joke aside... here's some discussion.
My personal ideal would obviously be text onfocus only, and I like text on the poster more than under it, and I like the amber color slightly more than white. The IMDB rating I could take or leave. The thinking is, for me, that I can generally tell just fine what the movie is just by looking at the poster thumb but having the title pop in onfocus could be helpful at times. Also the text and gradient shadow coming in makes it clearer where the focus is.
If you can manage to hook into dialogvideoinfo that would be super if only for consistency's sake. Plus I'm all about Cinema Experience and looking up extended info on actors and such, having dialogvideoinfo be the last step before pressing "play" has a lot of value IMHO.
OK all done "voting".
(2015-02-08, 01:37)antisuck Wrote: [ -> ]Wow Mike, what a generous perspective to take on all this. You rock.
My little hypnosis joke aside... here's some discussion. My personal ideal would obviously be text onfocus only, and I like text on the poster more than under it, and I like the amber color slightly more than white. The IMDB rating I could take or leave. The thinking is, for me, that I can generally tell just fine what the movie is just by looking at the poster thumb but having the title pop in onfocus could be helpful at times. Also the text and gradient shadow coming in makes it clearer where the focus is.
I like jokes, can always use a good laugh. Yours as well as uncertaintys gave me a chuckle
My opinion on the best way to handle all of these preferences (so far) would be to have compact as you described and expanded have the labels and rating always there for quick perusal. I can not think of a better way to accommodate all the different opinions. I do however realize that some will not get there exact way but it is impossible to create something loved by all, I can only do my best to achieve as many satisfied users as I can. I will always be open to changing things in the future, unless it is something I truly love but even still a good idea can easily overshadow one of mine
maybe
Mike can you have a look on this file it is the variables.xml ?
http://www.file-upload.net/download-1027...s.xml.html
i added some lines for FSK-0 they dont shows in vide info during playback (when movies scrapped with ember media manager)
now its ok, also i think is in the FSK-6 lines an error at one point is FSK-16 in the line of FSK-6 (when movies scrapped with ember media manager)
(<value condition="SubString(ListItem.mpaa,Germany:0)| SubString(ListItem.mpaa,ab 0) | StringCompare(ListItem.mpaa,0) | Substring(ListItem.mpaa,FSK 0) | SubString(ListItem.mpaa,Rated 0)">flags/mpaa/FSK-0.png</value>)
Great work Mike, love the enhancements you made. I was using an older Gotham release of Aeon Nox, until I found yours.
(2014-12-18, 15:32)mikesilvo164 Wrote: [ -> ] (2014-12-18, 15:27)snyft Wrote: [ -> ]Great work! Love the new views
Is it possible to make the submenus hidden until pressing down or just have an arrow pointing down?
That is already possible if you uncheck "detach RSS feed from the main menu" located in skin setting > home window
I realize this is an old, but this doesn't work if RSS feeds are disabled. Is it possible to have the submenu drop down when a "down" is pressed?
Could you add the movie poster to the playback pause screen, in the lower left corner?
When selecting the home screen background, there is an indication of what has been selected. But when you select a submenu background, you have no indication if it has been configured or not. Makes it a little confusing when you initially set up the skin. Maybe there could be a check box that will configure both with the same background image.
(2015-02-08, 11:23)Mario S. Wrote: [ -> ]Mike can you have a look on this file it is the variables.xml ?
Do you want me to add those lines or is there an issue with it not correctly showing FSK-0? What does ember place in the nfo file under <mpaa>?
(2015-02-08, 17:52)YellowDog Wrote: [ -> ]Great work Mike, love the enhancements you made. I was using an older Gotham release of Aeon Nox, until I found yours.
(2014-12-27, 00:14)mikesilvo164 Wrote: [ -> ]If you copy This File to your userdata folder and restart Kodi it will not show any RSS data and still enable the submenus to be hidden till you perform a down press (must still have show RSS news feed activated in appearance settings). It is a workaround but I think it should be sufficient.
Does the above work for you? Regarding the submenu backgrounds, they are the same as the main item so it should just work if you have a background set for that item in the main menu customizer.
Yes there was an issuse with the fsk-0 on video info is the icon there and at playback in the osd was the not ratet icon after
Adding these lines fsk-0 the icon shows correctly in the link is the corrected variables !!
Fsk12 and fsk 6shows ok before i changend something in the variables !! 16 and not tested before !!
The problem was only with ember i think its the naming of ember germany:0 and not fsk 0.
I just pushed an update to Git with the final versions of the extended info, movies, and video playlist widgets. It is still WIP but if you want to help out with bug reports it will save me a lot of testing time. I will probably release it before they are 100% since it has been hard to find the time recently to test and code. As of now the most glaring issue is episode widgets in compact mode and there is no expanded for the others not mentioned.
Original example line 496-500
<value condition="SubString(ListItem.mpaa,Germany:16) | SubString(ListItem.mpaa,ab 16) | StringCompare(ListItem.mpaa,16) | Substring(ListItem.mpaa,FSK 16) | SubString(ListItem.mpaa,Rated 16)">flags/mpaa/FSK-16.png</value>
<value condition="SubString(ListItem.mpaa,Germany:6)| SubString(ListItem.mpaa,ab 6) | StringCompare(ListItem.mpaa,6) | Substring(ListItem.mpaa,FSK 16) | SubString(ListItem.mpaa,Rated 6)">flags/mpaa/FSK-6.png</value>
<value condition="SubString(ListItem.mpaa,Germany:12) | SubString(ListItem.mpaa,ab 12) | StringCompare(ListItem.mpaa,12) | Substring(ListItem.mpaa,FSK 12) | SubString(ListItem.mpaa,Rated 12)">flags/mpaa/FSK-12.png</value>
<value condition="SubString(ListItem.mpaa,Germany:18) | SubString(ListItem.mpaa,ab 18) | StringCompare(ListItem.mpaa,18) | Substring(ListItem.mpaa,FSK 18) | SubString(ListItem.mpaa,Rated 18)">flags/mpaa/FSK-18.png</value>
<value condition="SubString(ListItem.mpaa,Germany)|SubString(ListItem.mpaa,FSK)| SubString(ListItem.mpaa,o.A)| SubString(ListItem.mpaa,Rated 0)">flags/mpaa/FSK-0.png</value>
changed example
<value condition="SubString(ListItem.mpaa,Germany:6)| SubString(ListItem.mpaa,ab 6) | StringCompare(ListItem.mpaa,6) | Substring(ListItem.mpaa,FSK 6) | SubString(ListItem.mpaa,Rated 6)">flags/mpaa/FSK-6.png</value>
also 538-543 and 580-585 and 621-626 !!
