(2015-02-08, 22:37)Mario S. Wrote: [ -> ]Yes there was an issuse with the fsk-0 on video info is the icon there and at playback in the osd was the not ratet icon after
Adding these lines fsk-0 the icon shows correctly in the link is the corrected variables !!
Fsk12 and fsk 6shows ok before i changend something in the variables !! 16 and not tested before !!
The problem was only with ember i think its the naming of ember germany:0 and not fsk 0.
Hopefully I am understanding you correctly... The lines you added work and only ember giving a rating of germany:0 does not work?
<mpaa>Germany:12</mpaa>
<certification>Germany:12</certification>
thats from an nfo that ember writes
i think the issuse is that is somthing missing in the original variables look there is something different
<value condition="SubString(ListItem.mpaa,Germany)|SubString(ListItem.mpaa,FSK)| SubString(ListItem.mpaa,o.A)| SubString(ListItem.mpaa,Rated 0)">flags/mpaa/FSK-0.png</value>
where is the 0 behind germany ?? and fsk ??
I also noticed only now !!!!
thanks MIke again!!!!!!!!!
(2015-02-08, 23:20)Mario S. Wrote: [ -> ]great work
Thanks Mario! I am going to PM you later this week to work on the ratings issue, if that is ok with you?
That mockup of the widget looks awesome!!
(2015-02-09, 00:06)canadave Wrote: [ -> ]That mockup of the widget looks awesome!!
Not a mockup
you can use it right now if you download from Git
(2015-02-09, 00:22)Warez Wrote: [ -> ]Nice work Mike!!! is it a option to move the names in program addon panel above of below the icon?
https://fbcdn-sphotos-h-a.akamaihd.net/h...63dac8d338
Just like your move panel with the black other layers?
The option is not there currently but I will get to those other widgets hopefully soon. The current plan is to add a background to all widget choices and offer an expanded and compact layout for each.
Cool... why are you doing all the Mods now? Is Warner out of the running? sick?
(2015-02-09, 00:36)Warez Wrote: [ -> ]Cool... why are you doing all the Mods now? Is Warner out of the running? sick?
Warner does his own mods and he was kind enough share some of his research that has been extremely helpful but currently I am modding, maintaining, and supporting this skin by myself.
Hey Mike,
I downloaded your last update to look at what you did with the panels and actually prefer your original design by a long margin. Having the text on the top on bottom is far too busy to the eye. The poster fade with the text on the poster looked really sharp. I'd hope you'd reconsider and go back to what you started with.
