(2017-08-13, 05:23)mikeSiLVO Wrote: [ -> ][...] or I will need a debug log (wiki), version of skin.helper.widgets installed, and a confirmation from you that your system does not have any banned addons (wiki) installed before posting any of that .
thanks a lot for your effort.
I started to implement your suggestion and afterwards I was ready to post and already typing. I checked the skin.helper.widgets version as the last thing. At that point, I noticed that the widget I'm using is based on the service.library.data.provider. But since you specifically commented about the service.library.data.provider line, I guess it's still supposed to work with both. Anyway, I also tested with the skin.helper.widgets plugin, see below.
service.library.data.provider:
I tried to modify the file. I actually modified all three lines relating to episodes and just to be sure, I rebooted afterwards.
Since I wasn't sure if I was supposed to leave the empty "result=" or not, I tested both versions (eg completely removing "result=" vs not).
However, I wasn't lucky.
I'm not sure if you actually want to go trough the effort of debugging this or if I just should restart with a clean install first.
Anyway, I can happily confirm that I do not have any shady addons (see addons folder content at the end).
I uploaded the log here:
https://pastebin.com/b3ixL3c4
service.library.data.provider version 0.3.0.
skin.helper.widgets:
After noticing it wasn't installed, I installed it (in v1.0.22 although that most probably is not relevant) and tested the results.
This widget will update correctly and immediately, so works as designed.
However, with that widget a new problem surfaces: It is using season posters for the episodes. Maybe this is the quicker path to go?
list of addons:
Quote:metadata.album.universal
metadata.common.themoviedb.org
repository.aeon.nox.silvo
script.grab.fanart
metadata.artists.universal
metadata.themoviedb.org
resource.images.recordlabels.white
script.module.routing
skin.aeon.nox.silvo
metadata.common.imdb.com
metadata.tvdb.com
resource.images.studios.white
script.module.simplejson
temp
metadata.common.musicbrainz.org
packages
resource.language.de_de
script.module.unidecode
visualization.projectm
metadata.common.theaudiodb.com
plugin.library.node.editor
screensaver.rsxs.euphoria
script.skinshortcuts
