(2015-02-12, 19:19)LFCFAN Wrote: [ -> ]Hi Mike,
Would it be possible for you to add Arial based font to the skin? I found one here in the forum and I manually added to the skin but each time you update your skin I have to added manually again.
Sure, No problem! If you send a link to the post or font file I will add it
Just pushed an update to Git. The panel widgets should all be done. Now it comes down to fine tuning the design so any feedback is welcomed and will be helpful
Sure, I will happily do that when I get home and let you know.
(2015-02-12, 23:45)LFCFAN Wrote: [ -> ]Sure, I will happily do that when I get home and let you know.
Just a heads up... the name will be blank till I update the skin so just change font from skin default to blank and it should be arial for most if not all items. If you notice any not arial just let me know and I will fix it.
Okay.
Thank you for the heads up.
(2015-02-12, 23:28)mikesilvo164 Wrote: [ -> ]I just copied and pasted a fontset from another skin... can you download This Font File and test it out? Unfortunately I do not have the time to test it myself.
Hi Mike,
The file is not there any more( I got a message: removed or deleted) when I tried to download. Did you removed it?
Fourth time trying it after your post and not there.Very strange!
(2015-02-13, 00:51)LFCFAN Wrote: [ -> ]Hi Mike,
That's weird it should be there... Maybe try again?
Okay, this one worked for me and I can confirm the Arial font is 'working' also. Sorry for the trouble.
Thank you very much for your help
hi mike, congratulations for your beautiful skin, i have also one feature requests
will you implement the ability to change the opacity of the fanart ?
tnx
