(2017-12-02, 16:18)flhthemi Wrote: [ -> ] (2017-12-02, 16:11)Gembird Wrote: [ -> ] (2017-12-02, 15:48)wgstarks Wrote: [ -> ]Those menu items aren’t there because you haven’t added the videos yet.
Adding_video_sources (wiki)
Yes i know that. But in the Aeon Nox 5 Skin is no Video option in the Main Menu to add my Video sources. In the default Skin (Estuary) there is no problem to add my Video sources. Or must i switch back to Esturay Skin to add my Video sources, and than, when i have add it, i must switch back to Aeon Nox 5?? In Estuary Skin the menus Video/Tv Shows/Movies are there although i dont added anything!!??
Click Settings, then Media you should see the options then!
Ah Ok!! Thank you very much!! :-)
I've being trying to workout how to set the default main menu item on Kodi startup. Looked a few times but need help please.
I'm sure it's so simple... Thanks!
(2017-12-02, 22:32)HomerJau Wrote: [ -> ]I've being trying to workout how to set the default main menu item on Kodi startup. Looked a few times but need help please.
IIRC it’s always the third menu item.
(2017-11-29, 17:04)vicius80 Wrote: [ -> ]In some View for example "MYFLIX View" the plot in Italian is not displayed. always in English. instead with other skin or other view this problem is not there. because? can you help me?
excuse me I wrote my problem a few days ago but nobody helps me to solve ...
please help me
(2017-12-02, 23:19)wgstarks Wrote: [ -> ]IIRC it’s always the third menu item.
Thanks. I'll give it a try.
Hi, thank you for this great skin! I have a small problem. Scrollbar does cut off channel logos in PVR mode. I'm using latest Raybuntu build (rb-leia18) on WeTek Play 2.
(2017-12-03, 09:24)HomerJau Wrote: [ -> ] (2017-12-02, 23:19)wgstarks Wrote: [ -> ]IIRC it’s always the third menu item.
Solved: It's always the 5th menu item.
(2017-11-21, 21:41)skripo Wrote: [ -> ]I asked this before but it was unanswered:
How do I remove the top info bar? It is white line across the top that says "expert" in it when in settings but also appears in other areas.
I added a global disable TopBar option to Git version, you can disable it in Skin settings > General.
(2017-11-22, 14:50)sanity Wrote: [ -> ]Thanks for your answer mikeSiLVO
but the Music fanarts are very dark/dim when playing music. That is not the case for movie/tv-series views or any other for that matter, only when playing music the fanarts dimout very much and are hard to see.
Is it just me?
This is usually because you selected a visualization and it is either not installed or disabled. You would need to either turn off the visualization you have selected, enable it in Kodi's Add-on Manager, or re-install Kodi and make sure the check box for visualizations is checked so it will install.
(2017-11-26, 07:39)tjs4ever Wrote: [ -> ]Thanks for getting back to me, Mike!
I'm about halfway through these instructions but I've hit a snag:
I have some of the find+replace completed in the "MyVideoNav.xml" but I can't find any references to $INFO[VideoPlayer.AudioCodec - do I have the right XML? What XML do I edit with these new VAR, as I have found two Variables.xml? I didn't see any folders for icons in my skin directory:
Kodi\addons\skin.aeon.nox.silvo\media
So I went ahead and created flags>default and flags>colored, and placed versions of the png files in each - I hope this is correct. My filenames should already be good-to-go as it was needed for Aeon Madnox
You should use the Git version of the skin so the folders are already there.
$INFO[VideoPlayer.AudioCodec is in DialogFullScreenInfo and Includes_LiveTV.
$INFO[ListItem.AudioCodec is in DialogVideoInfo, Includes, MyVideoNav, View_501_LowList, View_50_List, and View_602_FanartList.
Also there is typo in AudioFlagVar, dts-x as value should be dtsx no "-".
(2017-12-01, 17:38)Xero Wrote: [ -> ] (2017-12-01, 17:32)Xero Wrote: [ -> ]Hi guys, any idea if an HDR flag will be added to the skin in the future? I set a manual tag for my HDR movies, but it would be cool if the HDR flag would indicate which movies are HDR (I have a 2015 Samsung TV and it doesn't notify me when an HDR movie is playing so I have to manually check the TV display settings to ensure that the "backlight" setting adjusted to 100% automatically, pretty annoying after awhile).
Edit: I just read this post https://forum.kodi.tv/showthread.php?tid=320990 and I see it is actually a Kodi issue rather than a skin issue. Any way to get around this by adding "HDR" to the file name?
If Kodi doesn't provide a way to tell if a file is HDR or not then you will have to mod it in yourself.
(2017-12-02, 15:02)moravec Wrote: [ -> ] Hello Mike
The FSK Logo is still to big - doesn't fit into the two lines. Maybe you could check...
Christian
Should be fixed on Git now, please check when you can.
(2017-12-03, 19:06)gandharva Wrote: [ -> ]Hi, thank you for this great skin! I have a small problem. Scrollbar does cut off channel logos in PVR mode. I'm using latest Raybuntu build (rb-leia18) on WeTek Play 2.
Try latest from Git please.
(2017-12-04, 22:32)vicius80 Wrote: [ -> ] (2017-12-03, 02:43)vicius80 Wrote: [ -> ] (2017-11-29, 17:04)vicius80 Wrote: [ -> ]In some View for example "MYFLIX View" the plot in Italian is not displayed. always in English. instead with other skin or other view this problem is not there. because? can you help me?
please help me
help me please
I already told you what the problem is. You have enabled
Plot Outlines in your scraper settings.
Plot Outlines are always in english. MyFlix defaults to
Plot Outlines if you have one due to the limited space. You have two choices:
1) Rescrape your movies after you disable
Plot Outlines in Universal Scraper
or
2) Use Git version
i have a problem with the "cases" in films. when i selected it, only appear and empty CD turning, without pictures in it...
anybody knows the fix?
Hello Mike!
Is there a way to edit and/or change the media flags for the Aeon Nox 5: SiLVO skin?
I been trying to locate a folder named "flags" like in the older versions, but no luck so far.
From what I could gather somehow they depend on "Textures.xbt".
Any help would be much appreciated.
Sincerely,
Oscar
(2017-10-06, 19:06)Mario S. Wrote: [ -> ]Hy Mike found a little thing latest krypton git version i cant select colored icons and media flags nothing happend !!!
I cannot get rid of this quote and it is driving me loopy. Tried clearing browser cache and removing quote manually by de-selecting it on page 485 but nothing seems to be working so I will now try posting a useless reply in the hopes it will disappear from my life forever and ever...
(2017-12-05, 19:07)Boremc Wrote: [ -> ]i have a problem with the "cases" in films. when i selected it, only appear and empty CD turning, without pictures in it...
Need to add discart to your library. Artwork Downloader should be used but it requires some TLC to make it work. You will have to read the thread for that addon to make the necessary changes to get it working correctly.
(2017-12-06, 03:04)lynxstrike Wrote: [ -> ]Hello Mike!
Sincerely,
Oscar
Use Git version. Instructions on how to install is in FAQ on first page second post or click sig link.
Media folder contents are not in a Textures.xbt file on GitHub.
(2017-12-06, 22:30)mikeSiLVO Wrote: [ -> ] (2017-10-06, 19:06)Mario S. Wrote: [ -> ]Hy Mike found a little thing latest krypton git version i cant select colored icons and media flags nothing happend !!!
Sincerely,
Oscar
Thanks Mike for your timely response.
I was working with v. 6.1.1 Leia installed from your repository v. 1.0.5
I removed it and installed right from GitHub. It all worked out fine.
Thanks from your help!!!
Hi
love this skin, binging back lots of the old customization features that have bee removed from the current Nox and allows me to have exactly what i want how i want in the menus. i have it installed on 4 android TV and my PC however i struggle in my android tablets.
does anyone know if any mod exists to make it more touch screen friendly? - a simple 'back' button on all menus would do the trick for sure!
an advice would be much appreciated!
