(2018-03-20, 05:44)Atamans Wrote: [ -> ]ps. I would give you a reputation but I do not see the button
You are still on a probation account, so you don't have permissions for PM's and reputations yet. 20 Posts will give you the permission to use Reputations.
(2018-03-20, 05:47)Karellen Wrote: [ -> ] (2018-03-20, 05:44)Atamans Wrote: [ -> ]ps. I would give you a reputation but I do not see the button
Seriously!!! I am missing on my reps man!!! LOL
(2018-03-20, 05:44)Atamans Wrote: [ -> ]thanks again for help, but it's probably not for me, the phone works well and for this I did the rest is curiosity that I can not do
maybe mikeSiLVO will add some extra options like my or more like in picture
Ok, at least try the following in case it works. I have a little time to look into it.
Go to file "Includes_Home.xml" , line 592, it should say:
<onup condition="Control.IsVisible(90010) + ![System.HasMediaDVD | Control.IsVisible(9027)]">90010</onup>
The line number itself may be off depending of how old is the skin you have installed, but you should be able to find it.
Replace 90010 with the control id of your new button. That should work based on the image above.
Even if it works, it is not 100% because of the many options this skin has and how everything is so interweaved. So, for example, if you have widgets above the main menu, it may not work without further changes.
[url=javascript:void(0)][/url]
Which plug-in should you install to get this ?
Request for Mike :
Dear Mike,
I am hoping you could look into using the option of selecting backgrounds from the selected widgets ? As is the case of Madnox.
example : I select for my TV Shows widget 1 & widget 2. The items populating these widgets have their own backgrounds / fanarts. for the overall menu background selection there is an option to select widget 1 or widget 2 backgrounds.
(2018-03-20, 13:23)vansai Wrote: [ -> ] (2018-03-20, 05:44)Atamans Wrote: [ -> ]Which plug-in should you install to get this ?
This is not a plugin but an additional extra options in the skin
it worked but I can not go back "is frozen and there is no option <onup> <onleft> etc...."
I have 4 buttons on the main page and 5 on the menu
maybe now I have to do it in a group?
<control type="group" id="???">
Dear all, I am using this lovely skin for quite a while and I like it very much. Nevertheless, I have one issue to remark. Is use widgets (extended panel) for movies and TV shows. From the movie widget the appropriate movie starts directly. From the TV shows widget (recently watched) the skin jumps to the (list) view of the alphabetically ordered TV show, then I have to click on the TV show and in the following sub menu I have to select the season of the TV show, finally selecting the next (unwatched) episode. Is there a way to directly jump into the actual season of the recently watched TV show? Thank you for any suggestions. Best regards fred.
Hi if i scrape my library the video codec mediaflags from my x265 files are missing using 6.1.3 leia.
How do i name my x265 files for showing them?
i now have this:
Lucifer.S03E01.1080p.hevc.h265.mkv
Am i missing something?
(2018-03-20, 18:08)Atamans Wrote: [ -> ]it worked but I can not go back "is frozen and there is no option <onup> <onleft> etc...."
Yes, the reason it is "frozen", it is because once you jump to a different group, in the case a group of one button, from there, you need to specify, for that one button, what to do when you press up, down, left or right, which you haven't, so it is stuck. In other words, you haven't told your button how to navigate. In the previous example I gave you, we told the main menu how to navigate when you press up, but once it is up (meaning in your new button), it doesn't know what to do.
Now that I see more of what you are trying to do, the way I would go about it, is creating an "include" list with all those buttons. This list will show 4 or 5 buttons on the screen depending on the conditions you set, with navigation options and other attributes. Then include that group in the windows you want, for example, the home.xml. It seems to me, maybe I'm wrong, that is beyond the scope of your knowledge, and unfortunately, too much specific code for me to guide you through.
The easiest way I can think of, is inspect the Home.xml file and include_home.xml file and see how both work and interact with each other to get a deeper understanding of skinning. It takes time and patience, that's for sure.
(2018-03-20, 23:59)sniferx1 Wrote: [ -> ]mikeSiLVO
Skin Feature Request: I am using your Skin now over 2 to 3 years and now and awesome skin.
As you may know recently the “Artwork Downloader” add-on stop working due to API key issue and developer stop supporting it and mark the add-on as broken and I am not getting new artworks at all.Luckily another developer developed a better version of Artwork downloader called “Artwork Beef” .
This is humble request to integrate this awesome skin with “Artwork Beef” and it’s features.Details / Skin Integration help available via below
links:
Artwork Beef” Kodi Forum: https://forum.kodi.tv/showthread.php?tid=258886
Artwork Beef Wiki: https://rmrector.github.io/script.artwork.beef/
I might be wrong but I assume if you want it it is already there if you install it. You might also want to read
this post that I found using the thread search tool for the words "Artwork Beef".
problem solved, it was not so terrible
(2018-03-21, 15:40)flhthemi Wrote: [ -> ] (2018-03-20, 23:59)sniferx1 Wrote: [ -> ]mikeSiLVO
links:
I might be wrong but I assume if you want it it is already there if you install it. You might also want to read this post that I found using the thread search tool for the words "Artwork Beef".
script.artwork.beef is not showing in my skin. As per skin help screen I am on Kodi V17.6 and v6.0.13 of the skin. Any help on how to get this script?
