Possible, yes. I've added the default values without the tvshow prefix to EmbyCon again, but to be sure it's always good to add those fallbacks. I would never trust any addon to deliver the correct artwork values.
sualfred
So, what do that mean for EmbyCon?
So you have to fix it for correct Banner view?
What I did not said:
With using Emby for Kodi together with Aeon Nox Silvo, the BannerView is correct.
Only with EmbyCon it's broken, so I'm not sure (although I don't really understand that anyway), if it's only a skin related problem.
But thanks for looking into this!
It's changed on the beta version 1.5.21 @
Siutsch
Hi Mike, Just updated to Leia and using your fantastic skin. Noticed 2 things compared to the Krypton version I have been using.
EDIT: Re-installed skin and the middle menu item is focused, so please ignore my original first point.
Secondly, I use the small shift view and noticed that the Movie covers along the bottom now intrude into the fanart. Also the company and rating icons are now under the title (and covering some of the text) rather than on the right. Is that something you can fix or is it a new design. Thanks
Leia
Kodi
^^ I edited your post to show the image correctly.
Hello, thanks for all.
I have two questions.
How could i change the colour buffer line when the video player play movie. In the next picture you can watch the gray colour is very similar to background line colour. I want change it to yellow, for example
Could i change control buttons position in the tv live pvr? i want it show on top of the screen as original aeon nox. It is possible?
after upgrading to Leia my 4K cases are now gone? not sure what happened or if if there is a new setting i'm missing now. all the other cases appear as normal. i got 4K cases before upgrading
(2018-05-20, 13:57)satelly Wrote: [ -> ]Hi Mike, Just updated to Leia and using your fantastic skin. Noticed 2 things compared to the Krypton version I have been using.
I will take a look and fix as soon as I can but please keep in mind that Leia is currently WIP and there are a few changes made that may cause some issues. Please continue to post anything else you notice
(2018-05-21, 20:04)marpemim Wrote: [ -> ]Hello, thanks for all.
Everything you are asking needs to be changed in the skin xmls. Buffer color is in DialogSeekBar.xml and the control buttons are in VideoOSD.xml.
(2018-05-23, 07:29)knives of ice Wrote: [ -> ]after upgrading to Leia my 4K cases are now gone? not sure what happened or if if there is a new setting i'm missing now. all the other cases appear as normal. i got 4K cases before upgrading
Please post a
debug log (wiki) of you playing a 4k file and I can take a look to see what may be the issue.
Morning. I am having a nightmare. Trying to put a new splash screen/mp4 on. When Kodi starts it hangs on the loading circle just going round. If I then press backup on my remote it goes to Kodi, briefly displays then plays my splash mp4.
I’ve had a search and there was a thread asking about it but never got answered. I had a look in the settings xml and looked at what was recommended in other threads but that seemed to be more about the duration.
As I say, the mp4 plays fine when it does start but doesn’t start on opening Kodi.
I am using a shield tv, with a nightly from the 20180514. I have put and renamed the mp4 into the extras folder. I have also enabled play splash intro on the skin.
Any help?
Jbev01
You will need to provide a
Debug_Log (wiki). The instructions are in my signature. Use the Basic method. Once you have
enabled debugging in Settings>System Settings>Logging,
restart Kodi which should then
replicate the problem. Once done
upload to
https://pastebin.com/ or
https://paste.ubuntu.com/ and link back here.
Hi, just some little remarks to improve this great skin :
- Is it possible to add option to allow osd menu to back off automatically after x seconds because we need to press back key after restarting the movie. Especially on video.
- Magnify a little bit the year in information panel to the right top corner, it's not center on the row.
- Move "fanart in full screen" from extra menu to the icons list to allow rapid access to the picture.
- I think it's not so easy to see what item is selected, the color is just a little more blank, perhaps a colored line at the bottom of the picture could be enough.
somethings else, I don't find how to delete a music album from the médiatheque but not sure ii is because of the skin.
Thx for all the job to keep this skin so good.
(2018-05-11, 07:06)guandms Wrote: [ -> ]Guys, please help, this is the 3rd time I'm asking this, can I cancel the "Video Lyrics" and go back to the regular version, the Lyrics are beautiful but very heavy on my streamer...
And another question, how can I disable the "info section" from disappearing after a few seconds, I want to see the CD and Artist and song name all the time.
Thanks in advance.
personnely I just uninstalled lyrics add-on to stop showing it in music. Don't see what is "video lyrics", perhaps it could help you.
for the second question, i think the answer is to let the osd visible (not remove it by pressing back button).
Hey guys, im having a problem with the trailer button in the video info dialog. When i click the button, my kodi just restarts. i had a look into dialogvideoinfo.xml but everything seems fine:
Quote:<onclickcondition="String.IsEmpty(ListItem.Trailer)">ActivateWindow(videos,plugin://plugin.video.youtube/kodion/search/query/?q=$INFO[ListItem.OriginalTitle]+Trailer)</onclick>
my youtube plugin is working too, so why not the trailer on the video info?
anyone an idea?
Here's my Log
https://paste.ubuntu.com/p/zbmTYzc5MG/
(2018-05-23, 08:43)Jbev01 Wrote: [ -> ]Morning. I am having a nightmare. Trying to put a new splash screen/mp4 on. When Kodi starts it hangs on the loading circle just going round. If I then press backup on my remote it goes to Kodi, briefly displays then plays my splash mp4.
Any help?
Logfile, again hope I’ve done it right:
https://paste.kodi.tv/jeletoreni
