(2019-03-19, 17:51)villano666 Wrote: [ -> ]Hi, i have a question about movies/tv series widget.
Regarding the movies, I've configured "recently added movies", the thing is that I would like the widget to remove from that list movies I've already seen. Show recently added not played. Is it possible?
2
As to tv series widget, i have problem with "in progress" asi I have tons of episodes with almost all the video watched (i stop the video on credits, and it's showing as not finished)
Is there a way to correct this? Maybe I'm missing a configuration.
Maybe check "Skin Helper Service Widgets" settings.
2 Changing these settings for the widget might help.
(2019-03-12, 14:29)Wombat18 Wrote: [ -> ] I wachted a recorded ts file, but the preview image is there with different types of content, e.g. streams from DAZN addon or German Sky Go.
I would like to have an option to disable the preview image in the Video OSD, so that you only have the small black line with current time, end time, time's up, remaining time
SiLVO v7.0.1 is updated in Kodi repo with this now disabled by default.
(2019-03-12, 16:17)bluemartian Wrote: [ -> ]Hey @mikeSiLVO, a while back I pointed out some view settings that work for video but not music (Default/Alternate Layout in TriPanel settings and Small List in LowList settings).
Well, I found another one. The Hide Ratings In List Views setting does not work in the Music versions of the views it is supposed to affect -- TriPanel, List and LowList, according to the help tip. Actually, TriPanel (the music version) as far as I can see doesn't even have ratings. LowList and List do have ratings, but Hide Ratings doesn't affect their display. Always on.
From a little poking around, I found that the Music-related sections of code in the various view XMLs do not have:
!Skin.HasSetting(Enable.HideRatings)
...whereas the Video sections do. I'm sure there's more code to it than that, and it is not a big deal, but I was wondering if you plan on matching/catching-up the Music versions of these views with the Video versions feature-wise? It just seems a little inconsistent and misleading, as these settings by their names appear to be global, but actually only apply to video views, and the only way to discover that is to try them in music and find they don't work.
Poor Music...Video gets all the love. "Oh-a, oh-a!"
Yeah, that's not gonna be so quick cause the number ratings for videos and the image used for star ratings in music are quite different IMHO. I can make it so that if you do not have a rating for music the grey stars will not appear and reword the setting to be video library only...
(2019-03-13, 15:26)zyanni Wrote: [ -> ]Not sure if this is the right place to post, But I am having a difficult time installing any skins. Tried to install the Aeon versions that are in kodi 18.1 but get this error or a version of this every time..
"the dependency on resource.images.recordlabels.whiteversion 0.0.1 could not be satisfied".
Also tried to directly download and install but get the same message. I can install the Husham version of confluence but it dosen't work correctly at all.
I am on a new Linux computer with a new AMD Ryzen™ 5 2400G with Radeon™ RX Vega 11 Graphics processor.
Can I correct this error?
resource.images.recordlabels.white is in the Kodi repo and should install automatically. You would have to post a
debug log (wiki) for anyone to know why you are not able to install that dependency.
(2019-03-14, 20:40)emveepee Wrote: [ -> ]@mikeSiLVO since @Karellen referenced pvr-nextpvr I got a sample of his file and saw his initial problem and your fix worked for me too.
I am not sure if your aware, but it doesn't look like your skin really supports PVR Radio it treats it more like an audio player so the labels are quite different from other skins I have tried.
Martin
I don't have PVR so I have to use the PVR Demo Client and it is limited. I do not see a way to test PVR Radio using it. Do you have any suggestions?
(2019-03-14, 23:44)quebert Wrote: [ -> ]The more I use this skin the more I'm loving it. I have a question and a suggestion.
suggestion - in the music widgets for the main menu where it displays the row of album covers with the album name under them. Perhaps an option could be added to display the artist name? I have a lot of albums that I don't recognize based just off the cover and album title.
question, is there any way to get it to rotate thru random music fanart for songs that have multiple artists? I was listening to an Eminem song feat. Alicia Keys. In the ID3 both artists are named and the track comes up under both artists. But, when I play it I only get fanart for Eminem. If this is even possible, I'm sure it's way more complicated than I'm imagining. I poked around and asked in the Artwork Beef thread even. I could have sworn I've seen this in Kodi months ago. But I don't remember the skin, or if I'm even remembering correctly lol.
I'll take a look for artist name but the fanart for feat artists I have no idea how to add that...
(2019-03-17, 21:11)tjs4ever Wrote: [ -> ]@mikeSiLVO
I updated to Kodi 18 today and was happy to see that this is now in the official repo! I was able to update the addon and keep most of my config from Kodi17, I hit one small roadblock, not sure if I found a bug?
When trying to create a widget for Favourites, the submenu in Favourite category is completely empty and only has the two dots..
Unrelated: I haven't had a chance to look yet, but I'm assuming that the same fixes as previous version for the atmos and dtsx custom icons?
Going to need some more info here. A screenshot would also be helpful. Where are the two dots and what is supposed to be there?
Yes atmos and dts-x should be the same mod that I previously posted. Might be different line numbers if I specified them but other than that should be roughly the same.
(2019-03-19, 01:11)Botafuco Wrote: [ -> ]Hi everyone,
When pausing a video, the pause symbol overlays on the center of the screen. Is there a setting such that said symbol does not overlay the screen (e.g. does not "block" the picture underneath)?
Thanks in advance.
There is only two other settings; use a Label instead of Pause image or Use Netflix style pause screen after whatever seconds I set it too.
(2019-03-23, 20:00)mikeSiLVO Wrote: [ -> ]
Martin
I offered to write a special version of my pvr (pvr.nextpvr) in demo mode that runs without a backend that loaded a channel list, recordings an played fake radio and TV but I didn't get any takers. Would that help?
Martin
(2019-03-23, 20:00)mikeSiLVO Wrote: [ -> ]Quote:Hi everyone,
Thanks in advance.
I'm not familiar with the theming process but would it be possible to replace the existing pause icon/image with a transparent .png and kind of cheat it?
(2019-03-23, 20:37)emveepee Wrote: [ -> ]I offered to write a special version of my pvr (pvr.nextpvr) in demo mode that runs without a backend that loaded a channel list, recordings an played fake radio and TV but I didn't get any takers. Would that help?
Martin
If it provided as many INFOlabels as possible for testing then that sounds like it would help a lot
(2019-03-23, 20:41)VectorZ Wrote: [ -> ]I'm not familiar with the theming process but would it be possible to replace the existing pause icon/image with a transparent .png and kind of cheat it?
You would have to be using the Git version cause the repo one has a bundled Textures.xbt file so replacing images wouldn't work also you could just delete the image as well...
(2019-03-23, 23:08)mikeSiLVO Wrote: [ -> ] (2019-03-23, 20:37)emveepee Wrote: [ -> ]I offered to write a special version of my pvr (pvr.nextpvr) in demo mode that runs without a backend that loaded a channel list, recordings an played fake radio and TV but I didn't get any takers. Would that help?
Martin
The addon doesn't normally create the Infolabels, Kodi does that. I made this video
https://www.youtube.com/watch?v=vgQsRVOnl_4&t=221s showing how different skins use the exisiting Info labels for TV Recordings differently both on screen and in the player and radio is similar. The first 3 minutes shows how NextPVR has to fake Season and Episode info. into the Program Name to get consistent output, the last 2 minutes show just Kodi defaults. Live TV and Radio have similar variances. My offer was to hopefully allow more consistent use of the the labels that are there now.
Aeon Nox5:SiLVO was interesting for me because of the CD image during radio, none of the other skins I tried shows any useful image.
Martin
mikeSiLVO , is it OK with you if I "borrow" the layout you have for TV Next Aired so I can do something similar in the migration I am doing of the Amber skin to Leia? Please let me know. Thanks.
Regards,
Bart
Hello, I have a problem with the movies in bluray. The media flags do not appear in any movie in bluray format (folder structure). I have tried many movies in bluray and different skins and still does not appear the media flags (resolution, codecs, audio, etc). However with mkv video files if they appear correctly. I added the word "BLURAY" in the movie folder but it does not work. How do I have to do it?
Bluray movie without media flags:
mkv movie with media flags:
david86bcn
They work for me...
And this is how I named my folder...
Have you tried playing the movie for a few seconds? It shouldn't be necessary, but sometimes it is.
If you have tried a number of skins with the same result, I will have to say it is a problem with the video file.
(2019-03-24, 00:51)Karellen Wrote: [ -> ]@david86bcn
They work for me...
Yes, I have tried to play the movie for a few seconds but nothing ... And I have tried 3 or 4 fullblurays with the same result (all with folder structure with BDMV and CERTIFICATE folders).
Hello
I have a problem...
When i set a Widget Panel in "TV-Shows" file location "Video Library" then i don't see the Cover/Poster
but...
When i set a Widget Panel in "TV Shows" file location "TV Shows > InProgress TV Shows" then i see the Covers
How can Fix this?
Hi everybody. I have a problem in the info screen. Since updating to 6.1.8. and avobe, plot is missing. How can i fix it? Sorry for my english!!
