2019-08-04, 21:33
(2019-08-04, 04:59)Wombat18 Wrote: [ -> ]How can I delete the black area at the bottom in this view (outlined in red)?:
Either delete the floor.png image or mod the code in Includes_Backgrounds.xml
(2019-08-04, 19:08)gmantonz Wrote: [ -> ]Thanks Mike, that worked! I think I also found a small bug with the live background cases for sets. If a set contains 4K quality movies, the cases on the live background show as Bluray, but when you go into the boxset, they show up as 4K just fine. So I don't think the live backgrounds mod is reading the 4K cases.
It looks like the skin.info.service script was not ready for 4k. I have updated the script to v1.0.5 HERE.
Some prerequisites here though:
You need the updated version of the skin cause the calls to the script have changed. The updated skin is pending review so you will need to install the GitHub version and instructions to do that are in the first post.
_________________________________________________________________
@ All There is an update for script.skin.info.service v1.0.4 that has already been merged to the Kodi repo and it looks like the skin reviewers are quite busy ATM so there will be a little bit of an adjustment period where the skin will not show set info correctly without some intervention.
There are two ways to fix it:
First is to downgrade the Skin Info script to v1.0.3 from my repo
Second is to update the skin from GitHub to v7.0.3
Then when the skin is updated to v7.0.3 you need to then update the script to v1.0.4 or v1.0.5 depending on which version happens to be in the Kodi repo at that time.
Just for clarification:
Aeon Nox SiLVO v7.0.2 needs Skin Info Service v1.0.3
Aeon Nox SiLVO v7.0.3 needs Skin Info Service v1.0.4 or above
