(2019-08-19, 19:32)flhthemi Wrote: [ -> ]It appears the V7.04 update has removed cover art in List mode for TV and Movies. Addon icons do not display in list mode either.
(2019-08-20, 04:34)snyft Wrote: [ -> ]Since the last official repo version my list view for addons does not show thumbnails.
Fixed on Git. It is a one line change due to some copy/paste code error, and just a smidge of stupid on my part, while adding the information setting to SlimList.
Just follow the commit
HERE if you don't want to wait for the next update.
(2019-08-20, 11:51)Solo0815 Wrote: [ -> ]some more:
5. LiveTV-Settings: remove setting "Enable Fullscreen Info for Recordings"
If there is some "info" stored" with the recordings, why isn't it displayed by default? If you want the user to choose between small and full info, then you should add a button "Enable small info screen for movies and TV-shows" also
My suggestion is: remove this button and enable only Fullscreen Info for recordings --> one button (setting) less
6. Add a bigger listview for recordings
sample xml will come ...
7. please, please change the infoscreen for PVR-entries to fullscreen. Atm half of the screen is not used (dark, semitransparent overlay) and the other half is only used by 2/3 of the size. There is much room for improvement: bigger text area, bigger channel-logo/Icon etc.
8. NowPlayingInfo on HomeScreen is overlapping
9. change Recording Icon in now Playing screen to the new one
see image for both
10. if you are recording, text is overlapping in MyPVRChannels
11. Add Season, Ep-Nr and Ep-Name to Timers
Then you can see in "Timers" which Ep is recorded
Improvements (summary) for Guide/MiniGuide:
- Add Season/EpisodeNr and Episodename to the textfield
- allign the text vertically centered in the grid. ChannelName is vertically centered, so it doesn't look good IMHO
- maybe add Season- and EpisodeNr (if available) to each entry in guide (grid)
^^^^^ I have code for it already ... somewhere. Let me search on my HD. I'll post a sample xmls later
It is not displayed by default because some people don't want it and whenever I try to add/remove stuff with a setting people lose their collective shit over it so...
Also you literally just said remove a button then add a button, that's the same amount of buttons
Screenshots are helpful. Code is not cause I'm likely not going to use it.
It is half the screen cause there isn't a lot of info to be shown. Bigger logo is a silly reason to have something be fullscreen with so much empty space.
If you have examples of things that are missing then I can add more stuff and re-work PVRInfo to fit. I also am not currently happy with that look but need more stuff shown to make it bigger. Might just go back to the Aeon Nox 5 way and show a popup dialog instead of emulating DialogVideoInfo.
9 & 10 are fixed. For 8 I just re-worked that but some of the info needs to be removed. I don't show plot or end time for library items so it has been removed to match.
You can test on Git for any issues now.
I don't think you can add some of that info to timers. Have you added any and checked if it populates?
I re-worked that bit now as well so you can test it out when you get a chance.
Do you mean add season/ep and name to the large info on bottom for default and left side for mini?
I will center it if only there is no icon but not sure if that is gonna be jarring when there is an icon. I guess test it out and let me know.
Not gonna add it to the actual guide listing. Way too much clutter then.
(2019-08-20, 13:14)Jayabs Wrote: [ -> ]Hi All,
@mikeSiLVO I have some issues with the Movie Database scrapper since upgrade to 7.04 Not sure if it is related to the skin.
Some of the most common TVshows are no more recognized (Power, queen of the south by exemple),I dont know if I am the only one to experience this issue.
Looks lilke the problem start when I install the new emburay programm.
Thanks and Rgds.
Skin has nothing to do with scraping. Have you checked The Movie DB site cause if it is too new an episode sometimes it takes a day or two for someone to update the show.
(2019-08-20, 17:00)brazen1 Wrote: [ -> ]Embuary Helper updated yesterday and nothing else. Not sure if it's the culprit? Selecting an actor picture in the info window no longer goes to the bios info for the actor selected. It only displays titles within the library that actor is associated with. This skin and Estuary. Using v.19 nightly that was previously fine so it's not Kodi build. Just an FYI.
Extended Info is not maintained and support for it was removed. A replacement was added to Kodi repo and I switched to using that instead.
If you go to Skin settings > Help > add-ons then install script.embuary.info the actor search will work again.
That info should be in What's New IIRC...
