(2019-09-13, 21:41)Wanderer189 Wrote: [ -> ]I would like to see it happen, white is simple and clean. If you decide not to do it, would love a copy of what you've done
I really don't think you'd want it in its current state.
Literally only two screens are "
finished".
The Skin Settings, Color Customizer and that's it.
When the option is active some of the text colors switch so most of the skin would be unreadable...
FYI, a new skin update is on the way.
Nothing should break but you may have to
re-enable the Widget info if it disappears from your Widget.
A complete list of changes can always be found in the commit history on GitHub but you can find a summary
HERE.
Hi, I would like to add a libreelec setting shortcut in an item submenu, any hint how to do it ?
Thank you
(2019-09-13, 23:54)Roby77 Wrote: [ -> ]Hi, I would like to add a libreelec setting shortcut in an item submenu, any hint how to do it ?
Thank you
In menu customizer use change action, scroll down to custom item then add:
RunAddon(service.libreelec.settings)
I'll add it to both the common and system menu items in the next update.
Oh you just had to screenshot a diffused image vs natural! I've always liked the diffused blend because it doesn't appear coarse and rigid if you know what I mean. But... now I see just how much information is diffused and I'm tossed now. Thanks a bunch. LoL.
In all honesty, as was mentioned, the text color on a matching color fanart in that area would be hard to read. I paid no attention to the gradient banding approaching the diffused area before... but now I probably will. Thanks a bunch again.
How do I display a progress bar using CU LRC Lyrics? I see player controls but no progress bar. I want to skip backward or forward in the song using right and left arrows but those take me to the next or previous artist when in list view. I don't care which view is recommended. I've tried a few and it didn't make any difference. I ask here because I think it's skin dependent but I could be wrong.
(2019-09-14, 02:13)monisriz Wrote: [ -> ]Is this diffusion dependent on a transparency based texture? Or some other method? If it’s a texture, then smoother gradient might help..
It is from this image
HERE.
If you want to play around and try to improve it, I can update it in the skin
(2019-09-14, 04:02)brazen1 Wrote: [ -> ]How do I display a progress bar using CU LRC Lyrics? I see player controls but no progress bar. I want to skip backward or forward in the song using right and left arrows but those take me to the next or previous artist when in list view. I don't care which view is recommended. I've tried a few and it didn't make any difference. I ask here because I think it's skin dependent but I could be wrong.
Music playback doesn't have a progress bar it has the time played/total duration in the info screen. You can press your info button to see it. It never was coded to display while seeking.
Should I add that?
I don't know what your on about with the recommended view...
Playback controls work differently in Lyrics mode. Up/Down scroll through the lyrics and you can press Enter/OK to move to that place in the song. I don't think it works for non-synced lyrics though, but personally, I turn all those off in the settings of the CU LRC Lyrics add-on and only show the synced ones.
I added left/right for track changing so it was easier for users with limited buttons to see lyrics and be able to skip songs.
I guess the view chosen makes no difference once playback begins in fullscreen and I assume I should use fullscreen in order for the lyrics to display? Without using fullscreen, I get no lyrics but a song plays and different views then come into play. I thought if I didn't use fullscreen, used a compatible view, lyrics would finally display, and the seek bar (sorry I thought it was called progress bar) would appear. I'd rather use fullscreen and will continue with or without a seek bar.
I've just reformatted and undergoing a complete fresh manual rebuild. It's been a very long time since I used CU LRC Lyrics. Years. I vaguely remember a seek bar available on the same screen lyrics were displaying and I was able to navigate forward and back on that seek bar with a mouse or my remote using directional arrows. I wasn't using this skin then so that's why I thought the seek bar thing might be skin dependent.
By all means, if you could add one, that would be cool but it's a minor thing and maybe not worth your time. I just thought it already existed and I'm not setting up for it correctly. I don't know anything about playing music files in fullscreen but I assume I need it if I want lyrics to display as well as all the other things made possible by using it.
The way it stands, I can pick any view and start a song. I'm presented with a fullscreen and 'info' about the song for a short time and then the info goes away. In the mean time, extrafanart is rotating in the background and lyrics are displaying on top of them. These lyrics are colors that change and font size that changes according to emphasis the artist uses singing the words. Everything is in sync. It's really quite cool and I like it having never seen anything like it before. I assume this is delivered because of the extra lyrics setting you've provided. It all seems quite perfect except there is no way I can figure out how to skip forward/backward through the song. I can bring up the player controls and use FFW or REW but I want to skip... say 10sec jumps or where I select with the mouse curser in a seek bar.
brazen1 Lyrics are only displayed fullscreen.
The lyrics work when there are ones to display.
There is no seekbar for music and I likely won't add one.
Sorry but not understanding the reason you want to skip through a song and see lyrics at the same time
Like I explained above, scrolling through the lyrics with Up/Down and pressing enter/OK will seek the song and I would think that should be good enough.
IMHO of course...
Found this
thread about an actor art resource add-on.
Should I add it to the next skin update or is it too much?
(2019-09-15, 01:26)Karellen Wrote: [ -> ]Yes please
Maybe a step further and add support for multi-posters... https://forum.kodi.tv/showthread.php?tid=345299
I already have many of those multi-poster collections saved locally, so would be nice to use them.
Ok
Do you mean cycle the posters in DialogVideoInfo like extra-fanart does in the library views?
I finally got the songs to seek via the lyrics. I like everything about the whole experience including how to seek a song via the lyrics and using the L/R arrows to skip songs. Most of all, I like the look of the lyrics. Thank you for the help. I'd favor the actress's png's added. It isn't too much. There's one for character png's too.
