(2019-12-26, 21:52)shedrock Wrote: [ -> ] (2019-12-26, 20:59)hoschilo Wrote: [ -> ]running pkscouts latest artisitlideshow on Silvio's latest GitHub version - so far so good running well but I noticed that in musicvisualisation two slide shows are running at the same time. One is pkscouts artistsslideshow and the other seems to be be random fanart. Any idea on this?
I am also using the skin with AS Beta 7 and I confirm that it is indeed an issue.
I have deleted the lines 87-94 and ghost fanart has disappeard. Sorry I'm not a programmer so please make sure to backup the file when you try and I have no idea what else will be not working ;-).
I'm sure experienced programer or skinner will find the real issue
<control type="multiimage" id="90300">
<include condition="Skin.HasSetting(Enable.AnimatedBackgrounds)">AnimatedBackgroundAnimation</include>
<fadetime>2000</fadetime>
<aspectratio>keep</aspectratio>
<include>MultiImageTime</include>
<imagepath background="true">$VAR[VizBackgroundVar]</imagepath>
<animation effect="fade" start="100" end="20" time="0" condition="![String.IsEqual(Visualisation.Name,waveform) | String.Contains(Visualisation.Name,spectrum) | String.IsEmpty(Visualisation.Name)] + !Skin.HasSetting(HideVisualizationFanart)">Conditional</animation>
</control>
Double fanart should be fixed with latest Git versions
(2019-12-27, 17:36)mikeSiLVO Wrote: [ -> ]Double fanart should be fixed with latest Git versions
Sorry to bug you Mike, but the changes only made to the
MusicVisualisation.xml file?
Regads,
Shedrock
(2019-12-28, 01:16)shedrock Wrote: [ -> ]Sorry to bug you Mike, but the changes only made to the MusicVisualisation.xml file?
Regads,
Shedrock
It appears so but I recommend deleting the entire skin or using the addon manager to install the zip after following the instructions in Post 3 of this thread.
Grabbing a file or two here and there is a recipe for disaster IMHO.
(2019-12-28, 16:37)mikeSiLVO Wrote: [ -> ]It appears so but I recommend deleting the entire skin or using the addon manager to install the zip after following the instructions in Post 3 of this thread.
Thanks Mike, I'll do that in fact.
Regards,
Shedrock
hello,
is there a way to show video bitrate info? bitrate would be useful in info that appears when you press 'o' button. Is there a way to add it there? thank you
(2019-12-28, 17:27)rix81 Wrote: [ -> ]press 'o' button
That information comes from Kodi core and cannot be modified by the skin. You would need to make a Feature Request.
(2019-12-28, 21:12)Karellen Wrote: [ -> ] (2019-12-28, 17:27)rix81 Wrote: [ -> ]press 'o' button
you're right. Found a couple feature request regarding this started a couple of years ago , but with no progress...
Hovewer I found another way to show it, cntrl + shift + o does the job, but can't use it on regular remote control (cntrl, shift are missing) Is there a way to add this info to regular info overlay ('o' button) ?
I seem to be missing the show airing status from my TV shows after the TVDB update mess that was happening a short while ago ? Is this a thing or do i need to run an update of Nox Silvo ? I am using the current Silvo from the Kodi repo.
I used to get date airing and show returning status on my TV shows but now its gone ?
It does work. You probably need to reset the TV information in TV Show Next Aired. It may prompt you with a few errors, but it will work, at least it does for me. I believe TheTVDB is still sorting some of their issues out.
Shedrock
(2019-12-29, 07:26)shedrock Wrote: [ -> ] (2019-12-29, 07:12)timoxx4 Wrote: [ -> ]
Shedrock
Yeah done that about 5 times now but still not showing the info. I have uninstalled tvshow next aired and reinstalled it but yeah no dice. It shows the dates and stuff in the tvshow next aired list. Just i dont get the info of the shows status in the silvo skin on my TV shows folder. Using BannerPlex. It used too. Dosent now ? What version of the skin are you using ? Oh also what version of Kodi ? I am using the latest of leia
(2019-12-29, 08:58)timoxx4 Wrote: [ -> ] (2019-12-29, 07:26)shedrock Wrote: [ -> ] (2019-12-29, 07:12)timoxx4 Wrote: [ -> ]
Shedrock
All good. Got it working. Turns out the last update of the skin disabled the setting in skin settings Extras/ enable next aired information in the videolibrary.
Is possible to have more information about satellite TV. The actual one has only information about SNR and AGC. Is possible ot have information from sateeliet as: name, frequencie,provider, etc, something like exists on enigma skin?
What addon and what setting makes the info show for the widgets? I can't for the life of me figure out why on one Windowz box I have it doesn't work when you mouse over or use a keyboard to place it on a movie cover. What DOES happen is the info does not show and the row of widgets that gets covered by it, when it works, disappears and you end up with a blank space on the screen. Man I hate getting old....
