(2019-12-26, 22:30)flhthemi Wrote: [ -> ] (2019-12-26, 21:56)GWADA.TYS Wrote: [ -> ] (2019-12-23, 22:49)flhthemi Wrote: [ -> ]I know nothing about Macs but I'm sure if you post a debug log someone will help. There are several versions of the skin, one for Leia 18.5, one for each of the older versions too. V7.08 I think is the current version for Leia 18.5 so make sure you have the right version of the skin for it.
Where should I do that please ? I have Leia 18.5
As I said I have no Mac knowledge....If Kodi runs you should be able to switch back to the default skin and then uninstall Aeon Nox Silvo. Then use the Kodi repo to install it again but make sure the correct version will be installed for Kodi 18.5, which should be Aeon Nox Silvo V7.0.8.
How to get a log file posted is in this wiki - https://kodi.wiki/view/Log_file/Easy
Hi all,
I'm using an IMac and I have Leia 18,5. I've tried to download the AEON NOX Silvo but I have an issue with it : "Building menu" still running for hours...
I can't locate the advancedsettings.xml as mentioned in the link of the last reply from the member "flhthemi".
During the process I found this message
"Dec 31 08:59:59 iMac-de-Baptiste-MENANT Kodi[833]: CPSGetCurrentProcess(): This call is deprecated and should not be called anymore.
Dec 31 08:59:59 iMac-de-Baptiste-MENANT Kodi[833]: set_foreground_operation_state(): This call is deprecated and should not be called anymore.
Dec 31 08:59:59 iMac-de-Baptiste-MENANT AGMService[520]: ProcessPath : /Applications/Kodi.app/Contents/MacOS/Kodi
Dec 31 09:00:04 iMac-de-Baptiste-MENANT Kodi[833]: WARNING:
The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt -- it is a documented limitation. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Dec 31 09:00:04 iMac-de-Baptiste-MENANT XBMCHelper[836]: ParseOptions - AppPath /Applications/Kodi.app/Contents/MacOS/Kodi
Dec 31 09:00:04 iMac-de-Baptiste-MENANT XBMCHelper[836]: ParseOptions - AppHome /Applications/Kodi.app/Contents/Resources/Kodi
Dec 31 09:00:04 iMac-de-Baptiste-MENANT Kodi[833]: 0 CarbonCore 0x00007fff8d1916df ___Gestalt_SystemVersion_block_invoke + 113
Dec 31 09:00:04 iMac-de-Baptiste-MENANT Kodi[833]: 1 libdispatch.dylib 0x00007fff9948a40b _dispatch_client_callout + 8
Dec 31 09:00:04 iMac-de-Baptiste-MENANT Kodi[833]: 2 libdispatch.dylib 0x00007fff9948a303 dispatch_once_f + 67
Dec 31 09:00:04 iMac-de-Baptiste-MENANT Kodi[833]: 3 CarbonCore 0x00007fff8d11dfbc _Gestalt_SystemVersion + 987
Dec 31 09:00:04 iMac-de-Baptiste-MENANT Kodi[833]: 4 CarbonCore 0x00007fff8d11d7d0 Gestalt + 139
Dec 31 09:00:04 iMac-de-Baptiste-MENANT Kodi[833]: 5 libSDL-1.2.0.dylib 0x00000001147f3368 QZ_VideoInit + 152
Dec 31 09:00:04 iMac-de-Baptiste-MENANT Kodi[833]: 6 libSDL-1.2.0.dylib 0x00000001147e48ff SDL_VideoInit + 927
Dec 31 09:00:06 iMac-de-Baptiste-MENANT WindowServer[167]: disable_update_timeout: UI updates were forcibly disabled by application "Kodi" for over 1.00 seconds. Server has re-enabled them.
Dec 31 09:00:20 iMac-de-Baptiste-MENANT WindowServer[167]: disable_update_likely_unbalanced: UI updates still disabled by application "Kodi" after 15.00 seconds (server forcibly re-enabled them after 1.00 seconds). Likely an unbalanced disableUpdate call.
Dec 31 09:00:20 iMac-de-Baptiste-MENANT WindowServer[167]: common_reenable_update: UI updates were finally reenabled by application "Kodi" after 15.44 seconds [0.06fps] (server forcibly re-enabled them after 1.00 seconds [1.00fps])
Dec 31 09:37:04 iMac-de-Baptiste-MENANT Kodi[953]: CPSGetCurrentProcess(): This call is deprecated and should not be called anymore.
Dec 31 09:37:04 iMac-de-Baptiste-MENANT Kodi[953]: set_foreground_operation_state(): This call is deprecated and should not be called anymore.
Dec 31 09:37:05 iMac-de-Baptiste-MENANT AGMService[520]: ProcessPath : /Applications/Kodi.app/Contents/MacOS/Kodi
Dec 31 09:37:07 iMac-de-Baptiste-MENANT Kodi[953]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt -- it is a documented limitation. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Dec 31 09:37:07 iMac-de-Baptiste-MENANT Kodi[953]: 0 CarbonCore 0x00007fff8d1916df ___Gestalt_SystemVersion_block_invoke + 113
Dec 31 09:37:07 iMac-de-Baptiste-MENANT Kodi[953]: 1 libdispatch.dylib 0x00007fff9948a40b _dispatch_client_callout + 8
Dec 31 09:37:07 iMac-de-Baptiste-MENANT Kodi[953]: 2 libdispatch.dylib 0x00007fff9948a303 dispatch_once_f + 67
Dec 31 09:37:07 iMac-de-Baptiste-MENANT Kodi[953]: 3 CarbonCore 0x00007fff8d11dfbc _Gestalt_SystemVersion + 987
Dec 31 09:37:07 iMac-de-Baptiste-MENANT Kodi[953]: 4 CarbonCore 0x00007fff8d11d7d0 Gestalt + 139
Dec 31 09:37:07 iMac-de-Baptiste-MENANT Kodi[953]: 5 libSDL-1.2.0.dylib 0x000000010893c368 QZ_VideoInit + 152
Dec 31 09:37:07 iMac-de-Baptiste-MENANT Kodi[953]: 6 libSDL-1.2.0.dylib 0x000000010892d8ff SDL_VideoInit + 927
Dec 31 09:37:07 iMac-de-Baptiste-MENANT XBMCHelper[956]: ParseOptions - AppPath /Applications/Kodi.app/Contents/MacOS/Kodi
Dec 31 09:37:07 iMac-de-Baptiste-MENANT XBMCHelper[956]: ParseOptions - AppHome /Applications/Kodi.app/Contents/Resources/Kodi
Dec 31 09:37:08 iMac-de-Baptiste-MENANT WindowServer[167]: disable_update_timeout: UI updates were forcibly disabled by application "Kodi" for over 1.00 seconds. Server has re-enabled them.
Dec 31 09:37:11 iMac-de-Baptiste-MENANT WindowServer[167]: common_reenable_update: UI updates were finally reenabled by application "Kodi" after 3.43 seconds [0.29fps] (server forcibly re-enabled them after 1.00 seconds [1.00fps])"
If someone is able to help me (using an IMac will be a more helpfull), I'm blocked since days and I don't know what to do.
Thanks in advance for your assistance
Best regards
Baptiste
