cant install xbmc on my Designer Habitat - HD Android 4.0 Media Player Media
i got this android tv box running 4.0.3 but when i try to install xbmc i get
this your device is not compatible
pls help
Which version did you download? Did you try installing it via the device's downloads app?
Maybe have a look over the
Android FAQ (wiki)
i downloaded the following versions
kodi-14.0-Helix_beta5-armeabi-v7a
kodi-20141129-03d5947-master-x86
non of them worked so i tried using the devices playstore and it browser but i either get not installed or
not compactible
It should install, but the bad news is it won't run very well because your box uses an Allwinner A10 SoC. I wouldn't put much effort into getting this to work.
