Full Version: [TEST] If you cannot browse SMB shares...
Could people having issues browsing their SMB shares (i.e. having to add SMB sources by ip address) test this APK and report, please:
http://mirrors.xbmc.org/test-builds/andr...bi-v7a.apk
[EDIT] build is actually available, now
Will this install separately from Helix or SPMC builds?
Just need to know if I need to backup before testing.
No. It's an Helix build.
It still suffers from the same issue.
If you continually attempt to try to open WORKGROUP it may eventually generate all the shares, but it is a hit and miss situation.
Here's the debug log: http://xbmclogs.com/show.php?id=362215
It seems that when it scans for the Workgroup shares it times out way to early. When you click on Workgroup it fails almost instantly.
Also, if you look at the log, after about the 6th or 7th attempt it does eventually generate the shares.
