2014-12-13, 20:35
sorry but this is a 23.976 file, which play fine in my sys without dropped or skipped frames.
here is a debug log anyway: http://pastebin.com/RMV9A2LF
cheers
cheers
<screen id="0" minimum_w="320" minimum_h="200" current_w="1920" current_h="1080" maximum_w="32767" maximum_h="32767">
<output name="HDMI1" connected="true" w="1920" h="1080" x="0" y="0" crtc="0" wmm="1060" hmm="626">
<mode id="0x48" name="1920x1080" w="1920" h="1080" hz="60.00000" current="false" preferred="true"/>
<mode id="0xa9" name="1920x1080" w="1920" h="1080" hz="50.00000" current="false" preferred="false"/>
<mode id="0xaa" name="1920x1080" w="1920" h="1080" hz="59.94020" current="false" preferred="false"/>
<mode id="0xaf" name="1920x1080" w="1920" h="1080" hz="24.00000" current="true" preferred="false"/>
<mode id="0xad" name="1920x1080" w="1920" h="1080" hz="30.00000" current="false" preferred="false"/>
<mode id="0xae" name="1920x1080" w="1920" h="1080" hz="25.00000" current="false" preferred="false"/>
<mode id="0xb1" name="1920x1080" w="1920" h="1080" hz="29.97010" current="false" preferred="false"/>
<mode id="0xb2" name="1920x1080" w="1920" h="1080" hz="23.97608" current="false" preferred="false"/>
<mode id="0xab" name="1920x1080i" w="1920" h="1080" hz="30.00000" current="false" preferred="false"/>
<mode id="0xac" name="1920x1080i" w="1920" h="1080" hz="25.00000" current="false" preferred="false"/>
<mode id="0xb0" name="1920x1080i" w="1920" h="1080" hz="29.97010" current="false" preferred="false"/>
<mode id="0xb3" name="1680x1050" w="1680" h="1050" hz="59.88325" current="false" preferred="false"/>
<mode id="0xb4" name="2880x576" w="2880" h="576" hz="50.00000" current="false" preferred="false"/>
<mode id="0xb5" name="1600x900" w="1600" h="900" hz="59.98247" current="false" preferred="false"/>
<mode id="0xb6" name="2880x480" w="2880" h="480" hz="60.00000" current="false" preferred="false"/>
<mode id="0xb7" name="2880x480" w="2880" h="480" hz="59.94006" current="false" preferred="false"/>
<mode id="0xb8" name="1280x1024" w="1280" h="1024" hz="75.02467" current="false" preferred="false"/>
<mode id="0xb9" name="1280x1024" w="1280" h="1024" hz="60.01974" current="false" preferred="false"/>
<mode id="0xba" name="1440x900" w="1440" h="900" hz="59.90146" current="false" preferred="false"/>
<mode id="0xbb" name="1366x768" w="1366" h="768" hz="59.78954" current="false" preferred="false"/>
<mode id="0xbc" name="1280x800" w="1280" h="800" hz="59.90955" current="false" preferred="false"/>
<mode id="0xbd" name="1152x864" w="1152" h="864" hz="75.00000" current="false" preferred="false"/>
<mode id="0xbe" name="1280x720" w="1280" h="720" hz="59.96726" current="false" preferred="false"/>
<mode id="0xbf" name="1280x720" w="1280" h="720" hz="60.00000" current="false" preferred="false"/>
<mode id="0xc0" name="1280x720" w="1280" h="720" hz="50.00000" current="false" preferred="false"/>
<mode id="0xc1" name="1280x720" w="1280" h="720" hz="59.94020" current="false" preferred="false"/>
<mode id="0xc2" name="1440x576" w="1440" h="576" hz="50.00000" current="false" preferred="false"/>
<mode id="0xc3" name="1440x576i" w="1440" h="576" hz="25.00000" current="false" preferred="false"/>
<mode id="0xc4" name="1024x768" w="1024" h="768" hz="75.07622" current="false" preferred="false"/>
<mode id="0xc5" name="1024x768" w="1024" h="768" hz="70.06936" current="false" preferred="false"/>
<mode id="0xc6" name="1024x768" w="1024" h="768" hz="60.00384" current="false" preferred="false"/>
<mode id="0xc7" name="1440x480" w="1440" h="480" hz="60.00000" current="false" preferred="false"/>
<mode id="0xc8" name="1440x480" w="1440" h="480" hz="59.94006" current="false" preferred="false"/>
<mode id="0xc9" name="1440x480i" w="1440" h="480" hz="30.00000" current="false" preferred="false"/>
<mode id="0xca" name="1440x480i" w="1440" h="480" hz="29.97003" current="false" preferred="false"/>
<mode id="0xcb" name="832x624" w="832" h="624" hz="74.55127" current="false" preferred="false"/>
<mode id="0xcc" name="800x600" w="800" h="600" hz="72.18757" current="false" preferred="false"/>
<mode id="0xcd" name="800x600" w="800" h="600" hz="75.00000" current="false" preferred="false"/>
<mode id="0xce" name="800x600" w="800" h="600" hz="60.31654" current="false" preferred="false"/>
<mode id="0xcf" name="720x576" w="720" h="576" hz="50.00000" current="false" preferred="false"/>
<mode id="0xd0" name="720x480" w="720" h="480" hz="60.00000" current="false" preferred="false"/>
<mode id="0xd1" name="720x480" w="720" h="480" hz="59.94006" current="false" preferred="false"/>
<mode id="0xd2" name="640x480" w="640" h="480" hz="75.00000" current="false" preferred="false"/>
<mode id="0xd3" name="640x480" w="640" h="480" hz="72.80880" current="false" preferred="false"/>
<mode id="0xd4" name="640x480" w="640" h="480" hz="66.66667" current="false" preferred="false"/>
<mode id="0xd5" name="640x480" w="640" h="480" hz="60.00000" current="false" preferred="false"/>
<mode id="0xd6" name="640x480" w="640" h="480" hz="59.94048" current="false" preferred="false"/>
<mode id="0xd7" name="720x400" w="720" h="400" hz="70.08166" current="false" preferred="false"/>
</output>
<output name="DP1" connected="false">
</output>
<output name="HDMI2" connected="false">
</output>
<output name="VIRTUAL1" connected="false">
</output>
</screen>
(2015-01-18, 03:18)rob77 Wrote: [ -> ]I'm running windows 8.1 on a nuc and see the same behaviour. The skipped frames are once a minute or so but not really noticeable unless you look really closely at end credits. Is the only fix to downgrade to windows 7 or enable sync display to video?
Cheers
Edit: I enabled "Use a fullscreen window rather than true fullscreen" which I had disabled before and now I do not get any skipped frames on 24 hz or 23.976 hz material. I don't know why this is and what downsides there are to using a full screen window but I will keep an eye out for any changes.
Edit 2: Using full screen window has created stutter on live TV so its back to the drawing board. It works okay for a few minutes and then the frame rate goes wrong. This was tested with 60hz material.
(2015-08-23, 08:45)a11599 Wrote: [ -> ]This issue has been worked around in Kodi 16 Jarvis for windowed fullscreen mode (not for true fullscreen).
