Full Version: host connection errors when first boot
Using openelec/gotham. Every time i boot up, I get host connection errors. I've pulled a log which shows the following errors:
Any help would be supremely appreciated!!!
(this was with a quick search of the word error):
23:10:47 T:140382328686400 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
18:10:48 T:140382328686400 DEBUG: UDisks: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UDisks was not provided by any .service files
18:10:48 T:140382328686400 DEBUG: DeviceKit.Disks: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.DeviceKit.Disks was not provided by any .service files
18:10:51 T:140382328686400 INFO: Error loading includes.xml file (/storage/.xbmc/addons/skin.aeonmq5/720p/IncludesPlaylistWidgets.xml): Failed to open file (row=0, col=0)
18:11:29 T:140380813002496 ERROR: Exception in thread Thread-11:
gaierror: [Errno -2] Name or service not known
18:11:29 T:140381006034688 ERROR: Exception in thread Thread-10:
18:11:29 T:140381836519168 ERROR: Exception in thread Thread-5:
18:11:34 T:140381777770240 ERROR: Exception in thread Thread-8:
18:11:34 T:140381760984832 ERROR: Exception in thread Thread-2:
18:11:34 T:140381073176320 ERROR: Exception in thread Thread-3:
18:11:34 T:140382029752064 ERROR: Exception in thread Thread-1:
18:11:34 T:140381828126464 ERROR: Exception in thread Thread-4:
18:11:34 T:140381811341056 ERROR: Exception in thread Thread-6:
18:12:17 T:140380880144128 NOTICE: XBMC Log Uploader: upload failed with response: '<?xml version="1.0" encoding="UTF-8"?>\n<result>\n <error>err_spamguard_censor</error>\n</result>'
Is this producing any problem in using the system, or are you just curious to make it go away?
Try delaying xbmc starting until network is ready, it is in the openelec settings addon.
I have so many addons I don't actually use that I couldn't tell you if it's causing problems.
URL error: Unable to connect to server Unable to connect to host
followed by
Error in artwork rotation
[Erno-2] Name or service not known
I put a 10 second delay and the errors still returned.
thanks for your help!
my google sleuthing skills came up with the solution:
Disabled XBMB3C
stopped receiving the error.
