2014-12-03, 06:17
I am having trouble with my xbmcbuntu installation in that when I put the computer to sleep or hibernation it is working perfectly at 1080p then on resume
it wakes up briefly displays at 1080p, then only shows xbmc on the upper left corner of the TV and is at 1280x800p.
I can then set the resolution back to 1080p and it goes back to fullscreen 1080p just fine. This is reproducible
every time I put the system to sleep/wake it up. the computer is a HP dv4 laptop that I bought cheap with a broken LCD. I have it hidden
in my entertainment center and hooked up to my TV via HDMI and it works wonderfully with XMBCbuntu. Specs of the laptop are here. /Laptop Specs
Pictures of what I see are shown below.
XBMC before I suspend the system
XBMC just after it resumes
XBMCBuntu login screen when switching between XBMC and the desktop
xbmc.log at http://paste.ubuntu.com/9352160/
this is the newest version of XBMCBuntu running XBMC 13.2, Architecture is X86_64
xrandr output
ryan@ryan-HP-Pavilion-dv4-Notebook-PC:~$ sudo xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 32767 x 32767
LVDS1 connected 1280x800+0+0 (normal left inverted right x axis y axis) 303mm x 190mm
1280x800 60.0*+
1024x768 60.0
800x600 60.3 56.2
640x480 59.9
VGA1 disconnected (normal left inverted right x axis y axis)
HDMI1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 820mm x 460mm
1920x1080 60.0*+ 59.9 24.0 24.0
1920x1080i 60.1 60.0
1600x1200 60.0
1400x1050 59.9
1280x1024 60.0
1360x768 60.0
1280x720 60.0 59.9
1024x768 75.1 70.1 60.0
1440x480i 60.1 60.1 60.1
800x600 72.2 75.0 60.3 56.2
720x480 60.0 59.9
640x480 75.0 72.8 60.0 59.9
720x400 70.1
DP1 disconnected (normal left inverted right x axis y axis)
DP2 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
I have tried creating a xorg.conf file and dropping in some info that I found online. this is the contents of my xorg.conf
Section "Screen"
Option "HWCursor" "Off"
Identifier "Screen0"
Device "Device1"
Monitor "Monitor0"
DefaultDepth 24
Option "NoLogo" "True"
Option "DynamicTwinView" "False"
Option "metamodes" "1920X1080_60 +0+0"
SubSection "Display"
Depth 24
Modes "1920x1080_60"
EndSubSection
EndSection
I have tried changing the Screen, Device, and Monitor settings from 0 to 1 since I have 2 displays. the broken internal LCD, and the HDMI
The xorg.conf file here does not seem to make any difference as the result is the same if it is there as if I delete it completely and restart.
When fully shutdown and restarted, the resolution stays correctly at 1080p. it is only on suspend/resume and Hibernate/resume that it screws up.
Any help would be appriciated as I cant seem to fix it. I dont know if I need a correct xorg.conf or if I can somehow have the system run a script that uses xrandr to set resolution on resume.
Thanks in advance.
xrandr output
1280x800 60.0*+
1024x768 60.0
800x600 60.3 56.2
640x480 59.9
1600x1200 60.0
1400x1050 59.9
1280x1024 60.0
1360x768 60.0
1280x720 60.0 59.9
720x480 60.0 59.9
720x400 70.1
Section "Screen"
Device "Device1"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Thanks in advance.
