2014-12-03, 20:53
Hi, when I'm adding some source I first open DialogMediaSource, then click on "Search" and the XBMC opens FileBrowser correct? I need that when click in "add source" instead of call DialogMediaSource, the XBMC call FileBrowser. It's possible?
I tried to do this in DialogMediaSource.xml. Without success.
The log.
The log.
PHP Code:
15:38:54 T:139914766432192 INFO: Loading skin file: DialogMediaSource.xml, load type: KEEP_IN_MEMORY
15:38:54 T:139914766432192 DEBUG: ------ Window Init (DialogMediaSource.xml) ------
15:38:54 T:139914766432192 DEBUG: ExecuteXBMCAction : Translating ActivateWindow(FileBrowser)
15:38:54 T:139914766432192 DEBUG: ExecuteXBMCAction : To ActivateWindow(FileBrowser)
15:38:54 T:139914766432192 DEBUG: Activating window ID: 10126
15:38:54 T:139914766432192 ERROR: Unable to locate window with id 126. Check skin files
15:39:01 T:139914766432192 DEBUG: ProcessMouse: trying mouse action leftclick
15:39:01 T:139914766432192 INFO: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
