2014-12-04, 17:59
hi everyone,
i recently bought this sound bar from sony. The only way to connect the sound bar is through optical cable and so i connected it directly with my Kodi machine (ASROCK ION330) running OpenElec Helix RC.
So now my question is, which are the best output configuration settings to set in Kodi? When I enable passthrough i can only control the volume directly with the sound bar which i don't really like, but there i have these AC3 and Dolby Digital settings. Can I set the output to fixed or optimized to get the same or even better results?
Or should i connect the sound bar to my 2008 Sony HDTV?
thanks so much for your help
