2015-02-20, 11:06
When pausing video it shows timebar only. But when pausing live tv it also shows program title/plot/logo etc. Is there a way to make this work with all video?
(2015-02-18, 17:37)bryanbrazil Wrote: [ -> ](2015-02-18, 10:51)smiffy1989 Wrote: [ -> ]Do you use wrap list or fixed list for your horizontal lists? If you use the default wrap list, just move Movies to the end. Should achieve the effect you want.(2015-02-18, 06:36)bryanbrazil Wrote: [ -> ]Try reordering your main menu items in skin settings (ie, swap the positions of the second and third items).
That doesn't achieve what I want. I like the order that they are in, its just that when I first startup position 2 is the default instead of position 3.
I have:
Movies - TV Shows - Live TV - Weather - Settings
I want Live TV to be the default and be in the middle but TV Shows is the default.
If I switch TV Shows and Live TV around, Live TV will be the default but will no longer be in the middle.
Does that make sense?
(2015-02-20, 11:06)lednurb Wrote: [ -> ]When pausing video it shows timebar only. But when pausing live tv it also shows program title/plot/logo etc. Is there a way to make this work with all video?
(2015-02-20, 18:36)misa Wrote: [ -> ]Love you skin and got a question. When I see the TV series I can see the network logo's before the name but in movies I only see the ? sign. Is there a way to see also logo's?
(2015-02-20, 18:55)bryanbrazil Wrote: [ -> ](2015-02-20, 18:36)misa Wrote: [ -> ]Love you skin and got a question. When I see the TV series I can see the network logo's before the name but in movies I only see the ? sign. Is there a way to see also logo's?
The ? sign is displayed when the studio logo is missing. Are your movies from lesser known studios for which there are no logos?
You can check by looking to see if your studios can be found in the list of studio logos shown here (may have to download the zip from github to see the entire list):
https://github.com/bryanbrazil/skin.mimi...gs/studios
(2015-02-20, 19:34)misa Wrote: [ -> ](2015-02-20, 18:55)bryanbrazil Wrote: [ -> ](2015-02-20, 18:36)misa Wrote: [ -> ]Love you skin and got a question. When I see the TV series I can see the network logo's before the name but in movies I only see the ? sign. Is there a way to see also logo's?
Thanks I will download them but how do I activate them in your skin?
(2015-02-21, 17:55)lowfi Wrote: [ -> ]HI im running from git. 1080p res.Which window is this?
I see this however:
The R is cut off.
(2015-02-22, 16:42)patria o muerte Wrote: [ -> ]Hi bryanbrazil,I have no idea how an airmouse works...what would it take to make the skin compatible?
i love this skin,but is a bit unusable with an airmouse.Have you planned to include that feature?
(2015-02-22, 17:34)bryanbrazil Wrote: [ -> ]Hi,(2015-02-22, 16:42)patria o muerte Wrote: [ -> ]Hi bryanbrazil,I have no idea how an airmouse works...what would it take to make the skin compatible?
(2015-02-22, 21:26)Edworld Wrote: [ -> ]Hi Bryan,Xbt files shouldn't be on git, they are generated when installing from the repo.
Your current GIT doesn't include white.xbt and when using extendedinfo, some of the information is hard to read (I selected a movie to illustrate the issue)
