Full Version: [SOLVED]Logitech K400 media buttons on kodi 14
I have un keyboard Logitech K400. Since the update from XBMC 13 to Kodi 14, the media-key on my keyboard don't work (volume up, volume down and Mute). I have the first version of the k400 keyboard. I have this one http://3.bp.blogspot.com/-IQHyQeSmTc8/T6...yout+2.jpg and not the second version, that dont have the same key : http://www.xbmc-italia.it/wp-content/upl...ouseSX.jpg
How can i do ?
thanks
karpatt
L'anglais n'étant pas ma langue, pour les francophone : Je possède un clavier K400 de Logitech. Et les trois touches de volumes ne fonctionnent plus depuis la mise à jour sur kodi 14. Je possède la première version du clavier car après Logitech à transformer ces trois touches (voir les photos). Comment faire pour qu'elles refonctionnent ? Merci beaucoup !
Which OS are you running XBMC/Kodi on?
Excuse i haven't say that....
I'm on Linux Lubuntu 14.04 (ubuntu with lxde) on a Zotac ND22. The media-key works very well on 13.2 but now not.
Same issue here. K400r (the later version, same keyboard though), running rc3 on win8.1.
Ned Scott, thanks i read this but on my Lubuntu.. i still can not do the media-key working...
You can use the tool obkey to remove the keys that are not working in kodi:
./obkey ~/.config/openbox/lubuntu-rc.xml
I have removed the buttons XF86AudioRaiseVolume, XF86AudioLowerVolume, and XF86AudioMute and saved the file. After restarting kodi the buttons worked well.
Thanks a lot Dash145 !!!!
My problem is resolved !!!!
