I have two lists, one has static content (lets call it list_1), the other one (list_2) has dynamic content (plugin://) which is derived from a property of list_1.
So depending on the focused position of list_1 other content is displayed in list_2.
I wanted to use this construction for a home screen widget with (recommended, recent, etc. content)
But unfortunately every time list_1 gets focused it shows item no. 1 and not like I would expect, the last focused position.
Somehow list_2 remembers the last focused position and not stars always on position no. 1.
Any clues on who/why/when containers can remember they last focused position?
I managed to do the same thing but with grouplists. You can try and use this condition for list_2 items:
ControlGroup(Id).HasFocus(Id)
Where you would pass list_1 id and the Id of the button innside list_1.
This one returns focused or last focused for ControlGroup (grouplist).
But beware that it does not work well with mouse\touch, only keyboard.
Check the ID for list 1 isn't used elsewhere.
The ID of list_1 (ID 9100) isn't used anywhere for sure.
I just wonder why the position of list_2 (ID 8000) is being remembered even though the content changes.
Here is an excerpt from my code
PHP Code:
<control type="group">
<left>1028</left>
<top>452</top>
<visible>Container(9000).Hasfocus(1)</visible>
<control type="list" id="9100">
<description>Movie Widget</description>
<left>0</left>
<top>0</top>
<width>240</width>
<height>230</height>
<visible>!Control.HasFocus(8000)</visible>
<onup>8000</onup>
<ondown>9000</ondown>
<viewtype label="WidgetList">list</viewtype>
<orientation>horizontal</orientation>
<scrolltime tween="sine" easing="out">200</scrolltime>
<itemlayout/>
<focusedlayout height="230" width="240">
<visible>Skin.HasSetting(nomoviewidget)</visible>
<control type="label">
<description>Widget Name</description>
<left>0</left>
<top>25</top>
<width>220</width>
<height>40</height>
<align>center</align>
<aligny>center</aligny>
<label>$INFO[ListItem.Label]</label>
<font>cirrus_20</font>
<textcolor>c0FFFFFF</textcolor>
<shadowcolor>black</shadowcolor>
</control>
</control>
</focusedlayout>
<content>
<item id="1">
<label>Recent Movies</label>
<onclick>noop</onclick>
<property name="foo">videodb://recentlyaddedmovies/</property>
</item>
<item id="2">
<label>Random Movies</label>
<property name="foo">plugin://service.library.data.provider?type=randommovies&reload=10&limit=10</property>
</item>
</content>
</control>
<left>342</left>
<top>-22</top>
<control type="list" id="8000">
<viewtype label="535">list</viewtype>
<left>0</left>
<top>5</top>
<width>800</width>
<height>275</height>
<onleft>SetFocus(9000)</onleft>
<onright>8001</onright>
<pagecontrol>-</pagecontrol>
<itemlayout height="25" width="800">
<left>20</left>
<top>26</top>
<width>250</width>
<height>23</height>
<textcolor>grey</textcolor>
<selectedcolor>selected</selectedcolor>
<align>left</align>
<scroll>false</scroll>
</control>
</itemlayout>
<focusedlayout height="25" width="800">
<left>20</left>
<top>26</top>
<width>250</width>
<height>23</height>
<textcolor>black</textcolor>
<align>left</align>
</control>
</focusedlayout>
<content limit="10">$INFO[Container(9100).ListItem.Property(foo)]</content>
</control>
</control>
</control>
Possibly because when it regains focus it has to check the visible conditions and the last focus position isn't available instantly so it revert back to position 1.
EDIT: As a test pull out the visible conditions in the items and see what happens.
What if you try using a panel insteed of a list ?
(2014-12-10, 21:21)Hitcher Wrote: [ -> ]Possibly because when it regains focus it has to check the visible conditions and the last focus position isn't available instantly so it revert back to position 1.
Also though about trying this.
EDIT: this doesn't seem to fix the problem
(2014-12-10, 21:37)butchabay Wrote: [ -> ]What if you try using a panel insteed of a list ?
How could using a panel influence this behaviour? But I will see if anything changes.
I didn't come so far to test the panel, because a wraplist did the thing.
But I still don't know why
Because a list behaves in a different way as a wraplist or panel.
