Full Version: Surface Pro Side menu and windowed mode
I have been using XBMC since forever (original Xbox days) and since I got my Surface Pro 3 recently, I have been experiencing an issue that I am hoping will be fixed in the upcoming release of Kodi... the issue is detailed in this thread with a workaround.. Essentially, every click pops out the side menu from the left. The solution of manually fixing the xml files to move to kiosk mode is tedious... even worst with the quick release cycle. Can a developer help fix this?
I have also been wondering if a button could be integrated in the skin to allow for windowed mode (the backslash '\' key on the keyboard triggers this). I mostly use my Surface Pro 3 with the keyboard detached when watching movies and i can then no longer trigger the windowed mode
Thanks for the help.
+1
+1
