Full Version: How to remove sources?
Hi all,
sorry if this is obvious but I have searched and can't find a solution.
I am running XBMC on amazon fire tv stick.
I added a bunch of source folders but now I want to remove them (I didn't realize that this works better if tv shows and movies are in separate folders).
I cannot find any way to remove a source. One support article says to set the content to "none" and update -- but I cannot access the contextual menus it refers to by pressing "c" because I only have the fire remote and I believe there is no way to hook a keyboard up.
Can anyone help?
thanks
sorry all -- just ifgured this out. the button with three lines on it brings up the contextual menu with a remove source option.
In XBMC home screen
Go to video and select files. Under files arrow down to the source you want to remove. Click the menu button on your remote to bring up the context menu and select set content.
thank you!
Thanks heaps. Worked like a charm.
