2014-12-12, 03:54
OSX Version 10.10.1
ATV1
Open Elec 4.2.1 USB
linux 3.16.13
Gotham
I was running atv flash from firecore with frodo on the ATV1 hard drive but then decided to switch to crystalbuunto or open elec, tried installing one on the hard drive (wiping out the factory image) and then decided finally on running openelec from usb stick. Since changing from atv flash i have had no luck getting any files/directories to be accessible from my laptop. Ive even tried downgrading from gotham back to frodo and nothing changed (using ssh and dragging the .tar file in to the .update folder). I also tried upgrading to a kodi 14 release candidate by using the same method and it did not change. Still sitting using gotham.
to reiterate the problem is that i Cant seem to get any files to load from laptop to the atv. Whenever i try to configure a directory via samba (AFP is no longer presenting itself as an option) it just thinks and then does nothing and i cant add files. On the laptop side of things everything seems in order. The proper folder is being shared and is accessible.
http://xbmclogs.com/show.php?id=371262
ATV1
Open Elec 4.2.1 USB
linux 3.16.13
Gotham
