2014-12-12, 15:11
So ive been trying to get this to work on a non alienware PC / non alpha unit so far i can only get the first version of the shell running but little to no success it forces me to update into the next version and thats where it breaks.
What ive found in the update files is this, which i think is the restriction.
Alpha UI in Action:
https://www.youtube.com/watch?v=IEs5OM005D0
Line 63: autoUpdateData = AUTO_UPDATE_DATA(b'AlphaUI', b'ASM100', b'Desktopx64', autoUpdateDataResult[0])
ASM100 Would indicate the motherboard used in the alpha.
ill try and keep you updated.
Current Alpha UI versions
ALPHA UI - Release A01 (works but forces an update)
ALPHA UI - Release A02
ALPHA UI - Release A03
can be downloaded off Dells website
Alpha UI in Action:
