Full Version: Image download not always working
I'm using tinyMediaManager and am very pleased with it - but I have an issue. I'm not sure if it always occurs, but I'm pretty sure when it does it's for PNG files only, not JPG.
What happens is that I pick a poster or fanart on the Edit movie dialog. The poster and fanart will then show in the Edit movie dialog, but when I click OK, it's not downloaded to the folder (nothing happens).
If I click 'Show original image', right-click 'Save image...' and then use 'Choose file' to select the saved image, that works.
I'm running 2.6.4 (r1770).
please submit a bug report after you tried to download the artwork..
