Running Kodi RC3 and I can't access my external hard drive connected to my ASUS router via SMB. I entered the correct username and password but it doesn't take. Anyone else figure this one out?
So your username 'test' (odd user name are you sure it's right?) and whatever password you entered are not accepted.
Can you access the share from the commandline?
(2014-12-14, 21:02)nickr Wrote: [ -> ]So your username 'test' (odd user name are you sure it's right?) and whatever password you entered are not accepted.
Setup name "test" for debug log. I'm able to access external hard drive from laptop with same username password. What do you mean access the share from command line?
I'm also having same issues on my laptop running Gotham
Update I was able to fix. I was missing wakeonlan.xml file
