Hi i have a series in 3 episode, but it find only the first and refruse to take the other. Is name S01Exx and S02Exx and so on. I use this
http://thetvdb.com/ and it this series
http://thetvdb.com/?tab=series&id=74852
I have three maps and try all in same.
the first map
avatar last airbender
avatar >s01Exx
avatar 2 >s02Exx
avatar 3 >S03Exx
I try numers of combination. some avatar s01,avatar last airbender, avatar last airbender s01,, book 01- water
try
Avatar the last airbender/season 01/s01exx
Avatar the last airbender/season 02/s02exx
Avatar the last airbender/season 03/s03exx
(2014-12-14, 12:43)karandras24 Wrote: [ -> ]try
Hm, is only work whit Avatar The Last Airbender on one season and i have to call second and third
Avatar the last airbender 2 and Avatar the last airbender 3.
http://i.imgur.com/LyoaJqK.jpg and
http://i.imgur.com/MZyhzeC.jpg
(2014-12-14, 13:49)dabourb Wrote: [ -> ] (2014-12-14, 12:43)karandras24 Wrote: [ -> ]Avatar the last airbender/season 01/s01exx
+1, Please have a look at this wiki entry for how to name TV shows.. http://kodi.wiki/view/Naming_video_files/TV_shows
Also great utility for renaming TV shows: http://www.therenamer.com/, Uses thetvdb as it source..
Cheers!
I not understand the wiki :/
And the not work with the tip. I try yours.
And i stop here
http://i.imgur.com/suUWiur.jpg so it not mess up the files
You can also use the next namig:
Avatar The Last Airbender/Season 1/Avatar 1x...
Avatar The Last Airbender/Season 2/Avatar 2x...
Avatar The Last Airbender/Season 3/Avatar 3x...
(2014-12-15, 23:40)Ovokx Wrote: [ -> ]You can also use the next namig:
Try this
http://imgur.com/PkHJ4uG Do I it righ? Not working anyway.
(2014-12-16, 22:11)karandras24 Wrote: [ -> ]you nearly have it right, but you need to rename the files to match the tvdb.
i.e. you need to change Avatar S02E21 to Avatar S02E01 and so on.
the episode numbers need to match what the tvdb shows http://thetvdb.com/?tab=season&seriesid=...8114&lid=7
thank
I feel silly now :/
So now I understand how it works. Thanks again
Yes it works
glad you got it sorted in the end.
