2014-12-15, 19:02
Just downloaded the newest version on 14.0 RC3 onto my Pivos XS and after it loaded all the main screens look fine however when playing any videos they appear to be in zoom mode? Can't see anywhere to adjust this.
(2014-12-22, 08:37)Koying Wrote: [ -> ]See http://forum.kodi.tv/showthread.php?pid=...pid1866406
Resolution issues
Please try http://mirrors.xbmc.org/test-builds/andr...bi-v7a.apk
(2014-12-27, 01:40)Toronto Wrote: [ -> ]Something happened from RC2 to RC3 that also moved along to the stable release. RC2 was fine but once I installed Rc3 I had this problem, same on kodi 14. had to revert back to Gotham.Yes, seems that way, I'm running 15.0 and I'm just hope they fix it soon, I'm glad that at least I can use it with that quick fix.
Hopefully it will get fixed soon.
(2014-12-22, 08:37)Koying Wrote: [ -> ]See http://forum.kodi.tv/showthread.php?pid=...pid1866406I will try this, thank you
Resolution issues
Resolution issues
