Full Version: Freezer and artefact on superRTL
Hi Guys,
I'm using VDR in the following config:
vdr (2.1.6/2.1.6) - The Video Disk Recorder
hello (2.1.1) - A friendly greeting
permashift (1.0.0) - Automatically record live TV
epgtableid0 (2.1.1) - EPG handler for events with table id 0x00
streamdev-client (0.6.1-git) - VTP Streaming Client
dvbsddevice (2.1.2) - SD Full Featured DVB device
svdrpdemo (2.1.1) - How to add SVDRP support to a plugin
dvbapi (2.1.1-GIT-vdr-2.1.6) - SoftCAM for OSCam
vnsiserver (1.2.0) - VDR-Network-Streaming-Interface (VNSI) Server
status (2.1.1) - Status monitor test
svcsvr (2.1.1) - Service demo server
osddemo (2.1.2) - Demo of arbitrary OSD setup
pictures (2.1.1) - A simple picture viewer
svccli (2.1.1) - Service demo client
dvbhddevice (2.1.6) - HD Full Featured DVB device
rcu (2.1.1) - Remote Control Unit
streamdev-server (0.6.1-git) - VDR Streaming Server
skincurses (2.1.1) - A text only skin
I access the VDR live stream via VNSI from an Intel NUC with OpenElect 4.97.2.
When I switch to the channel SuperRTL I get continuous artefacts and freezers and in the vdr log I can see the following messages in a loop:
Dec 15 20:16:42 david vdr: [1635] VNSI: Started streaming of channel SUPER RTL HD (timeout 10 seconds)
Dec 15 20:16:43 david vdr: [27698] VNSI: Video Input - new pmt, attaching receiver
Dec 15 20:16:43 david vdr: [27698] DVBAPI: 0.0 set CAM decrypt (SID 11931 (0x2E9B), caLm 4, HasCaDescriptors 1)
Dec 15 20:16:43 david vdr: [1638] VNSI: Created stream for pid=300 and type=8
Dec 15 20:16:43 david vdr: [1638] VNSI: Created stream for pid=310 and type=1
Dec 15 20:16:43 david vdr: [1638] VNSI: Created stream for pid=330 and type=9
Dec 15 20:16:43 david vdr: [1638] VNSI: Created stream for pid=320 and type=11
Dec 15 20:16:47 david vdr: [1636] VNSI: call retune ...
Dec 15 20:16:47 david vdr: [1638] VNSI: close video input ...
Dec 15 20:16:47 david vdr: [1636] DVBAPI: 0.0 set CAM decrypt (SID 11931 (0x2E9B), caLm 5, HasCaDescriptors 1)
Dec 15 20:16:47 david vdr: [1638] VNSI: call retune ...
Dec 15 20:16:47 david vdr: [27698] VNSI: Video Input - new pmt, attaching receiver
Dec 15 20:16:47 david vdr: [27698] DVBAPI: 0.0 set CAM decrypt (SID 11931 (0x2E9B), caLm 4, HasCaDescriptors 1)
Dec 15 20:16:51 david vdr: [1660] VNSI: call retune ...
Dec 15 20:16:51 david vdr: [1638] VNSI: close video input ...
Dec 15 20:16:51 david vdr: [1660] DVBAPI: 0.0 set CAM decrypt (SID 11931 (0x2E9B), caLm 5, HasCaDescriptors 1)
Dec 15 20:16:51 david vdr: [1638] VNSI: call retune ...
Dec 15 20:16:51 david vdr: [27698] VNSI: Video Input - new pmt, attaching receiver
Dec 15 20:16:51 david vdr: [27698] DVBAPI: 0.0 set CAM decrypt (SID 11931 (0x2E9B), caLm 4, HasCaDescriptors 1)
Dec 15 20:16:55 david vdr: [1686] VNSI: call retune ...
Dec 15 20:16:55 david vdr: [1638] VNSI: close video input ...
Dec 15 20:16:55 david vdr: [1686] DVBAPI: 0.0 set CAM decrypt (SID 11931 (0x2E9B), caLm 5, HasCaDescriptors 1)
Dec 15 20:16:55 david vdr: [1638] VNSI: call retune ...
Dec 15 20:16:55 david vdr: [27698] VNSI: Video Input - new pmt, attaching receiver
Dec 15 20:16:55 david vdr: [27698] DVBAPI: 0.0 set CAM decrypt (SID 11931 (0x2E9B), caLm 4, HasCaDescriptors 1)
Dec 15 20:16:59 david vdr: [1704] VNSI: call retune ...
Dec 15 20:16:59 david vdr: [1638] VNSI: close video input ...
Dec 15 20:16:59 david vdr: [1704] DVBAPI: 0.0 set CAM decrypt (SID 11931 (0x2E9B), caLm 5, HasCaDescriptors 1)
Dec 15 20:16:59 david vdr: [1638] VNSI: call retune ...
Dec 15 20:16:59 david vdr: [27698] VNSI: Video Input - new pmt, attaching receiver
Dec 15 20:16:59 david vdr: [27698] DVBAPI: 0.0 set CAM decrypt (SID 11931 (0x2E9B), caLm 4, HasCaDescriptors 1)
Dec 15 20:17:03 david vdr: [1723] VNSI: call retune ...
Dec 15 20:17:03 david vdr: [1723] DVBAPI: 0.0 set CAM decrypt (SID 11931 (0x2E9B), caLm 5, HasCaDescriptors 1)
Dec 15 20:17:08 david vdr: [1638] VNSI: close video input ...
Dec 15 20:17:08 david vdr: [1638] VNSI: call retune ...
Dec 15 20:17:08 david vdr: [27698] VNSI: Video Input - new pmt, attaching receiver
Dec 15 20:17:08 david vdr: [27698] DVBAPI: 0.0 set CAM decrypt (SID 11931 (0x2E9B), caLm 4, HasCaDescriptors 1)
Dec 15 20:17:12 david vdr: [1849] VNSI: call retune ...
Dec 15 20:17:12 david vdr: [1849] DVBAPI: 0.0 set CAM decrypt (SID 11931 (0x2E9B), caLm 5, HasCaDescriptors 1)
Dec 15 20:17:16 david vdr: [1638] VNSI: close video input ...
Dec 15 20:17:16 david vdr: [1638] VNSI: call retune ...
Dec 15 20:17:17 david vdr: [27698] VNSI: Video Input - new pmt, attaching receiver
Other HD channels which use DVBAPI as well work without problems. I already switched EPG Update off, but without success.
I can observe the same behaviour when I'm accessing via XBMC from my Win 8.1 PC. So probably a problem of the VDR backendHuh
Any help is very much appreciated.
BR
André
vnsi gets a ChannelChange event from VDR. This instructs vnsi to re-tune the channel. Originally this feature was demanded by dvbapi which I think triggers this. I would ask manio, the author of dvbapi.
