Full Version: OpenELEC Testbuilds for RaspberryPi (Kodi 15.0) Part 1
New OpenELEC I****** build: #0113
(Supercedes previous build)
# uname -a
Linux rpi512 3.18.2 #1 PREEMPT Tue Jan 13 21:05:10 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Jan 12 2015 20:50:01
Copyright (c) 2012 Broadcom
version 341a769a2a969100a8923c9f60dd8c865d3d2174 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150113215658-r19990-gc0ad104 [Build #0113]
# vcdbg log msg 2>&1 | grep DTOK
001578.013: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of OpenELEC master (c0ad1043, changelog) and tip of XBMC master (669b87f4, changelog) with the following modifications:
  • Includes newclock4 patches
  • Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
  • Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-3.18.y
  • Excludes the OpenELEC kodi-001-helix_rpb_backports patch in favour of sourcing these and possibly more recent patches directly from newclock4 branch
  • Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
  • Disabled "Total Duration" in Confluence (see build #0221 for details)
  • Adapted service.openelec.settings to take advantage of PR:5217 [patch details]
  • Includes latest libnfs master (9a02f775)
  • Includes latest libcec master (9f000e43)
  • Includes latest xbmc-pvr-addons master (42b7f7a8)
  • Includes latest xbmc-addon-xvdr master (328fa653)
  • Includes additional ffmpeg codecs/muxers enabled for testing/benchmarking purposes (see patch)
  • Includes animated splash support (patch)
  • Includes commits from libcec-2.2.0 (popcornmix)
  • Exclude kodi-102-dont_really_depend_on_SDL_image.patch: No longer required
  • Exclude lirc_rpi.conf: No longer required, let Device Tree handle lirc_rpi (add "dtoverlay=lirc-rpi" to config.txt)
  • Include d6f4bebf: new package: libsquish
  • Include patch: Use our own texturepacker
  • Include patch: Enable kernel device-tree support (details)
  • Include patch: Add *.dtb files to firmware
  • Include patch: Add device tree kernel trailer
  • Include patch: Temporary fix kodi-pvr-addons build issue (kodi-pvr-addons)
  • Include PR:5430: [URIUtils] Fix IsSmb, IsFTP, IsAfp, IsDAV and IsNfs.
  • Include PR:5752: [jsonrpc] Allow retrieving empty TV shows via VideoLibrary.GetTVShows.
  • Include PR:5958: Fix state not saved after #5842 if playing from "Recently added".
  • Include PR:6177: [video info] Fix changing fanart
Build Highlights:
  1. Kernel mmc/dma updates
  2. Updated libnfs
  3. Updated kodi-pvr-addons
Build Details:
  1. OpenELEC:
    • IMX: Revisit coherent_pool (PR:3784, 2 commits, 2 files changed)
    • drop vpn (PR:3772, 5 commits, 11 files changed)
    • Add a project for WeTek Play TV box (b49c8b7a)
    • WeTek.Play/options: build: depend on mkimage/u-boot-tools (0e842188)
    • wetek.play: reorder linux patches (ec388d52)
    • wetek.play: linux: define __USE_KERNEL_XATTR_DEFS (1ef9ad73)
    • projects/WeTek.Play: rename to projects/WeTek_Play (8ddfc8fd)
    • tvheadend: bump libhdhomerun (73a97996)
    • repository.unofficial.addon.pro: bump (cef672df)
    • OpenELEC-settings: update to OpenELEC-settings-0.6.0 (c0ad1043)
  2. XBMC:
    • PR 4342 + add-on sync (PR:6196, 2 commits, 19 files changed)
    • [Confluence] fix focused text color for addons on home (f185a3a6)
  3. libnfs:
    • win32: add define for S_IFLNK (a5119185)
    • READDIR: Bake the file type into the mode we return (7b46c2bc)
    • nfs-ls: S_IFLNK is now avbailable under windows. No need for ifdef (9a02f775)
  4. kodi-pvr-addons:
    • Change README format to MarkDown (PR:402, 2 commits, 2 files changed)
    • [pvr.dvblink] version 1.9.13 (01f3c8d4)
    • Added support for ATSC subchannel numbers, fixing 'no tuner available' message users were getting with this type of channel (53c48b2f)
    • Added new PVR API function getBackendHostname. Bumped PVR API version to 1.9.3 (afb10ac8)
    • [cppmyth] Bump version 1.1.2 (0661aa93)
    • [pvr.mythtv] Bump version 1.11.2 (303a5faf)
    • [platform] added new callback based Wait() method to CCondition (b21b28a8)
    • [pvr.hts] replace with the newer pvr.tvh fork (5ec05077)
    • [pvr.hts] bump version (6cde7ea1)
    • sync api (56437392)
    • Merge branch 'pr372'. closes #372 (069a9cba)
    • Merge branch 'pr384'. closes #384 (a223ae30)
    • Merge branch 'pr398'. closes #398 (8642ea08)
    • Merge branch 'pr401'. closes #401 (33f3cf8a)
    • Merge branch 'pr399'. closes #399 (1d60b822)
  5. kernel 3.18.y:
    • New commits in this build:
      • config: Add USB_NET_HUAWEI_CDC_NCM, USB_NET_SR9700 and USB_NET_SR9800 (f4f63e24)
      • MMC: support for non-AUTO_CMD23 transfer modes (b22467c6)
      • mmc: Disable CMD23 transfers on all cards (21f1babd)
      • bcm2708-dmaengine: un-nobble DMA peak throughput (3537cdcd)
  6. Additional commits/pull requests/changes not yet merged upstream:
    • Added: patch: Temporary fix for kodi-pvr-addons build issue (kodi-pvr-addons)
(2015-01-12, 15:31)majaru Wrote: [ -> ]normal, zoom, wide zoom, custom, 4; 3
Some movies have black bars
#1223, 23-Dec-2014 aspect ratio works
http://i1167.photobucket.com/albums/q630...aebc9a.png
I can confirm that with at least #0111 and following all videos are somewhat distorted in aspect ratio, e.g. I have black margins on top and bottom on a 16:9 TV although the video is also 16:9. Any settings during video playback do not seem to work, whatever I chose: aspect ratio, zoom, shifting, etc, nothing happens.
edit: Okay, that's not true. It works for high-res videos with at least 720p. The culprit seems to be this new video setting "Enable native resolution switching".
(2015-01-14, 20:05)thent Wrote: [ -> ]edit: Okay, that's not true. It works for high-res videos with at least 720p. The culprit seems to be this new video setting "Enable native resolution switching".
You have that turned on?
@majaru did you also turn this on?
I should probably remove that commit. It was purely for testing and it is not recommended as a default option. It is far from a working feature.
(2015-01-14, 20:26)popcornmix Wrote: [ -> ]I should probably remove that commit. It was purely for testing and it is not recommended as a default option. It is far from a working feature.
Would it make sense to label experimental features as such, like "Enable native resolution switching - experimental"? It is hard to keep on top of the many settings, and this would be a heads up if a user/tester is trying to figure out why something isn't working right.
(2015-01-14, 20:26)popcornmix Wrote: [ -> ]You have that turned on?
Yes. Disabling solved the issues.
New OpenELEC I****** build: #0114
# uname -a
Linux rpi512 3.18.2 #1 PREEMPT Wed Jan 14 21:34:19 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Jan 14 2015 19:51:39
version 83418eb035b8cb762e7d1bf5fb10c09ecf258a04 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150114222030-r19997-ga43b836 [Build #0114]
001575.219: Kernel trailer DTOK property says yes
Based on tip of OpenELEC master (a43b836c, changelog) and tip of XBMC master (48aa36b2, changelog) with the following modifications:
  • Includes latest xbmc-pvr-addons master (ce70914a)
  • Include patch: Fix build patch for kodi-pvr-addons
Build Highlights:
  1. New firmware
  2. More kodi-pvr-addons updates
  3. Updated dtb files patch, now updates create_sdcard for fresh installs
  4. [videodatabase] path hash is not invalidated when removing tv shows or episodes
Build Details:
  1. Firmware (Jan 14):
    • firmware: Inline motion vectors - wait for CME to complete first. See: link
  2. OpenELEC:
    • fix compile for Linux 3.18 (PR:3787, 1 commit, 1 file changed)
    • projects/imx6/patches/linux: prepend kernel config cmdline to bootloader... (PR:3785, 1 commit, 1 file changed)
    • imx6: move coherent_pool back to kernel. increase to 2M (7eeb1f56)
    • boblightd.service: remove ExecStopPost. not needed (024b9851)
    • libhdhomerun: update to libhdhomerun-20141210 (a43b836c)
  3. XBMC:
    • Optimize CEpgInfoTag. No more copies, just shared pointers. (PR:5763, 1 commit, 30 files changed)
    • Add support for right mouse drag (PR:6197, 1 commit, 3 files changed)
    • [depends] fix building audio encoders on non unified depends platforms (PR:6199, 1 commit, 1 file changed)
    • [videodatabase] path hash is not invalidated when removing tv shows or episodes (PR:6204, 1 commit, 1 file changed)
    • dvdplayer: drop autocrop (PR:6154, 1 commit, 11 files changed)
    • dvdplayer: fix compiler warning in cc code (PR:6206, 1 commit, 1 file changed)
    • drop language string for crop black bars after d30e8ec54bbc374e70f1b313881d66ccdb3d2d62 (1e6c388a)
  4. kodi-pvr-addons:
    • Various build fixes (PR:403, 4 commits, 12 files changed)
    • [lang] update of language files from Transifex (e47b36f3)
  5. kernel 3.18.y:
      • bcm2708_gpio: Avoid calling irq_unmask for all interrupts (1c5855bf)
      • squash: Correct the GPIOEDS initialisation (0008982b)
    • Added: patch: Fix build patch for kodi-pvr-addons
    • Added: patch: Add *.dtb files to firmware
Hello.
Have you got networking problems with build #0114?
Here does not seem to work well.
If you are using test builds, then you should be willing to post a bug report.
You need to describe exactly what you do to provoke the problem.
Mediainfo of the file, a debug enabled log file and possibly a sample file that demonstrates the issue are likely to be needed. What kind of share are you using (NFS/SMB?), etc.
(2015-01-15, 13:11)ijsbeer79 Wrote: [ -> ]If you are using test builds, then you should be willing to post a bug report.
Hi.
Are you referring to my post?
I'm not able to do anything: my lan just stops working.
Thank you.
Which build did it last work on?
Please include the output of "dmesg" if you can, ideally one where the LAN works and one where it doesn't. You could host the logs on pastebin or sprunge if they are large.
(2015-01-15, 14:13)PhilE Wrote: [ -> ]Which build did it last work on?
Build #0113 works well.
(2015-01-15, 14:13)PhilE Wrote: [ -> ]Please include the output of "dmesg" if you can, ideally one where the LAN works and one where it doesn't.
How can I do it if my network is down? I'm not able to open a ssh session.
Yes, that does make it rather difficult. It is possible to get messages from the serial console for the early part of the boot process, but then it gets switched off before USB comes up.
It is a long shot, but if you remove the "quiet" from cmdline.txt on the SD card and add "nosplash" you will see slightly more messages at boot up. See if anything obvious shows up. What does the Network tab of System Info show?
[It's a shame there isn't a way to switch to a console prompt, or at least to be able to view kernel messages...]
FYI, I've upgraded my Pi to #0114, and I still have network access using the built-in LAN port on a B+. What are you using?
He could always mount the sdcard in a computer and get the logs.
I will update to latest build now as well and check if there's any network issues.
Edit: All good so far with #0114
@PhilE
I'm using model B and built-in LAN port. System Info shows LAN up and running.
@Patrics83
Thank you.
OK, I will do more testing without overclocking.
Add "textmode" to the end of your line in cmdline.txt and you'll get a console, needs a keyboard attached to be of any use.
