New OpenELEC I****** build #0207:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 3.18.5 #1 PREEMPT Sun Feb 8 01:02:53 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Feb 7 2015 19:35:45
Copyright (c) 2012 Broadcom
version e3cfc1e5001c71261c4d79e852723910772ffba9 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150208010157-r20214-gae13e63 [Build #0207]
# vcdbg log msg 2>&1 | grep DTOK
001506.716: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (ae13e636,
changelog) and tip of
XBMC master (54b069df,
Build Highlights:
- New firmware
- Upstream connman patches to improve network stability (dhcp etc.)
- Dropped PR6246, no longer builds on master due to other PVR commits
- Several new kernel commits, including a fix for HifiBerry-Amp
Build Details:
- Firmware (Feb 7):
- firmware: Move the warranty bit to bit 25 for Pi2 See: link
- firmware: arm_loader: Don't allow bcm2708.serial to be set in cmdline.txt. See: link
- firmware: Bug fixes for vc_image_fill on YUV_UV
- firmware: arm: Enable early b-resp. May give slightly improved write times to sdram/peripherals
- OpenELEC:
- lirc: fixed ir blasting (PR:3874, 1 commit, 2 files changed)
- connman: add upstream patches (82750bbd)
- unofficial: move icon/changelog (5eba7fa4)
- systemd wrapper: also restart services on upgrade (ae13e636)
- XBMC:
- Fix build in OSX with case-sensitive FS. (PR:6354, 1 commit, 1 file changed)
- [Keyboard Layouts] Add Spanish QWERTY (PR:6314, 1 commit, 1 file changed)
- [pvr] do not persist channel data a user can not set (PR:6353, 1 commit, 2 files changed)
- Optimize CPVRRecording. No more copies, just shared pointers. (PR:6207, 1 commit, 23 files changed)
- [PVR] Optimized CPVRManager::CanSystemPowerdown not to do expensive backend calls (PR:6324, 1 commit, 4 files changed)
- [pvr] Fix on Channel Manager channel move with mouse (PR:6322, 1 commit, 1 file changed)
- pvr/dvdplayer - set frame rate if not set by demuxer (PR:6340, 2 commits, 5 files changed)
- text rendering: dont change character spacing on justify (PR:6140, 1 commit, 2 files changed)
- [rebrand] ffmpeg extra version xbmc -> kodi (PR:6304, 1 commit, 3 files changed)
- [pvr] Fix list change with first or last page selection on Channel Manager (PR:6323, 1 commit, 1 file changed)
- kernel 3.18.y-rebase:
- New commits in this build:
- HiFiBerry Amp: fix device-tree problems (e84183b6)
- BCM270x_DT: Add i2c0_baudrate and i2c1_baudrate parameters (312667e4)
- pinctrl-bcm2835: bcm2835_gpio_direction_output must set the value (401868bb)
- w1-gpio: Sort out the pullup/parasitic power tangle (8329e96d)
- BCM2709_DT: Set the "always-on" flag for the timer to enable high res mode (2dc96ff2)
- i2c_bcm2708: Fix clock reference counting (fbd62b89)
- BCM270x_DT: Rename the activity LED back to the prosaic "led0" (f137a3e3)
- Add device-tree overlay for pcf2127 (5a37af9c)
- Commits no longer in build:
- config: Add ENC28J60 spi ethernet module (273b1197)
- Fix grabbing lock from atomic context in i2c driver (fec9b9d8)
(2015-02-08, 02:52)denz Wrote: [ -> ]This is a sample file of squashed live tv. I have purchased MPEG2 codec however I haven't received it yet so I am not sure if this is the cause. The interesting thing I must have changed some setting and now when I watch recorded tv I only hear sound.
Did you disable MMAL in settings/video/acceleration?
Oh yes that is the setting. I should be getting mpeg codes tomorrow so hopefully that will fix the aspect ratio.
(2015-02-07, 20:05)allan87 Wrote: [ -> ]3 seconds out of how many?
it was something like 24.7x vs 22. I usually see "importing channels from backend" followed by "importing EPG..." - but with that PR the channel importing didn't show up and EPG import was also faster.
https://drive.google.com/file/d/0B7X9IEX...sp=sharing
Fixed
here
(getting the codec licence should also fix it)
New OpenELEC I****** build #0208:
RPi /
RPi2
# uname -a
Linux rpi512 3.18.6 #1 PREEMPT Sun Feb 8 23:50:11 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Feb 7 2015 19:35:45
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150208234915-r20236-g2ca87fa [Build #0208]
001529.051: Kernel trailer DTOK property says yes
Based on tip of
OpenELEC master (2ca87fac,
XBMC master (c84bece9,
Build Highlights:
- New 3.18.6 kernel
- libc: install package 'arm-mem' only with TARGET_CPU=arm1176jzf-s
- Enable CONFIG_VMSPLIT_2G allowing ARM access to full 1GB RAM on RPi2
- Added: PR:6362: [videodatabase] include tvshows base dir in GetPathsForTvShow (thread)
- Dropped native resolution commits as they require rebasing
Build Details:
- OpenELEC:
- glibc: update to glibc-2.21 (293c21e9)
- sqlite: update to sqlite-autoconf-3080802 (5280e677)
- linux: update to linux-3.18.6 (cd64c199)
- Mesa: update to Mesa-10.4.4 (7c07d8cb)
- libpciaccess: update to libpciaccess-0.13.3 (54ce285a)
- xf86-video-nvidia-legacy: update to xf86-video-nvidia-legacy-304.125 (5ac00fb5)
- xf86-video-nvidia: update to xf86-video-nvidia-340.76 (bcd3393b)
- cmake: force not using system deps (b47ecedc)
- libc: install package 'arm-mem' only with TARGET_CPU=arm1176jzf-s (64197d35)
- libssh: update to libssh-0.6.4 (3c54af22)
- kodi: add PR6356 (9188d497)
- projects/imx6/patches/kodi: update imx6 rework patches (61fe4000)
- noobs: add support for PROJECT based multiple noobs builds (a7c79ebe)
- noobs: move distro icon to distri folder (36a5fbed)
- noobs: add support for noobs 'supported_hex_versions' (7e83801d)
- kodi: systemd wrapper: cosmetics (5e32f07d)
- kodi: add NFS chunksize patch (8300c082)
- projects/RPi*/linux: enable CONFIG_VMSPLIT_2G, thanks to popcornmix (2ca87fac)
- XBMC:
- [seek] replaces constant seek with additive seek support (PR:6347, 3 commits, 11 files changed)
- [fix][bluray] Fix Blu-Ray playback for all playback paths and refactor ShowPlaySelection (PR:6334, 4 commits, 11 files changed)
- [addon] webinterface shouldn't have GUI as dependency (ce2f5621)
- newclock4:
- dvdplayer: only consider standard framerates for vfr (60d45231)
- [mmalrenderer] Add back in SetVideoRect lost in PR6090 (1e012aa3)
- [PATCH] text rendering: dont change character spacing on justify, only word spacing (f0610b62)
- BCM270x_DT: Add pwr_led, and the required "input" trigger (5f1c4a04)
- BCM2708_VCIO : Add automatic creation of device node (7fa07e9f)
- Fix grabbing lock from atomic context in i2c driver (58ee33ad)
- config: Add ENC28J60 SPI ethernet module (72df98fe)
- ntp: Patch to fix false positives on 32bit systems (89d56313)
I have been running successive builds for a week now (now on build #207) on the new RPI2 and have repeatedly had the consistent problem of a total crash
(only on RPI 2 H/w) at every startup. Not even splash screen just lockup on black screen
If I subsequently ssh in I can reboot and everything works normal so I can enjoy both the speed of the new build with the new platform build.
A power down/power up cycle and 1'm back to square one.
I thought it was down to overclocking but after trying various configurations including default no difference
I have tried deleting userdata folder to remove any previous settings... still crashes.
Finally, I seem to have tracked it down to a CEC problem 1st log below after hard boot 2nd after reboot. If I disable CEC on RPI 2 everything works fine even after power off/on cycle, buth no remote control!
I have 2nd RPI B+ linked into same system Samsung TV, Denon 2313 etc. CEC control has/is very stable until RPI 2 builds.
16:38:32 11.155418 T:3041017856 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
16:38:32 11.155575 T:2958947392 NOTICE: Thread CECAdapter start, auto delete: false
16:38:32 11.157169 T:2958947392 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
16:38:32 11.157349 T:2958947392 ERROR: CecLogMessage - Open - vc_cec could not be initialised
16:38:32 11.157434 T:2958947392 ERROR: CecLogMessage - could not open a connection (try 1)
16:38:32 11.187523 T:2948592704 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
16:38:32 11.197577 T:3041017856 NOTICE: Raspberry PI firmware version: Feb 7 2015 19:35:45
Copyright (c) 2012 Broadcom16:38:32 11.155418 T:3041017856 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
16:38:32 11.206894 T:3041017856 NOTICE: Checking resolution 36
16:38:33 12.157958 T:2958947392 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
16:38:33 12.158114 T:2958947392 ERROR: CecLogMessage - Open - vc_cec could not be initialised
16:38:33 12.158184 T:2958947392 ERROR: CecLogMessage - could not open a connection (try 2)
16:38:34 13.158622 T:2958947392 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
16:38:34 13.158778 T:2958947392 ERROR: CecLogMessage - Open - vc_cec could not be initialised
16:38:34 13.158849 T:2958947392 ERROR: CecLogMessage - could not open a connection (try 3)
16:38:35 14.159294 T:2958947392 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
16:38:35 14.159476 T:2958947392 ERROR: CecLogMessage - Open - vc_cec could not be initialised
16:38:35 14.159565 T:2958947392 ERROR: CecLogMessage - could not open a connection (try 4)
16:38:36 15.159986 T:2958947392 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
16:38:36 15.160159 T:2958947392 ERROR: CecLogMessage - Open - vc_cec could not be initialised
16:38:36 15.160232 T:2958947392 ERROR: CecLogMessage - could not open a connection (try 5)
16:38:38 17.290781 T:2921329728 NOTICE: Thread CECAdapterUpdate start, auto delete: false
16:41:15 173.947479 T:3041017856 NOTICE: Storing total System Uptime
16:41:15 173.947968 T:3041017856 NOTICE: Saving settings
16:41:15 173.982529 T:3041017856 NOTICE: stop all
16:41:15 173.982834 T:3041017856 NOTICE: stop player
16:41:15 173.991623 T:3041017856 NOTICE: stop dvd detect media
16:41:16 175.176498 T:3041017856 NOTICE: stop sap announcement listener
16:41:16 175.176620 T:3041017856 NOTICE: clean cached files!
16:41:16 175.176727 T:3041017856 NOTICE: unload skin
16:41:16 175.183243 T:3041017856 NOTICE: stopped
16:41:16 175.183411 T:3041017856 NOTICE: destroy
16:41:16 175.183517 T:3041017856 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
16:41:16 175.183578 T:3041017856 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
16:41:16 175.183624 T:3041017856 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
16:41:16 175.183685 T:3041017856 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
16:41:16 175.183731 T:3041017856 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
16:41:16 175.183792 T:3041017856 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
16:41:16 175.183868 T:3041017856 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
16:41:16 175.183914 T:3041017856 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
16:41:16 175.183975 T:3041017856 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
16:41:16 175.184021 T:3041017856 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
16:41:16 175.184082 T:3041017856 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
16:41:16 175.191727 T:3041017856 NOTICE: closing down remote control service
16:41:16 175.192062 T:3041017856 NOTICE: unload sections
16:41:16 175.198746 T:3041017856 NOTICE: special://profile/ is mapped to: special://masterprofile/
After reboot
Your "after reboot" log is simlpy a subset of the first log (same timestams).
Best not to cut logs, instead post links to whole logs hosted on a pastebin site.
Also, what build are you running on your B+? Have you tried a recent test build (eg. #0207) on the B+, is that still stable?
(2015-02-08, 16:31)popcornmix Wrote: [ -> ] (2015-02-08, 02:52)denz Wrote: [ -> ]This is a sample file of squashed live tv. I have purchased MPEG2 codec however I haven't received it yet so I am not sure if this is the cause. The interesting thing I must have changed some setting and now when I watch recorded tv I only hear sound.
Fixed here
Thanks it worked however deinterlace on some channels is horrible. Raspberry Pi foundation must be busy still didn't receive my codes.
(2015-02-09, 11:49)Milhouse Wrote: [ -> ]Your "after reboot" log is simlpy a subset of the first log (same timestams).
You are quite right I duplicated paste!! Both logs are here
https://www.dropbox.com/sh/31t8upajt9zw1...5Pfja?dl=0
The B+ is my ref (has to be stable for max WAF appeal) is Running on OpenELEC (Milhouse) - Version: devel-20141223210156-r19858-gc75631b [Build #1223] 5.0, kernel: Linux ARM 32-bit version 3.18.1
I thought it was later
Hi, I noticed something strange yesterday...
When playing dvd img files the display dims slightly and it stays like that until I reboot or change resolution.
This happens on RPi B+ and RPi 2 B. I have tried to go back in the build history (>#0130) but I figured it might be better to ask if anyone else have noticed this behavior.
Scenario 1:
http://sprunge.us/HjKC
Sync playback to display enabled and resample audio
OMXPlayer enabled
MMAL disabled
No issues.
Scenario 2:
http://sprunge.us/HabP
Sync playback to display disabled
OMXPlayer enabled
MMAL enabled
No issues.
Scenario 3:
http://sprunge.us/RRPT
OMXPlayer enabled
MMAL enabled
Display dims slightly and stays like that until I reboot.
So to sum it up, sync playback to display > resample audio / adjust ppl makes the display to dim.
Except for this minor issues I'm having the rest is perfect!
Thanks a lot for your hard work
/Patric
(2015-02-09, 14:18)evanspae Wrote: [ -> ] (2015-02-09, 11:49)Milhouse Wrote: [ -> ]Your "after reboot" log is simlpy a subset of the first log (same timestams).
You are quite right I duplicated paste!! Both logs are here https://www.dropbox.com/sh/31t8upajt9zw1...5Pfja?dl=0
I have now installed [Build #0208] on both systems. The B+ has no issues on hanging on power up with #208, but the RPI 2 still does even with #208.
(2015-02-09, 14:38)Patrics83 Wrote: [ -> ]Hi, I noticed something strange yesterday...
Never heard of this and can't think of a reason. I note in your log a nubber of incompatible add-ons.
13:16:06 42.966045 T:1683330112 DEBUG: Addon plugin.video.offene_kanaele requires xbmc.python version 2.0 which is not available
13:16:07 43.682858 T:1683330112 DEBUG: Addon script.filecleaner requires xbmc.gui version 5.0.1 which is not available
13:16:07 43.754162 T:1683330112 DEBUG: Addon script.linphone requires xbmc.python version 1.0 which is not available
13:16:07 43.756950 T:1683330112 DEBUG: Addon script.linux.nm requires xbmc.python version 2.0 which is not available
13:16:07 43.774887 T:1683330112 DEBUG: Addon script.module.dialogaddonscan requires xbmc.python version 2.0 which is not available
13:16:07 43.833832 T:1683330112 DEBUG: Addon script.module.playbackengine requires xbmc.python version 2.0 which is not available
13:16:07 44.326267 T:1683330112 DEBUG: Addon skin.ace requires xbmc.gui version 5.0.0 which is not available
13:16:07 44.412556 T:1683330112 DEBUG: Addon skin.aeonmq5 requires xbmc.gui version 5.0.0 which is not available
13:16:07 44.425362 T:1683330112 DEBUG: Addon skin.amber requires xbmc.gui version 5.0.1 which is not available
13:16:07 44.547405 T:1683330112 DEBUG: Addon skin.bello requires xbmc.gui version 5.0.1 which is not available
13:16:08 44.603065 T:1683330112 DEBUG: Addon skin.carmichael requires xbmc.gui version 4.0.0 which is not available
13:16:08 44.648468 T:1683330112 DEBUG: Addon skin.cirrus.extended requires xbmc.gui version 5.0.1 which is not available
13:16:08 44.732979 T:1683330112 DEBUG: Addon skin.diffuse requires xbmc.gui version 4.0.0 which is not available
13:16:08 44.760231 T:1683330112 DEBUG: Addon skin.droid requires xbmc.gui version 4.0.0 which is not available
13:16:08 44.796169 T:1683330112 DEBUG: Addon skin.hybrid requires xbmc.gui version 5.0.0 which is not available
13:16:08 44.842999 T:1683330112 DEBUG: Addon skin.metroid requires xbmc.gui version 5.0.1 which is not available
13:16:08 44.888912 T:1683330112 DEBUG: Addon skin.nbox requires xbmc.gui version 4.0.0 which is not available
13:16:08 44.928276 T:1683330112 DEBUG: Addon skin.neon requires xbmc.gui version 5.0.1 which is not available
13:16:08 44.931229 T:1683330112 DEBUG: Addon skin.pm3-hd requires xbmc.gui version 4.0.0 which is not available
13:16:08 44.936543 T:1683330112 DEBUG: Addon skin.quartz requires xbmc.gui version 5.0.1 which is not available
13:16:08 44.984432 T:1683330112 DEBUG: Addon skin.re-touched requires xbmc.gui version 5.0.0 which is not available
13:16:08 45.030613 T:1683330112 DEBUG: Addon skin.refocus requires xbmc.gui version 5.0.1 which is not available
13:16:08 45.040768 T:1683330112 DEBUG: Addon skin.simplicity requires script.cu.lyrics version 2.0.6 which is not available
13:16:08 45.144684 T:1683330112 DEBUG: Addon skin.xeebo requires xbmc.gui version 4.0.0 which is not available
13:16:08 45.190983 T:1683330112 DEBUG: Addon skin.xperience-more requires xbmc.gui version 4.0.0 which is not available
13:16:08 45.243759 T:1683330112 DEBUG: Addon skin.xperience1080 requires xbmc.gui version 5.0.1 which is not available
13:16:08 45.284374 T:1683330112 DEBUG: Addon skin.xtv-saf requires xbmc.gui version 5.0.1 which is not available
13:16:08 45.351856 T:1683330112 DEBUG: Addon webinterface.home-row requires xbmc.gui version 4.0.0 which is not available
13:16:08 45.354557 T:1683330112 DEBUG: Addon webinterface.pwi requires xbmc.gui version 4.0.0 which is not available
13:16:10 46.583286 T:1683330112 INFO: ADDON: cpluff: 'Could not read plug-in directory /usr/lib/kodi/addons: No such file or directory'
13:16:10 46.601173 T:1683330112 DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
Can you confirm if the issue still occurs from a clean setup?
Rename /storage/.kodi to /storage/.kodi_back (and /storage/.xbmc to /storage/.xbmc_back if it exists) and reboot.
popcornmix. That log is normal. It's just processing the available repo list and filtering out the incompatible ones
Sure will do.
Edit: It happens even on clean install... I tried to take a photo and a movie of it but it's really hard.
