Are any of you experiencing stuttery playback of certain MPEG2 live streams? I'm using the new HDHomeRun add-on and have this on a couple of ATSC 1080i channels, while others (both 720p and 1080i) play perfectly. I have the codec licenses purchased and added to config.txt.
(2015-03-29, 14:44)popcornmix Wrote: [ -> ]If it's not the epel patch, then a nightly build on Windows/linux should have similar ffmpeg hevc code. Can you provoke a crash there?
I've rebuilt #0328 without
epel and HEVC continues to crash on the Pi2 (haven't done any testing on Pi1).
A Linux build (Ubuntu 14.10 x64, 2c6d5a8f) does NOT crash (must have started these HEVC files 30 times, all played successfully, no crashes).
Milhouse, thanks for the debug build. Here is a crash watching the same program from last night:
http://sprunge.us/MGWI
Several of my channels seem to produce periodic crashes when OMXPlayer is being used, Comedy Central, Disney, Nickelodean. I wonder if it is because they often use telecine and also do weird framerate changes during commercials. I'm uploading the recording to google drive now but it may be a few hours because it is 1.9gb.
(2015-03-29, 17:59)Milhouse Wrote: [ -> ]Further to the HEVC crashes, here's a debug-enabled crashlog without epel: http://sprunge.us/YGGJ
Do you think this crash is new to this build?
(2015-03-29, 18:02)popcornmix Wrote: [ -> ]Do you think this crash is new to this build?
No. I went back to #0227 and could get that to crash as well, so it's always been present since the introduction of HEVC support.
It doesn't happen all the time though, and may be dependent on rapid start-stop-start of HEVC files which is probably why I missed it when I initially tested a few movies (I tended to watch them for a minute or so, before testing the next).
With my current testing, it seems that if you start-stop-start a few movies in quick succession then you're pretty much guaranteed a crash eventually. I'm streaming these HEVC movies over SMB but I've also tested locally with the exact same result.
Edit: #0225 also crashes when playing HEVC, but this shouldn't have any of the NEON optimisations (#0225 crashlog:
http://sprunge.us/ESLb)
(2015-03-29, 15:50)hdmkv Wrote: [ -> ]Are any of you experiencing stuttery playback of certain MPEG2 live streams? I'm using the new HDHomeRun add-on and have this on a couple of ATSC 1080i channels, while others (both 720p and 1080i) play perfectly. I have the codec licenses purchased and added to config.txt.
Yes i see them in some 1080i streams and some sd tv channels from Tvheadend. Easy to see in camera pans
(2015-03-29, 14:35)noggin Wrote: [ -> ]Sorry wasn't clear. Files have Dolby Digital audio. Until now I've run with pass through enabled and have no stutter. However with the DTS HD MA and Dolby True HD decode (but not passthrough) capability, I disabled passthrough as I thought this would be needed to force decoding. With passthrough disabled I get stutter on these files.
Does enabling omxplayer work for you?
How about with omxplayer disabled but with "sync playback to display" enabled?
(2015-03-29, 18:08)Milhouse Wrote: [ -> ]With my current testing, it seems that if you start-stop-start a few movies in quick succession then you're pretty much guaranteed a crash eventually. I'm streaming these HEVC movies over SMB but I've also tested locally with the exact same result.
It's not crashing easily in my debug environment. Tried 3 HEVC files, and about 50 start/stops without a crash (just letting each file for about a second).
(2015-03-29, 18:39)popcornmix Wrote: [ -> ] (2015-03-29, 14:35)noggin Wrote: [ -> ]Sorry wasn't clear. Files have Dolby Digital audio. Until now I've run with pass through enabled and have no stutter. However with the DTS HD MA and Dolby True HD decode (but not passthrough) capability, I disabled passthrough as I thought this would be needed to force decoding. With passthrough disabled I get stutter on these files.
I've tried with and without omxplayer and pretty certain I tried both with and without sync playback to display for both players. In all cases disabling passthrough causes stutter. Will double check though.
I suspect that the problem is not hevc, but the software decoding at all. I reproduced the same bug with 264, when hardware decoding was turned off .
(2015-03-29, 18:41)popcornmix Wrote: [ -> ]It's not crashing easily in my debug environment. Tried 3 HEVC files, and about 50 start/stops without a crash (just letting each file for about a second).
Strange. I've tried testing #0328 (with and without epel), with a minimal config.txt (only "gpu_mem=256" and two codec licences, no overclock of any kind), and with a fresh .kodi, and I can still get it to crash with ease (by the 3rd or 4th file).
(2015-03-29, 19:12)MONSTA Wrote: [ -> ]I suspect that the problem is not hevc, but the software decoding at all. I reproduced the same bug with 264, when hardware decoding was turned off .
Yep (good point) - I've now been able to crash Kodi with a regular h264 movie that I never had a problem with when using hardware accelerated decoding.
Setting Video Acceleration to "Software" is sufficient, although it sometimes takes a few start-stop-start cycles (although in the log below, I managed to crash Kodi on the second "start").
Crashlog (debug enabled, no epel):
http://sprunge.us/OAeE
Popcornmix - here's an update on the playback performance of a Pi 2 with the file I PMed you a link to :
No audio pass-through
OMX Player - Sync to Display - very occasional
OMX Player - No Sync to Display - frequent
MMAL Acceleration - Sync to Display - occasional
MMAL Acceleration - No Sync to Display - frequent
(Sync to display method, when enabled, was Resample Audio)
So Sync to display improves things, but in all cases there are still issues IMO.
Audio pass-through
All the above scenarios are close to perfect - with possibly the odd stutter. No obvious difference between them.
New OpenELEC Isengard build #0329:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 3.19.3 #1 Sun Mar 29 21:41:10 BST 2015 armv6l GNU/Linux
# vcgencmd version
Mar 27 2015 18:48:55
Copyright (c) 2012 Broadcom
version b2109b1c1c8ae8717df455cfaf312a6c1801f45a (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150329213945-#0329-g5a88392 [Build #0329]
# vcdbg log msg 2>&1 | grep DTOK
001673.166: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (5a883921,
changelog) and tip of
XBMC master (01e00046,
- Includes newclock4 patches
- Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-3.19.y
- Excludes the OpenELEC kodi-001-helix_rpb_backports patch in favour of sourcing these and possibly more recent patches directly from newclock4 branch
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (e884d9a0)
- Includes latest libcec master (707bd51c)
- Includes latest libnfs master (63d40b17)
- Includes latest addons: audiodecoder.modplug (c7e8ca82), audiodecoder.nosefart (c77e5a12), audiodecoder.sidplay (f2e7d985), audiodecoder.snesapu (9fc775b1), audiodecoder.stsound (775c858d), audiodecoder.timidity (bf9ff93d), audiodecoder.vgmstream (0c3a51a2), audioencoder.flac (84acb141), audioencoder.lame (3eb59de9), audioencoder.vorbis (d556a687), audioencoder.wav (40aaedfa), kodi-platform (48bdd985), pvr.argustv (f227f989), pvr.demo (64749530), pvr.dvblink (7ad22a5e), pvr.dvbviewer (bd2c01f5), pvr.filmon (aa7b6583), pvr.hts (5b25721b), pvr.iptvsimple (38a72e5d), pvr.mediaportal.tvserver (f1c1f063), pvr.mythtv (59d0ddf7), pvr.nextpvr (e026e7aa), pvr.njoy (ce590843), pvr.pctv (ebe7e58a), pvr.vdr.vnsi (3a28e39a), pvr.vuplus (b0baab5a), pvr.wmc (b48784ad)
- Exclude kodi-999.97-fix_frametime_for_active_vsync.patch: Already merged
- Include master...stefansaraev:60afbf51: Prepare for kodi-15
- Include patch: Add dcadec package for DTS HD-MA support
- Include patch: Add experimental splash video
- Include patch: Enable audiodecoder/audioencoder, pvr and visualization addons
- Include PR:6418: Return correct playlist in Player.GetProperties
- Include PR:6703: [subtitles] refactor - fetch based on media basepath
- Include PR:6732: [pvr] fixed crash when multiple add-on instances get registered
- Include PR:6772: [musicdb] enable the library via xml
- Include PR:6801: [builtin] adds new builtin for seeking
- Include PR:6812: [video] select proper bookmark item based on current playtime
- Revert 01ecfb0b: Reverted until next kodi-15 sync
- Revert 1693d786: Reverted, don't force kodi-15 DEBUG
Build Highlights:
- Various updates
Build Details:
- OpenELEC:
- projects/imx6/patches/kodi: remove unneeded patch (8356bb77)
- mesa: update to mesa-10.5.2 (a8b07565)
- busybox: enable sha1sum/sha256sum/sha512sum applets (16b1d555)
- busybox: enable more applets/features (8ecaba8c)
- projects/WeTek_Play: use neon-fp16 FPU optimizations (97783486)
- kodi: move PR6090 out of projects folder (01ecfb0b)
- kodi: add upstream patch (for testing) (5a883921)
- XBMC:
- [Remote]Only log first connection attempt to avoid spamming the logs (PR:6824, 1 commit, 4 files changed)
- pvr.hts:
- [debian packaging] disable LTO until gcc 4.9 issues are fixed (PR:20, 1 commit, 2 files changed)
- pvr.iptvsimple:
- [droid] Fix extension library file name. (PR:11, 1 commit, 1 file changed)
