Hello,
I think I'm pretty close to having this working.
I'm logged into Netflix, I can see my list etc, but whenever I go to start a stream, the Kodi backdrop appears momentarily and then I am returned to the selection screen of Netflix (where i select what to watch).
I enabled debugging and this is the output of the log when I click to start a stream:
https://www.dropbox.com/s/c05jx0ycnlpvzs...i.txt?dl=0
A little info about the setup:
- HP Microserver N54L, 8gb RAM, Radeon HD5450
- Running Kodibuntu (Fresh install).
- ** 1024 x 768 15" monitor. < I'm using this monitor whilst I get everything set up how I want it, I mention it in case the problem is that the screen resolution is too small for Flix2Kodi to work.
Any help would be greatly appreciated.
Thanks in advance!
If you read the posts above yours you should see this addon doesn't work anymore.
Check out flix2kodi addon thread instead
Ah, I had both threads open, and actually thought I was posting in the Flix2Kodi thread. Oops.
(2015-02-17, 06:50)lja2014 Wrote: [ -> ]Can Netflixbmc be adjusted to work with Netflix Canada? If so how would I do it? Thanks.
Has anyone figured out how Netflix Canada can be accessed from within Kodi?
Did you try Flix2Kodi?
NetfliXBMC don't work in a several months.
@Boulevarder, I use W10 and am in Canada.
Flix2Kodi works, <=Non 5.1 sound
Netflix Remote Controller also works.
http://sticky-ux.com/apps/NetflixRemoteController/ <=5.1 sound, but requires some trial and error. I found the mouse control awkward to use.
My personal preference is a using a .bat file, advanced launcher to open the .bat, and autohotkey for remote mouse control from my television remote. Alt+F4 mapped to my remote for closing. Same principal for Shomi, except requires log in every time and Chrome (unless there is now a Windows app, I never watch it, so not a big deal for me)
Put "start:\\Netflix' in the .bat file and open it up. Again, only works on windows machines.
cwh
Is this working for Netflix Malaysia? I've had the plugin installed. Running Kodi J16.1 Jarvis on Mythbuntu LTS 16.04 (this is purpose-built HTPC). When I try to log in, it appears to work, but then nothing shows up in the list of shows and movies.
Edit: Nevermind, I find that Flix2Kodi is working fine for me. So I'll just use that from now on. Thanks.
Hi guys I am not tech savvy like you guys, can someone help me with the NetfliXBMC error, this is the error report I got
http://imgur.com/a/CyXEz
PLease be very simple to me , i dont understand difficult coding
(2016-06-29, 16:51)sagrath Wrote: [ -> ]NetfliXBMC don't work in a several months.
Repost ^^
There´s no workin addon to netflix at the moment.
I have used many apps like: Netflix, popcorntime, megabox and many more but -deleted- is best among all the other apps. -deleted- have amazing features like movie streaming and TV show streaming with or without subtitles in high definition. I have faced some issues with netflix and its very bad experience after spending lots of money. I am using -deleted pirate addon- for kodi. you can also take a look at it.
anthonyhaofmann I almost banned you as a spammer. That service is clearly a pirate illegal setup.
I mean "You can watch latest movies on...for free" - how did you ever think that fits in with our rules.
Does anyone know if this Addon still works?
I'm searching for a Netflix addon to use my Netflix account on raspberry 3 with Kodi.
I'm not searching for free or pirated movie.
I want to use my legal Netflix europe account.
(2018-02-26, 22:26)jumperger Wrote: [ -> ]Does anyone know if this Addon still works?
https://github.com/asciidisco/plugin.video.netflix, this is the closest to official as it will get for now
Tried installing the link from the github, used the repository (as suggested) but 2 of the dependencies required to install the netflix addon (script.module.pycryptodome & inputstream.adaptive) are unavailable.
Can't seem to manage installing them separately... no clue how to. :p
I'm on Windows 10 64-bit with the latest Kodi 18 Nightly.
Anybody have any input?
