(2015-02-01, 07:19)corona Wrote: [ -> ] (2015-01-30, 22:59)sideshowdad Wrote: [ -> ] (2015-01-28, 05:28)corona Wrote: [ -> ]Yeah there's a known problem in that python requests library is defaulting to using sslv3 but a number of services like adfreetime are blocking sslv3 due to security flaws.
I'm planning on trying the suggestions on http://lukasa.co.uk/2013/01/Choosing_SSL..._Requests/ to not use sslv3 when I get a chance.
Thanks Corona, I look forward to it.
Just updated to 1.3.13 which includes a fix for the ssl issue. There's a new setting which defaults to TLSv1 for communication which should work for all users, but can be changed if needed.
Hi corona, I just updated netflixbmc even re-installed kodi just in case and i see similar errors in log (SSLv3).
16:36:13 T:4984 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'requests.exceptions.SSLError'>
Error Contents: [Errno 1] _ssl.c:510: error:14094410:SSL routines:SSL3_READ_BYTES
slv3 alert handshake failure
File "C:\Users\Kevin\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py", line 1157, in <module>
index()
File "C:\Users\Kevin\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py", line 194, in index
if login():
File "C:\Users\Kevin\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py", line 761, in login
content = load(urlMain+"/Login")
File "C:\Users\Kevin\AppData\Roaming\Kodi\addons\plugin.video.netflixbmc\default.py", line 137, in load
r = session.get(url, verify=False).text
File "C:\Users\Kevin\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\sessions.py", line 469, in get
return self.request('GET', url, **kwargs)
File "C:\Users\Kevin\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\sessions.py", line 457, in request
resp = self.send(prep, **send_kwargs)
File "C:\Users\Kevin\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\sessions.py", line 569, in send
r = adapter.send(request, **kwargs)
File "C:\Users\Kevin\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\adapters.py", line 420, in send
raise SSLError(e, request=request)
SSLError: [Errno 1] _ssl.c:510: error:14094410:SSL routines:SSL3_READ_BYTES
Thanks,
Kevin
